Thats why I'm getting a refurb...mhschmieder wrote: Of course, this becomes a challenge if buying a new computer with Leopard pre-installed... .
T
http://www.motu.com/products/software/d ... pport.htmlzed wrote:I wish I could run some RTAS plugs within DP. This hasn't changed, has it?TheHopiWay wrote:If the RTAS works as advertised it's goodbye to about 2k of gear and I'll run DP on my PTHD rig.
Im thinkin about selling my g5zed wrote:What on earth are you holding out for!?!?! Treat yourself to a new computer and a decent LCD monitor... even a second-hand G5 will make a world of difference.mhschmieder wrote:Too bad I can't upgrade. But I'll recheck the DP 5 reqs, because they might have been the same, and I have no trouble at all running DP5 (in fact, less than with DP4).
You are seriously short-changing yourself. Composing will be MUCH more enjoyable if you upgrade your setup. One day you will ask "What was I thinking?" and "Why did I go without this for so long?"
It's just you.larryf wrote:Is it just me, or does $195 seem excessive for a version upgrade?
THat is NOT the way to increase you post count, Richard. DO what Monkey Man does... then again, DON'T. Repeated post are preferable...richardein wrote:Now, this may be old news but still it is very nice:
" DP6 now pre-renders instrument track output before playback actually begins, allowing the computer's CPU to distribute the required processing beforehand, rather than in real time."
Dude, that's been like OUT for months. Maybe years now...Jim wrote:I'm skipping the upgrade, and just ordering the PDF manual.
Yes!Improved OMF/AAF importDP6's expanded audio file support means that a wider variety of OMF and AAF files can be imported without converting the audio.
