MOTU 24 io with Vista - Having to always reinstall driver
musicmad
Post by musicmad »
I have the 24 io running fine with Vista but the only problem is that I need to re-install the driver every time I run the PC.
Has anyone else run into this problem?
Is there a cure?
billruys
Post by billruys »
I don't have to continually re-install the driver, but I do find that if the rack unit is switched on before the computer is booted, the driver often fails to find the rack unit.
For whatever reason, I find that if I only switch on the rack unit after the OS has booted, it always works. This is with Vista x64.
I think the drivers are still a bit flaky under Vista, but MOTU don't seem to update their drivers for the PCIX/PCIe stuff very often.
