hi i have a problem
lordzool
hi i have a problem
Post by lordzool »
ok so i ordered this computer from musicxpc
http://www.music123.com/MusicXPC-Profes ... 9.Music123
with a motu 828 mk3
and at first it crashed a bunch when installing then it wouldnt work at all it kept saying that it wasnt working properly then i got past that and now cuemix wont open up but i can get the audio console working but it goes slowly and now im going sorta crazy can any one help me
thanks
lordzool
Post by lordzool »
ok i have installed and reinstalled the softeware this doesnt seem to make of a difference in fact everytime i do this it just gets worse and worse
i had heard that certin motherboards would work with the 828 is this true and if so which ones
i put in the update but it keeps asking me to install new drivers from windows
please any help would be awsome
lordzool
Post by lordzool »
ok so when i try to open cuemix i get
no motu audio devices detected
or
c:\program files\motu\audio\cuemixfx.exe this application has failed to start because the application configuration is incorrect reinstalling the application may fix this problem
then there is the audio console
no motu audio device could be found make sure your motu audio device is connected powered on and the drivers are installed
i have tried every combo of not installing the drivers that windows wants me to install to installing them i cant figure this out
please help
emanman
Post by emanman »
I can tell you that pc should handle the MOTU fine, as I just built one for myself last month. It looks like its built off the Shuttle SD32G2 which is what I have, and that motherboard works great for me. All I can suggest is either you have a bad firewire cable, or you have some driver conflict which might benefit from a fresh install of windows. Good luck!
p.s. if you go to newegg.com you can built a higher spec'ed machine for half price of what you paid thru Music123
lordzool
Post by lordzool »
yeah im talking motu right now so hopefully itll work out
lordzool
Post by lordzool »
ok now i got sound but cuemix wont come up or audition they just seem to freeze at the start sceens any ideas
lordzool
Post by lordzool »
ok i got it it was the firmware update
