time stamp
Julia Newmann
time stamp
Post by Julia Newmann »
How do you time stamp a stereo mix? I highlighted the file and then under audio, I picked, "Move to Original Time Stamp," "Move to User Time Stamp," and then I tried, "Set User Time Stamp from Sequence." None do anything. What am I doing wrong?
Thanks,
Julia
Radiogal
Post by Radiogal »
Just wanna say "Hi" to u DP sister :D
bralston
Re: time stamp
Post by bralston »
Julia Newmann wrote:How do you time stamp a stereo mix? I highlighted the file and then under audio, I picked, "Move to Original Time Stamp," "Move to User Time Stamp," and then I tried, "Set User Time Stamp from Sequence." None do anything. What am I doing wrong?
Thanks,
Julia
Time stamps are already created automatically in the creation of every new SDII audio file in DP. They are the "metadata" that is stored in the header of the Sound Designer 2 files. The Time stamping occurs when you create a new recording...not on import of existing files though. i.e, bouncing your tracks to disk in SDII format...or manually recording new audio tracks/files.
Take note that exporting aiff files or wav files do not keep the time stamps intact. Those formats to not support the metadata of the time stamping. Only SDII files.
So...If you are wanting to deliver time stamped files to the Pro Tools guy...you will need to give him the sound designer 2 files. Something that looks like "sterofile.L/R" They are actually 2 mono files, one for the left channel and one for the right. These are already created in DP and it is what DP (before version 6) uses natively. So just look in the audio folder for your session to find them.
FYI...for future compatibility with other DAWs like Pro Tools...DP version 6 now supports broadcast wave format which is the new industry standard and is what Pro Tools uses today as it native file format. broadcast wave (which is different than standard wave file)...also has time stamping info and the like in its metadata. It is one of the biggest reasons to eventually upgrade to DP6.
Regards,
Brian Ralston
___________________________________
- MacPro 7,1 3.2 GHz 16-core Intel Xeon W, 384GB 2933MHz DDR4 RAM, OS 10.15.7, 2TB SSD OS drive, 6TB Samsung Pro EVOPlus SSDs via Sonnet 4x4 M.2 PCIe card, Graphics card: AMD Radeon Pro Vega II 32GB, UAD-2 Quad, DP 10.13, DP 11.0,
- 15" MacBook Pro 2.3GHz 8‑core 9th‑generation Intel Core i9 processor, Turbo Boost to 4.8GHz, 32GB 2400MHz DDR4 mem, Radeon Pro Vega 20 w/4GB HBM2 mem, 2TB SSD storage, OS 10.15.7, 2TB SSD, DP 10.13
Eleventh Hour Sound
Re: time stamp
Post by Eleventh Hour Sound »
Thanks,
Julia
Hi Julia,
When you record something into DP, it automatically gets it's original time stamp. You don't have to do anything for that.
Now let's say you take something that was originally recorded between Bar 1 and 9.
Then you cut and paste that 8 Bars to Bar 21, then highlight it and say select user time stamp.
Now it's got 2 time stamps. The original; Bar 1-9. And the user time stamp Bar 21-29.
If you now select move to user time stamp. It's not going any way because it's already where you set your user time stamp, but it you select move to original time stamp, it will go back to bar 1 where it came from.
Say Hi to LA for me I miss it, (well Santa Monica and the Ocean anyway:)
Vincent
DP11.1, 16" MacBookPro 2.3Ghz 8 Core i9's 32GB Ram 1TB SSD, (2) external 1TB Samsung SSD's , Steven Slate SSD 5.5 and Trigger Drums, ML-1 Mic and VSX Headphones, Omnisphere 2, Trilian, Ivory2, EW, MSI, MX-4, Philharmonik 2, Komplete, Reason, Live, Melodyne, IK Multi's Total Studio, ARC, T-RackS, SampleTron, AMG's KickA--Brass. and my beloved guitars :-)
digitalolive
Post by digitalolive »
Slightly OT but I went to an Audio Forensics lecture at AES in New York where a guy was telling us about a way they've developed to "time stamp" almost any recording. Seems it has to do with fluctuations in the power grid (i.e., 60 hz is not exactly 60 hz but fluctuates a bit. They have these fluctuations mapped out all over the world and can for instance tell not only when but where a recording was generated by plotting the fluctuation in the 60 (or 50 overseas) hz hum. Pretty neat, huh?
Steve
Mac Pro Quad 2.66, 5 gig RAM, OSX 10.5.4, MOTU DP6, Altiverb 6.06, Peak Pro 6.01XT, MOTU 828mk2, True Systems Precision 8, DAV Broadhurst Gardens No. 8, Line6 UX2, Neumann, Schoeps, Sennheiser, AKG mics, Dynaudio BM5a monitors, DA-78 x 2
