It doesn't copy the conductor tracks for a reason. First of all, you can copy the conductor tracks any time you're ready--it's a menu selection. But it doesn't do it automatically, because it can't guess which ones you want to copy. Because you can stack chunks so that they overlap in as many layers as you want, it's quite obvious that you would have a conductor track conflict on your hands very quickly. So, you select the chunks you want to lead the tempo, then copy those conductor tracks.Originally posted by garys:
But I find the Song part of DP incredibly clunky compared to Vision - when you drag a chunk to the song it doesn't even copy the Conductor track across - and sometimes with Virtual Intruments like Reason, playing back a song you either don't hear the sounds, or the balance is too loud. It seems to be something to do with Aux tracks.
I can't address your second problem, as I don't use virtual instruments much at this point (though I plan to), and haven't experienced that as a problem. I'm guessing it's nothing you can't fix with careful settings of levels beforehand... but I can't say for sure, of course.
Anyway, the conductor track thing is a non-issue. It's a feature, not a bug, because it has to be up to the user to determine how to do it. And once you make those decisions, it's easy to do it.
PS: GaryS, I'm not positive that the chaining feature works without a pause. I'm not in a position to test it at the moment, but I normally use the "Cue" feature, so that it stops the previous chunk, cues up the next one and waits for me to hit "play." But, if there was a gap, first check to see if you have set the end time for the previous sequence. That's done in the Chunks window meni-menu. Set "Auto-Manual End Time" for the moment that you want that sequence to end. That may fix the lag if there is one. If not, then I apologize... but I thought it played through without a pause.
Oh well, you can always do it by putting them in a Song and copying the conductor tracks.
<small>[ July 22, 2005, 10:34 AM: Message edited by: Shooshie ]</small>
