Hi all,
I have an instrument track in my mix and when I bounce the mix the instrument track isnt there. What am I doing wrong? I looked in the manual and couldn't find anything. I tried sending the output of the instrument track to a bus pair and opening a separate audio track with the inputs set to that bus pair, but nothing came up. I'm using DP 4.6. Thanks for your help.
Brandon
Instrument track not bouncing...
Re: Instrument track not bouncing...
i would check out the usual suspects first.
enough voices.
make sure your output is the same one you have everything else assigned to.
make sure no two tracks have the same voice assigned.
FM
FM holds the world record for the most lies ever told.
enough voices.
FM
Hello,
Bouncing doesn't include Instrument tracks. You'll need to "Freeze" these tracks as audio first or manually bus the Instrument track outputs to a new audio track.
Cheers
Cheers
I tried sending the output of the instrument track to a bus pair and then created an audio track with the input set as that same bus pair. But still nothing. What am I doing wrong? Thanks for the help.
Brandon
Brandon
Check your Input Monitoring Mode...Is Monitor record-enabled tracks through effects selected?
