Exporting to Logic??
lumisuto
Post by lumisuto »
Hi!
I'm having trouble exporting files to open in Logic Pro 8 in omf. The document can be opened but even after I input the correct tempo all the audio regions get in the wrong position except the ones starting at zero. I'm also getting stereo tracks as two mono tracks but I suppose that could be normal with omf. What could be the problem here? What are the right settings to export the document?
Yiannis
Post by Yiannis »
I had the same problem with Logic.
Here is what works for me:
1) make sure you have enable omf Logic compatibility when you export from DP.
2) open a new file in Logic.
3) set the correct sample rate
4) set the correct bpm
5) now import the omf file to Logic.
Everything should be ok.
hope it helps :wink:
Mr_Clifford
Re: Exporting to Logic??
Post by Mr_Clifford »
lumisuto wrote:..after I input the correct tempo all the audio regions get in the wrong position except the ones starting at zero.
I suspect that's because the audio is put in the 'right' place before you set the tempo, and then they move with the tempo change (as you would expect) - can you 'lock' tracks to timecode position in Logic? That would be the only way to stop them from moving after a tempo change.
Mono tracks is normal with OMF. Doesn't sound like you're doing anything in the export process. It's a pity that OMF doesn't allow for tempo maps to be included.
lumisuto
Post by lumisuto »
Ohhh I'll try that! I'll let you know if it works for me!
Thanks Yiannis!!
:D
