Problem with racing fans
gavspen
Post by gavspen »
The fans on my G5 dual 2.5 have always seemed to race at odd times, when the machine isnt doing much of anything. The logic board and processor have been replaced to no effect, but now something new. As soon as I press the start button the fans race at top speed and wont stop. I mean, it's alarming the noise they make, and it obviously doesnt have anything to do with overheating, since it starts immediately.
It happens 19 times out of 20, (this morning I cant get it to stop at all) and I can find no pattern. I've tried 3 different system disks (internal, external, CD), since when the hardware replacements didnt solve anything a software problem seemed a possible culprit , unplugged all peripherals including monitors (I still have cards inside though) and presumably the ram was checked when the other hardware was replaced.
It happens even when holding down "Option" on start up, in other words even before a start up disk has been chosen. Wouldnt that eliminate the possibility of a software problem, since it hasnt even looked at a system at that point?
I'm running 10.4.11, except from the CD which is a Tiger install disk, the cards still inside are a powercore and a UAD. I cant think of anything that's changed for quite some time, and the problem is brand new.
It sounds like a hair dryer.....I GOTTA TURN IT OFF!! Any ideas?
Gavin
bkshepard
Post by bkshepard »
Hey Gavin,
There's been a lot of talk about that over at MacFixit. You might do some nosing around there and see what you find. Good luck.
-Brian
Mac M1 Ultra 20-core, OS 15.5, 128 GB RAM, DP 11.3.4, UA Apollo x6
toofar
Post by toofar »
Hmm, I thought this was going to be a tirade about the freeways after a NASCAR event.
Sorry about your troubles, though. Wish I could help you. :(
DP 11.32 | iMac 3.2GHz 6-core i7 & Monterey | Audient iD44 | FaderPort2 | MIDI Express XT | G4 dual 1 ghz MDD & Tiger | 2408 mk3 (x2) | A-500 PRO | Rosetta 200 | Toft ATC-2 | Mackie VLZ3 | JBLs | DP 4.6 | Live | 'n stuff
gavspen
Post by gavspen »
toofar wrote:Hmm, I thought this was going to be a tirade about the freeways after a NASCAR event.
I figured it wouldnt be long before someone chimed in with "I dont know what you mean, I was at the Belmont, and everyone was very well behaved", or words to that effect. :wink:
Now enough with the jokes, SOMEBODY HELP ME!! I'm going to turn on the vacuum cleaner just to mask the noise!!! :shock:
I'll check macfixit, thanks
Gavin
gavspen
Post by gavspen »
Macfixit wants me to buy a subscription to read the relevant articles, something I'm not inclined to do, but the little bit they do let you read says that some noticed a problem after installing 10.4.7. I'm using 10.4.11, and as I mentioned the problem starts immediately, before the thing even knows which system I'm going to boot to....I think, right?.... Idont really know what I'm talking about.
Gavin
Try re-setting NVRAM/PRAM. See the sticky in this forum.
robstudio
Post by robstudio »
Hey Gavin,
sounds like logical thinking to me... the other thing you could try is booting into target mode... press T when starting... That shouldn't load any software either... just to see... being you've tried the os cd and had the same result I'm thinking hardware related for sure... you haven't upgraded firmware recently??? Not even sure of the status of that on a G5, that's the only other thing I can think of... wait a minute... unless the firmware has become corrupted ... try resetting the pmu ..or pram whichever... sorry, SMU... oh hey check this out....
Restart while holding Option-Apple-P-R. You will hear the startup chime. Continue to hold the same 4 keys until you hear the chime 2 more times. and release keys to boot normally.
This process should bring your fans back under control.
from the link....
http://forums.macosxhints.com/archive/i ... 47992.html
See if that doesn't help...
Regards, Rob
Edited to add...
I believe I picked that up from Frodo! (Thanks!)... sorry for stream of thought post... took me a second to remember!!
PSS... I clicked on the link thinking... hey bud, what's your problem.. I'm a racing fan!!!
PSSS... what cuttime said ;)...
Mac Pro 2x2.66GHz, 3 GB Ram, OS10.4.11 (not using 10.5), DP5.13, 2408mKIII, 2408mKII, 328 Digital Console (x2), FostexD2424, Micro Lite, QSR, SPX90, URS, PSP, Altiverb, Alphatrack, Shuttle
chucks
Post by chucks »
Reset the SMU - instructions here:
http://support.apple.com/kb/HT1436?viewlocale=en_US
gavspen
Post by gavspen »
Thanks fellas I'll try all that stuff tomorrow. Right now I'm off to consume half a cow and a bathtub full of booze.
Happy 4th
Gavin
gavspen
Post by gavspen »
Yipee!
Although it didnt "take" the first time, the second time I zapped the pram it seems to have done the trick. The fans are now behaving as usual, which is to say they only race sometimes, not ALL the time. I wish they would calm down in general but no one seems to know what to do about that.
I also did the SMU thing, just for laughs (which in my machine is labeled PMU, somewhat disconcertingly since somewhere in those links it says that Apple has retired that term), and so far through several restarts it's all holding up.
Thanks all. If it's get weird again I'll be sure to let you know :wink:
Gavin
gavspen wrote:Yipee!
Gavin
Why? Perhaps the PRAM reset your Energy Saver Preferences to have the processor run at AUTOMATIC instead of HIGHEST?
Sys Pref>Energy Saver>Options
If you leave the setting on highest, the processor will heat up and the fans are cooling it. If you leave it at automatic, it should keep the fans at a reasonable level.
gavspen
Post by gavspen »
Just restarted and the problem came back. Zapped pram again, problem went away. I guess I can zap the pram every day for the rest of my life...sigh.
Any more thoughts?
By the way MLC, zapping the pram did not reset Energy Saver Preferences to highest, it stayed at automatic.
bkshepard
Post by bkshepard »
If zapping PRAM each time fixes it, perhaps the battery is dead. Are you seeing things like the date and time not being correct, or other settings not "sticking" when you reboot?
-Brian
gavspen
Post by gavspen »
bkshepard wrote:If zapping PRAM each time fixes it, perhaps the battery is dead. Are you seeing things like the date and time not being correct, or other settings not "sticking" when you reboot?
Good thought, but no, everything else appears normal.
bkshepard
Post by bkshepard »
Try this and see if it works.
1. Open the Energy Saver Preferences and set the processor to something other than "Automatic."
2. Close the Preference pane.
3. Reopen the Preference pane and set the processor back to Automatic.
4. Close the pane and reboot the computer.
-Brian
