mhschmieder wrote:Too bad I can't upgrade. But I'll recheck the DP 5 reqs, because they might have been the same, and I have no trouble at all running DP5 (in fact, less than with DP4).
What on earth are you holding out for!?!?! Treat yourself to a new computer and a decent LCD monitor... even a second-hand G5 will make a world of difference.
You are seriously short-changing yourself. Composing will be MUCH more enjoyable if you upgrade your setup. One day you will ask "What was I thinking?" and "Why did I go without this for so long?"
I'm aware of that, but Apple threw a spanner into the works last autumn when they swapped out the stable TI Firewire chip with a non-working Aguire chip that renders almost anything except the MacPro useless for multi-channel audio.
I've had the money in savings for quite awhile, but am holding out for the next updates, which I thought would happen last week ad WWDC, to see whether I'm better off with a top-end MacBook Pro or can take the risk on a 24" iMac with FW audio interfaces routed in daisy-chain fashion through an external hard drive (the recommended workaround for the Aguire Firewire chip flaw). A MacPro is overkill and requires a lot more saving-up.
This is OT at this point, so my apologies.
I am curious though whether I would have to first install DP 5 on a new computer before installing a DP 6 upgrade. As MOTU allows two installations (same user, of course), I don't recall if the initial authorisation is done via the internet with one's account information and serial number, or via some encrypted files on the hard disc (from previous versions).
Mac Studio 2025 14-Core Apple M4 Max (36 GB RAM), OSX 15.5, MOTU DP 11.34, SpectraLayers 11 RME Babyface Pro FS, Radial JDV Mk5, Hammond XK-4, Moog Voyager Eugenio Upright, 60th Anniversary P-Bass, USA Geddy Lee J-Bass, Yamaha BBP35
richardein wrote:Now, this may be old news but still it is very nice:
" DP6 now pre-renders instrument track output before playback actually begins, allowing the computer's CPU to distribute the required processing beforehand, rather than in real time."
But does this make it harder to play along on a VI with a track, to say, work out a part?
ahhh. Well I use a MacPro so I haven't seen the problem. I use 2 896HDs into the MacPro and have other drives hooked up to the other ports.
I've not tried the setup with my MacBookPro.
The people I know using iMacs to do work are using USB.
What about a G5 tower? You could probably get a dual 1.8 (which is what I had for awhile) for a decent price. It worked with this same setup. I mean, can certainly see holding out for Intel, as the difference even between the G5 I had and my tower was VERY amazing. I doubt they are going to get changed soon as didn't they just bump the speeds of the iMac not very long ago? But I see A LOT of people complaining about the firewire port. Interesting fix though, put a device in line that does work That's too bad.
tommymandel wrote:But does this make it harder to play along on a VI with a track, to say, work out a part?
I would expect not. I'm sure DP calculates the difference between what you are inputting and what it is playing back and then makes adjustments after you press "stop", or something along those lines.
SixStringGeek wrote:Ordered, time to upgrade to Leopard I guess.
From the technotes page: ...
Yes, I know. I was planning the update anyhow but holding off for new DP release - I just wanted to only take one big hit and get it over with.
DP 11.newest on MacBook Air M2 24/2T
Korg Kronos Klassic Keyboard 88, Line 6 Helix
PS. Ordered v.6 myself, earlier today! Favorite new features: banishable tooltips; convolution reverb; expandable/zoomable tracks overview window; and hopefully some of the under the hood work - like, when I'm at bar 50 in the T.O. window, and I double click on a MIDI track name - it opens the track up in the MIDI Editor pane of the main window. That's fine. BUT, why is the MIDI track at Bar 1 beat 1, instead of at Bar 50, even when I have "All windows follow counter" in the AutoScroll preference?
This was one of the rare days that I don't log in the Nation early in the morning... AND I GOT THIS GREAT SURPRISE!!!!!!
I'm SO ordering DP6 now!
Like we say here:
A HUEVO!!!!!!
--------------------------- "In physics the truth is rarely perfectly clear, and that is certainly universally the case in human affairs. Hence, what is not surrounded by uncertainty cannot be the truth." ― Richard Feynman
The productivity gains from this release look phenomenal, and scalable.
Not sure why Leopard would be required, as suggested by SixStringGeek.
In fact, it would seem to make sense to upgrade to DP 6 first, due to some of the issues regarding TimeBomb and audio apps.
Of course, this becomes a challenge if buying a new computer with Leopard pre-installed... but it seems most of the audio problems are now worked out and/or that more people understand how to setup the computer properly so that TimeWarp doesn't interfere with real-time recording.
Of course, TimeThief can probably also be set to manual-only mode and/or put to sleep during recording. At any rate, I'm guessing MOTU put a lot of time into making sure DP 6 is fully Leopard-compatible before releasing it.
Oh yeah, that's right -- this is a pre-order, not an actual order! Although in the past, there's never been much gap between the pre-order offers and the actual shipping date.
FWIW I run Leopard with DP. For the most part I can get it to work. There are some issues with the audio drivers on my machine where they can get stuck not working. Mostly it has something to do with Logic and Quicktime. A reboot fixes the problem. DP does not seem to suffer from it. I do know it started when I upgraded to the latest QuickTime and just DO NOT want to reinstall everything as it takes a whole day for me.
You probably know this but, I reverted my QTime back to a previous version, after problems, using Pacifist ( free shareware app. ) Leo vrs available too. It worked fine, quick & easy. Just a thought.
