how record the sound from Apple Software Synth
olivari
Post by olivari »
hello guys,
sorry the silly question.
I want to record the sound to an audio track from the MIDI Apple Software Synth. How can I do that?
Thanks.
Arcangel Castillo-Olivari
QuickSilver Dual 1 GHz G4 1.5 GB SDRAM OSX 4.5.1
DP 5.13, motu828, Motu Fastlane,
E-MU Virtuoso 2000
http://usuarios.lycos.es/olivari2007/
http://www.myspace.com/olivarimultimedia
aeon
Re: how record the sound from Apple Software Synth
Post by aeon »
Originally posted by Timeline:
Create an aux track and send the audio there via a send.
Record on the aux track
u can't record on aux track, what he has to do, is to freeze the selected audio apple synth track.
G5 dual 2.3 ghz,1.5 gig ram, osx tiger .4.4,DP4.6.1, UAD-1, Powercore Element,Auto-tune,NI, Logic pro 7.
MR Booth
Post by MR Booth »
I think that if you can hear the apple synth then you can record it. if you create a mono or stereo audio track to record to then on the input of that track specify whatever channel the softsynth is sending on - analog, spdf, sound manager etc etc - it should record. You may need to play the softsynth track in isolation from your other tracks and don't forget to only record on the new audio track.
Mike
H.-TheSaxGeorg
Post by H.-TheSaxGeorg »
Go to Project>Add Track>Instrument Track>Apple: DLS Music Device
Then put the output of your MIDI Tracks to DLS Music Device instead of Apple Software Synth. You will see, they sound exactly the same, cause they are the same (with different names).
Then select this new instrument track and your MIDI tracks and choose Audio>freeze selected tracks
I think this is the fastest way.
olivari
Post by olivari »
thanks Heinz for your advice, it worked out beautifuly. Mboo, I think like you but for any reason it doesn't work, thing that I do not understand.
Thanks anyway guys for your help.
E-MU Virtuoso 2000
Percy the Burp King
Post by Percy the Burp King »
It's too bad that the DLS Music Device doesn't show actual patch names like the Apple Soft Synth.
It helps to keep a GM chart handy to correlate the numbers with a name. :roll:
niken
Post by niken »
Where is the DLS music device located?
I just see Add multiple... or Unassigned under Instrument track?
Thx
Mac G5 OSX 10.5.8 Motu 2408 MK3, DP 4.61, BFD
Dfab020
Post by Dfab020 »
In set up > interapplication MIDI, you have to enable the software synthesizer.
--Bryan--
http://www.dfabstudios.com/" onclick="window.open(this.href);return false;
http://www.dfabmusic.com/" onclick="window.open(this.href);return false;
DARKMATTER
Post by DARKMATTER »
I'm going to jump on this thread, instead of startinbg a new one.... Hope no one minds?
I frequently trigger a loud, jarring, unwanted "SONIC BOOM" when selecting new DLS, soundfont patches, etc. Scares the hell out of me each time. I've grown rather superstitious, and have taken to muting my entire rig whenever adding instrument traks. :eek:
I'm still on 4.12 - is this a known bug? Sorry if this has been addressed in another thread. Had no idea how to perform a search on this one
Thx
Bobby
OS X.4.11/ DUAL 1GHZ G4/ 1536 RAM / DP 5.13 / MOTU 828mkII / EXPRESS XT / GLYPH 180 GIG /
XYZ
Post by XYZ »
Try this link to get DLS to have the names of the patch
http://www.ramp.pdx.edu/info/dp.html
MacPro2.66/3GB/828mk3/Rosetta800/UAD-2Quad/Waves/
christopherjhoh
Post by christopherjhoh »
Thanks, Arcangel and Percy. What you suggested worked fine and was simple. This still worked for me using DP 9 in 2020. I looked and looked elsewhere for the answer but only found it here! :D
chris hoh
