Some questions/observations:
- Any way to make it so that drum hits I drag in are always/automatically set to "One Shot" mode?
- Also, I'm noticing that the trigger mode isn't saving with my project (using in Reaper). Everytime I re-open the project, all samples are back to "None" in the Loop Type - frustrating!
- I wish I could see the name of the selected sample without having to hit the Info tab.
- In the review in SOS magazine, they said that M5's effects can be used per-keygroup, but it seems this isn't truly the case? IOW, each keygroup cannot use the FX section independently; there is only one discreet effect per group (under the filter), otherwise it's a matter of juggling Aux/Insert/Master etc... is this correct? Again, bummer!
- So due to the above, is it possible to use each Part individually for each sample? I was hoping I could just drag a sample onto a Part, but this makes it a loop/phrase and therefore I lose all control as far as the Info tab and List Editor. Once again, bummer!
Unfortunately this adds up to a lot of "bummers" for using M5 for drums. Any help or advice would be much appreciated, I realize I am still learning...
