Not only did you get down to specifics, but you opened wider the door of constructive dialog between MOTU and its customers.
This Hobbit journey may not make the big screen, but it may help spawn many more excellent soundtracks.
The suspense is killing me. Could you finish that sentence, pretty please. I've been hesitant to try this for fear of screwing something up. Does MOTU sanction this as a viable workaround?Frodo wrote:12. MAS/AU wrapper still reporting problems. fix?
Different things, including third-party plugs, can impact on MAS/AU bundle behavior. Reports from users, including any resulting crash reports, will contribute to a worthy fix. But it seems that the workaround of swapping the MAS/AU bundle
Now that's what I'm talking about. I wonder in what significant ways "Leaner, meaner code" makes 6 a great upgrade?Leaner, meaner code
It might mean that the code is so hot that is burned away the GUI!bradswan wrote:Now that's what I'm talking about. I wonder in what significant ways "Leaner, meaner code" makes 6 a great upgrade?Leaner, meaner code
Boo, hiss.Frodo wrote:28. Eucon, Novation, surface controller support status
No word yet.
LOL and Oops my face off!!Phil O wrote:Thank you so much, Mr. Frodo, for that wonderful report. Your generous contributions to the board are greatly appreciated.
But if I may be so bold, one quick question:The suspense is killing me. Could you finish that sentence, pretty please. I've been hesitant to try this for fear of screwing something up. Does MOTU sanction this as a viable workaround?Frodo wrote:12. MAS/AU wrapper still reporting problems. fix?
Again - thank you, thank you, thank you.
-PO
You guys talking about the MAS AudioUnit Support.bundle .Frodo wrote: Hey Phil-- I can't promise a grand slam, but I do promise to find the thread where other users were talking about the MAS/AU Support bundle to find the specific name of the file that they swapped for the version used by DP5.
Sorry about the truncation!
Sorrry Frodo, I just realized that it seems like I was "sighing" at you for not having read my other reports. I actually meant "sigh" at MOTU for saying they've not been able to reproduce the problem when I sent them a detailed techlink one year ago, to which they've replied "resolved" not once, but twice in the course of the last several months. Yet the bugs are still there in DP 6.Frodo wrote:I've been going on power naps for the past couple of days, and I really hope your other post wasn't something I saw and responded to but had forgotten in just a few days. How embarrassing would that be?nadeama wrote: Sigh.... For what it's worth, I've reported it in another thread on the first day I got my copy of DP 6 and well, I guess I'm reporting it again here today. Not only volume burst but also MIDI bombs and all the other MIDI bugs often discussed in the past.Certainly, bursts would be of particular bad news to me because that's what was happening to me for most of 2007. Hmm.
I'm currently working on a very simple project for an intimate film score, only 4 or 5 MIDI tracks per sequence, almost no controller data, no VIs loaded; everything is sent via MIDI to my external slave computers. Yet, I'm experiencing occasional volume outbursts (no MIDI bombs or other oddity on that one, though). This wouldn't be a good test sequence to send to MOTU because the problems happen too sporadically, but it does happen. It really has nothing to do with VIs (unless, as I said, there is a different problem with VIs that happens to have the same apparent symptoms - that's certainly possible).Now, if that doesn't snatch all the hind fur off a wolverine!!!! I'd not heard of this happening with OTB MIDI devices. I tested this on some outboard MIDI gear and it didn't happen for me-- only on VI tracks. There's something else afoot going on here, then. This is SO odd!!nadeama wrote: And this has nothing to do with VIs. The volume outbursts happen all the time when sending MIDI to external hardware, with no VI loaded. I've explained this in detail in my tech link to them. I don't understand why they say the workaround has to do with VIs. Unless of course it's two different problems with the same symptoms.
Yes, I actually started a couple of such threads last year. I was reading them again a few days ago, because I wanted to refresh my memory as to what tests I had actually run last year. Well, I did run quite a few tests! In fact, I'm planning on running one last set of tests within the next few days before making my final decision to switch DAW, but now, re-reading the threads, I honestly can't think of anything that I hadn't tried last year. And of course, DP 5.13 didn't fix anything for me. It's too early to tell if DP 6 will display all the same problems, but I've certainly experienced the MIDI volume outbursts already.I don't know if you've seen all the long threads on volume and MIDI bursts with DP5, but none of them were conclusive, and a number of us were running tests of all sorts. DP 5.13 and 10.4.11 seemed to reduce this quirk almost entirely-- maybe 95-97%. I think that's when we all sort of gave up talking about it and started waiting for DP6. I'm totally befuddled.
Here's my own personal plan: within the next few days, I'll again run as many tests as I can to try and find out what's going on. Hopefully, I may have better luck this time and figure out that some non-DP-related element in my system is causing all this. I'll probably even start a thread here asking for help. If I can't find anything, I'll call MOTU up and offer them to go over there with my computer and show them the problem. I live 5 hours away, but I'm ready to make the trip in-between gigs. Last year, I had asked them to pay the shipping fees, but this year I'll offer to go myself. If they decline, I'll have no choice but to conclude that they have absolutely no interest in getting to the bottom of this issue (which is not affecting only myself), and I'll switch to another DAW. Crossing my fingers...All I can say is keep reporting the issue and keep reporting back with your results. Once again, until I get going with DP6 on my system and dig into it, I can't even test or confirm anything. Am feeling quite helpless at the moment.
I think if I experience the volume bursts, I may have to just run a video camera during a session one day since the bursts are too unpredictable to reproduce. Then, I can send MOTU a DVD just to make sure they've seen it happening even if they can't make it happen on their own systems. The video may be the best way of "sending them your computer".
Right you are-- and they've been there for a very long time.carrythebanner wrote:RSS feeds are already there:Frodo wrote:26. white papers, more frequent RSS updates with software releases and announcements, reports of official bugs, bug fixes, better organized tech data base
RSS feeds, especially when new updates are posted. Would be a step in the right direction to keeping users posted.... and it's a wasted resource where tech links, e-mail, and phone calls could be freed up for more urgent needs
http://www.motu.com/other/rss-feeds
That's good to know and I'm glad it's in the manual! Thanks for posting that. It's strange that Ethno and Mach5 MAS versions (and unknown others?) currently do not support offline BTD where the AU versions must be used. At least we now know that we haven't done something wrong when certain instruments won't BTD where expected.carrythebanner wrote: All od DP's included instruments support bounce to disk, it's in the manual.
