Can DP6 MIDI learn?
monsieurescargot
Can DP6 MIDI learn?
Post by monsieurescargot »
Hi there.
Upgrading to DP6 for a couple of plugins doesn't really make sense to me.
But tell me that the new DP can MIDI learn cc parameters (like Ableton does) for its MAS plugins and VIs and I will upgrade...
please....come on.... tell me it does....
cheers
OSX 10.13. 16gig ram. UFX, Traveler mk1, Pulse16mx, DP10 , Live9, Nord Stage2, Sh101tubbutec, PolyEvolver Rack,Slim Phatty, MIDI Express XT, RYTM, AnalogKeys,Digitone, EmaxSE rack, Daking Pre/Eq, Tanzbar, tr606, SP16, s612, Neutron, TT303, EPS16+, Parva, p600Gligli, Biscuit, mcf42, therapsid, modules, seqV4
Post by Shooshie »
I guess it doesn't. Of course, I'm not really sure what you mean by "MIDI Learn." If you explain it, I'll tell you if I know of a way to do it.
billf
Post by billf »
I have the same question as Shooshie. What do you mean by "MIDI learn?"
vbassguy
Post by vbassguy »
first, i must MIDI learn...... then i will see if i can get DP to MIDI learn...
:shock:
G5 quad 2.5 ghz w/ 8 gigs ram, OS 10.5.4, DP 5.13,DP6, Mach 5,Mach 5 v2, SI, two loaded UAD-1e cards, PCIe 424, two Black Lion Modded 24 I/O's, Harrison 3624 console, cool old mics, pre's and compressors.....Great sounding Rooms.........
www.RRRPROD.com
Post by Shooshie »
:D Glad it's not just me. 20+ years I've been doing this professionally, and here I am a beginner again! So, someone learn me MIDI, learn me quick, learn me without the learning stick. ;)
Shoosh
mike_o
Post by mike_o »
parts of the DP 5 VI's could MIDI learn, but they were incomplete, and none of the plugins had that option, only the VI's, open modulo in DP5, right click on the tune knobs and it will offer "learn MIDI" as an option, select that and then move any MIDI controller, the controller will now be attached to the parameter knob.
only some controls work, others do not, modulo can assign the tune or frequency controls but not the hp/lp/bp/br filter select buttons, their system for plugin control is just non existent.
Mac Pro 2X Dual Core 2.66Ghz-10.4.9-7 GigRam-828MKII-MTPAV-Ultralight MK3-Digi Performer6.01-PeakPro5.1-Reason4-AbeltonLive6-Virus Rack(Red)-ReMOTE 25 & 37 SL-Nocturn-Stanton Dacratch-PluggoPack-DimensionLE W/EmuProteusPack-Sylenth1-Discovery MAC-MX4-Rapture-Alpha-Octopuss-Automat-Automat1-TALbassline-TALUno60
taylor12k
Post by taylor12k »
MIDI learn is the ability to, often right-click, on a plug in parameter (ideally, ANY paramter) to set it in "learn" mode for an instant.. and then turn a knob on your MIDI controller (any knob) and the program will register that knob as controlling that paramter.
it's the best way to quickly assign and re-assign controllers for realtime control quickly.
DP really really really (really) needs this ability.
taylor12k wrote:MIDI learn is the ability to, often right-click, on a plug in parameter (ideally, ANY paramter) to set it in "learn" mode for an instant.. and then turn a knob on your MIDI controller (any knob) and the program will register that knob as controlling that paramter.
I know it does this on the mixing board, but not plug-ins I guess. I have an AlphaTrack that I use for plug-ins sometimes.
Post by Shooshie »
Doesn't DP do this? It certainly does with some plugins.
taylor12k
Post by taylor12k »
may be plugin dependant. i just picked up the modelling suite from AAS.. and the standalone versions of those programs do it, i haven't tested that inside DP yet...
although, i have it open right now and just layed down a String Studio track.. so, let me test now..
hmm.. no.. sadly, it doesn't not seem to work... the option is there (right click a parameter in string studio and select "MIDI learn") but DP seems to break the functionality...
i'll have to poke around some more..
mike_o
Post by mike_o »
I've had problems making this work in DP, it's a badly needed enhancement. even when the controls do learn, they dont keep their assignments.
Tritonemusic
Post by Tritonemusic »
MIDI Learn has been around forever. Just search Google and you'll get all sorts of information about it.
tyronehowe
Post by tyronehowe »
James Steele wrote:I know it does this on the mixing board, but not plug-ins I guess. I have an AlphaTrack that I use for plug-ins sometimes.
Hi James
Have you tried your AlphaTrack in DP6? Is it working any better for plug-ins than it did in v5 please? Or do we still have the binary behaviour?
Tyrone Howe
DP 7.24, Mac Pro 8-core 2.26Ghz 32 GB (OSX 10.7.4)
Maybe we should combine this with the PT vs. DP thread? Will PT ever learn to do MIDI :)
kassonica
Post by kassonica »
MIDI Life Crisis wrote:Maybe we should combine this with the PT vs. DP thread? Will PT ever learn to do MIDI :)
:lol: :lol: :lol:
