OT: Powered Near-fields
dmshep
Post by dmshep »
The studio from which I'm currently working has a larger mix room that is not fully dampened. It's equipped with a pair of TOA monitors that are reasonably decent, but set into a wall 11-12 ft from the mix position. Given that the room isn't as dead as it should be, I'm not able to hear with the accuracy I would like, particularily with the low end and setting reverb levels.
I've covered a large portion of the tile(!) floor (I don't what the guy was thinking when he built this place) with dampening, which helps, but the speakers are still too far away, so I'm looking at getting some near-field monitors to try and overcome that.
Any reccomendations? I'm looking at powered as the studio only has one amp which is hooked to the TOA's. I don't have a lot of money to spend, though I recognize that you get what you pay for. Is there anything of decent value in the $800-1000 range?
dmshep
Re: OT: Powered Near-fields
Post by dmshep »
Sorry! I didn't see the recording forum where this should be. Admins - feel free to delete this. I'll repost it over there.
Timeline
Post by Timeline »
It really depends on the shape of the room.
I used 6" fiberglass batting behind frames covered with duvateen and it looks good and solves the reflection issues. As foar as monitors, the larger the room the more power you need in the monitor.
The room I built in Burbank required two BGW 750's ... one on each pair of woofers and a BGW 750 on the top end. It was biamped.
Good luck.
JES
Post by JES »
I got a used pair of Mackie HR-824s for $800. Some people love them, some people hate them. I love them. With some realtraps in my room, I can hear everything clearly and they've got lots of low end to keep me from overdoing it down there.
Best,
--JES
aaronlyon
Post by aaronlyon »
I love my Mackie HR824s, too! I'm listening now to Roger Waters howl on Pros and Cons of Hitchhiking. Sweet recording, man.
DP7*, Mac Pro Quad 2.66GHz, 12GB RAM, MOTU 828mk3, Mac OS 10.6*
* Bleeding edge updater--if it's released, I've updated, and bled.
inukshuk
Post by inukshuk »
Check out the Tannoy 600a's. Very good for tracking, mixing and mastering.
Dual G4, 1.42GHZ, 2,048 ram, 3-74gb Raptors, 1-250gb Caviar, OS X Tiger 10.4.5, D.P. 4.61, HUI, Tannoy 600a's, UAD-1,Fairchild, Pultec-Pro, tc PowerCore firewire, Restoration Suite, MD3, VSS3, Inflator, Voice Modeler, Assimilator, Auto-Tune4, PowerCouple, PSP MasterQ, Vintage Warmer, MixPack, Blue Tubes Bundle, BFD, motu 896 HD.
http://www.inukshukproductions.ca/mastering
laurence
Post by laurence »
Another HR 824 Lover here.. i find they always translate for me well as i am completely used to them and like the fact they aren't totally transparent.. To my ears they are very similar to Genelec A30's ? whichever model it is with 8in drivers anyway.. except sweepeing EQ filters on the genelecs is smooth throughout the spectrum where the Mackies do have a small spot where it's not perfectly accurate (forget the frequency but it's a small range).. either way the Mackie's are unbeatable for me !
DP 7.12 ~ G5 dual 2.3 / Mac Pro Quad 3/Genelec ~ ProTools HD 7.4 / 8 with 96 i/o's / MOTU 2408 Mk 3 + 1224
Kind Of Loud
Post by Kind Of Loud »
HR824's....I love'em!
daveyboy
Post by daveyboy »
Another vote for Mackies and RealTraps. Didn't really like the Mackies until I treated my room with Real Traps. Now it's all good.
Dave
www.dbwproductions.com
Henry Robinett
Post by Henry Robinett »
I'll give you something different. Although it's not in your price range. Not well known I suppose. I use the NHT Pro M-00 and the sub S-00. Awesome. I couldn't be happier. I used to also use the Genelec 1031s and much prefer these.
All the best,
Henry Robinett
2019 Mac Pro 16 core, 192 GB; 2 MacPro 5,1 Metric Halo ULN-8 3d (x6), ULN-2-3d, MIDI Express XT,
DP10.13, UAD2 Quad TB,Duo,solo, Fractal Ax Fx III, FM3, LF+12+, Altiverb 7, Pianoteq7, Falcon, Keyscape, Omnisphere, Kontakt 5, Superior Drummer 3, Slate Drums, Live 10, Battery4, Diva, Spitfire Chamber and Symphony Strings, Ivory 2, Spectrafoo, Millennia HV3-D, many mics, many guitars . . ..
aboutfaceaudio
Post by aboutfaceaudio »
I guess it's a matter of taste...I have a room that's treated with fibreglass from the front all the way until just behind the mix position. Behind me I diffuse a bit with some open space here and there.
I chose the Mackie 824s. I pitted them against the Genelecs and didn't like anything by them under $3k.
My 0.02£
Henry Robinett
No I'm not a fan of Genelecs either. I've just used them a lot. I never would have bought them and I didn't. I was an engineer at a studio that had 5 monitors set up. Genelec 1031s, NS10s, KRK, NHTPros and Auratones. Mixing I'd cycle through them all getting the mix to sound good on all of them. A good exercise. I kept settling on the NHTPros. They blew me away till I finally just mixed on those and checked every once in a while on the NS10/KRKs. Then I just decided to buy them
All the best,
Henry Robinett
tim57var
Post by tim57var »
Believe it or not, i still use the original Event 20/20 powered monitors with a JBL sub. I have them about 5' from my ears. The newer model has more bass response than the originals. I used to have these and Genelecs, and I always liked working on the Events more - I got more energy out of the speakers for performing. I get no complaints from clients on my mixes and have lots of commercials running on the air. I've often thought of upgrading to something - I can afford to spend more $$ on speakers - but nothing else has blown me away.
MacPro 8 core/DP 5.12/Mach5v2/HD192/24io/(2)2408 Mk3/(2)MTP AV/UAD-1/Powercore/Spectrasonics/NI Komplete/BFD/Ivory/Arturia/Plugsound Pro/Dimension Pro/Nord Stage88/Gigastudio/V-Stack/MacBook Pro
sdemott
Post by sdemott »
I must agree - I have the 20/20bas also (first generation). I love them. I actually chose them over a pair of similar Genelecs. I just think the Genelecs are funky up top...but I seem to be in the minority on that.
To my ears the Events are great...and my mixes seem to translate very well - I find that if they sound good on my Events, they just sound good everywhere.
Just my $0.02
-Steve
Not all who wander are lost.
donreynolds
Post by donreynolds »
I have the Event 20/20 bas originals. Very nice. I agree, If the mix sounds good on them, it usually sounds good every where.
God bless,
Mac Studio M2 OS 15.3 Sequioa, Presonus Faderport 8, 150gig Raptor x 2, Glyph 2Tb drive DP 11.33, Antelope Discrete 8, BLA microclock ll, Presonus Central Station, Waves Plat. V7 , Slate Everything, Melodyne studio, SSD 5, TruePianos, Event 20/20 bas, Adam A7, Avantone Active MixCube, and other toys, Lotsa guitars, HeadRush GTR processor and a Korg Triton)
