DP6 GUI Can Be Customized
billf
Post by billf »
It takes some time and some patience, but you can customize your DP6 GUI. Here's a screen shot of what I've done so far. I modified the mixer to have a darker look and also the background space next to it is no longer white, but a light gray. To do this you have to make some changes to both the appropriate image files and the XML file Default_Style.xml
I am continuing to tweak this and will post my final results when done. However, for those who find the GUI "too bright" there is hope. As for bugs, sorry, I can't fix those. :wink:
mike_o
Post by mike_o »
I can edit graphics no problem, don't know how to change a .xml though, never tested those waters, a little more in depth instructions please, I dont have 6 yet, but I'm saving :x
Mac Pro 2X Dual Core 2.66Ghz-10.4.9-7 GigRam-828MKII-MTPAV-Ultralight MK3-Digi Performer6.01-PeakPro5.1-Reason4-AbeltonLive6-Virus Rack(Red)-ReMOTE 25 & 37 SL-Nocturn-Stanton Dacratch-PluggoPack-DimensionLE W/EmuProteusPack-Sylenth1-Discovery MAC-MX4-Rapture-Alpha-Octopuss-Automat-Automat1-TALbassline-TALUno60
billf
Post by billf »
If you haven't dealt with XML before, be careful!
The XML file is in the folder English.lproj
Look for the area <!-- Default Colors --> and change the RGB numbers where you like, there are about 30 lines that can be modded. Make sure you save a copy of the original file just in case you mess up and I recommend you don't go editing areas if you don't know what they refer to.
wurliuchi
Post by wurliuchi »
What did you open the XML file with?
Tritonemusic
Post by Tritonemusic »
This is very encouraging, billf.
Too bad we can't change the 2D back to 3D, as it was in DP5.
Can the blue meters be changed to green? I won't hold my breath on that one.
Nonetheless, I appreciate your effort and it gives me hope.
billf
Post by billf »
666 wrote:This is very encouraging, billf.
I think so. I haven't tried it yet, but these three are the likely culprits:
<TEXT name="kMeterActiveColor">107:159:253</TEXT>
<TEXT name="kMeterBackgroundColor">28:28:85</TEXT>
<TEXT name="kMeterPeakHoldColor">255:212:55</TEXT>
billf
Post by billf »
wurliuchi wrote:What did you open the XML file with?
Use TextEdit. Be sure to save the resulting file with a .xml suffix instead of the default .txt
Simple enough. My guess is that those numbers are simply RGB values. Figure out what meter background color you might want in photoshop, the use the color picker to see the RGB values and plug those in between the colons. RRR:GGG:BBB
That's my guess anyway... haven't tried it myself.
bkshepard
Post by bkshepard »
Obviously, the lines that look like: <TEXT name="kMeterPeakHoldColor">255:212:55</TEXT> refer to RGB values.
What is it referring to when there is only one color number like: <TEXT name="kMeterFrameColor">20</TEXT>?
-Brian
Mac M1 Ultra 20-core, OS 14.6.1, 128 GB RAM, DP 11.3.2, UA Apollo x6
gearboy
Post by gearboy »
This seems like a simple process and good news relating to this issue, specifically the white background color. I personally don't have a problem with anything except the background color, as I can see how white will be tired on the eyes. when I finally get around to picking up DP6 I'll be sure to follow your instructions.
thanks for posting this!
Jeff
OS 10.4.11 - G5 Dual 1.8GHz, 3GB RAM / Mac PB G4 1.5GHz, 1.5GB RAM / Apogee Duet / MOTU 828mkii w/BLA Analog & Clock mod / MOTU DP4.61 / Live5.2 / Peak 4 & 5 LE / Izotope Oz3, Sp, Tr / Waves Ren Max / TRacks, Miroslav / NI Komplete 5 / GF impOSCar, MiniMonsta, M-Tron / Automat / Nomad Factory Vintage Studio Bundle / apTrigga / Audio Hijack Pro
My recording blog: http://www.ipressrecord.com
billf
Post by billf »
Those are RGB numbers. Enter your preferences in place of the numbers there, and try it out. 8)
billf
Post by billf »
bkshepard wrote:Obviously, the lines that look like: <TEXT name="kMeterPeakHoldColor">255:212:55</TEXT> refer to RGB values.
You can replace that with an RGB entry.
bkshepard
Post by bkshepard »
Cool! Out of curiosity, though, do you know if that is a grayscale number or something like that?
-Brian
RCory
Post by RCory »
Seems "simple" enough, but MOTU could add a preference for this.
quincyg
Post by quincyg »
yep,
seems like someone could create some skins in a couple of hours. i am going to try this. the colors of a daw really impact my mood when working, strangely enough.
