OGG is a container format, and the compression used with OGG can be either lossy or lossless.bongo_x wrote:What they said.
Lossless is just that, lossless, so it should sound the same. I didn't know they used m4a as a suffix, that's weird. MP3, AAC, OGG, etc, are lossy formats, they get rid of information that you can never get back when they are encoded, hence they are smaller.
I have seen no double blind or abx tests that shows LAME to be any better than Fraunhofer/Thomson's FhG codec or mp3sencoder.kassonica wrote:And don't forget to Rip them with LAME.
There is NO better codec out there, period.
Thanks, I never understood that. I thought OGG was just short for OGG-Vorbis (which is certainly not a catchy name unless you run a comic book store or host RPG's in your parents basement).arth wrote: OGG is a container format, and the compression used with OGG can be either lossy or lossless.
OGG-Flac is an example of lossless OGG, while OGG-Vorbis is an example of lossy OGG.
It can be confusing. Much like AIFF, which can refer to both uncompressed audio as well as compressed (which is better called AIFC, but Apple disagrees...).bongo_x wrote:Thanks, I never understood that. I thought OGG was just short for OGG-Vorbis (which is certainly not a catchy name unless you run a comic book store or host RPG's in your parents basement).arth wrote: OGG is a container format, and the compression used with OGG can be either lossy or lossless.
The difference between codecs is more noticeable at lower bitrates, and using VBR. With higher bitrates (256 and 320kbps) the original audio file and the mp3 become very hard to distinguish from each other, and the codecs as well.arth wrote:I have seen no double blind or abx tests that shows LAME to be any better than Fraunhofer/Thomson's FhG codec or mp3sencoder.kassonica wrote:And don't forget to Rip them with LAME.
The only test I've seen where LAME "beat" Fraunhofer was one where a new LAME was tested against a four years old FhG codec, using 128 kbps VBR, and the average bitrate was higher on the LAME samples. LAME came out slightly ahead, but with a ~6% higher bitrate and testing against a very old FhG codec, that's not surprising.
Anyhow, I much prefer FLAC as my codec -- lossless is better than MP3. Period.
Veritable bitrates give me the jitters.chamelion wrote:Dang! This thread has become a veritable fountain of information! Thanks guys.
Cheers,
Geoff
At least no sharp ones Metaphorical Monkster.monkey man wrote:Sorry I can't deliver here Geoff.chamelion wrote:... This forum's all about sharing information and expertise, and you guys have delivered in spades.
I have no garden tools to speak of.
