Thanks, any guidance on how to set this up as an insert with the 828mk3?
Adam
Send Outs on the 828 MK3
well i guess there are many ways, but i think that you might achieve that by routing any audio chanel from your daw software to a specific group (groups are possible in cubase sx, i dont really know about dp or other software) which can be assigned a phisical 828 stereo out. this out will feed the BBE's input or inputs, and come back to one of the 828 INS.
you will get some delay between the dry signal and the processed one, so its up to you on how you want to monitor that, either enable direct monitoring and you ll get near zero latency monitor from the 828 itself, or manage to monitor from your daw software.
i hope that makes sense
