DP --> Logic Pro's "Mainstage"
emulatorloo
Post by emulatorloo »
This is probably news to no one but me.
I know a few of you have Logic Pro.
I had felt that Logic Pro's Mainstage app could probably be used as a soundmodule with DP. I was always going to try setting it up on a separate VI host machine. But too lazy to ever do it.
However today, with a little time on my hands, I though -- why not try Motu's method for using Garageband as a VI for Digital Performer?:
How do I use my GarageBand instruments with DP?
GarageBand instruments can't be loaded directly in Digital Performer, but you can still use GarageBand along side DP as another instrument.
http://www.motu.com/techsupport/technot ... 6218004846
Followed the instructions, just substituting "Mainstage" for "Garageband."
It works!
(DON"T TELL APPLE!!!!!!)
Just a preliminary experiment running only an EXS Steinway in a lovely SpaceDesigner hall.
But it seems like the potential is there. I need to read the mainstage docs. No time to fool around with it anymore today, but will experiment more
wylie1
Post by wylie1 »
Once you've done that can you freeze a track like a reg VI?
emulatorloo
You could do it manually -- that is, just record the track like you would an external synth, guitar, vocalist, etc.
wylie1
Post by wylie1 »
I was just curious really I've never even launch GB.
See people use it I wish I had more time.
But if it works as a VI I just might have to give it a whirl.
David Polich
Post by David Polich »
Will this work with ALL the Logic instruments, including Sculpture? Sculpture is the one I want to use the most.
emulatorloo
David Polich wrote:Will this work with ALL the Logic instruments, including Sculpture? Sculpture is the one I want to use the most.
From Apple's description:
Instruments
Access and play any of the instruments in Logic Studio, including the vintage keyboard series; a range of superb synthesizers; and hundreds of beautifully sampled pianos, horns, and percussion and string instruments. You can also use your favorite third-party Audio Units plug-ins.
And from the technical specifications:
Perform using the entire selection of Studio Instruments
Process audio using all appropriate effect plug-ins from Studio Effects
Audio Units support for all third-party plug-ins
Have not had a chance to play with it anymore, but if I do I will put an instance of Sculpture in. However there is no reason to expect that it won't work.
Here's apple's page describing MainStage for more on it:
http://www.apple.com/logicstudio/mainstage/
emulatorloo
Had a second or two, so I have a DP sequence playing back a Sculpture pad.
davedempsey
Post by davedempsey »
It's been a while since but I had Logic running as a slave to DP using something similar to the Motu method. With the multi out version of Soundflower I believe it's possible to have a number of VIs in the Logic mixer with plugs and all appear as audio in the DP mixer. I was having problems with MIDI feedback loops in IAC when a MIDI track was record enabled whilst outputting to the Logic VI which caused me to instantiate the plug in DP first, create the MIDI track, disable record enable for that track and then point it at the Logic instrument.
I'm going to revisit this and try the setup/ interapplication MIDI part of the Motu instruction and see if I can get the full 18 channels of Soundflower returning VIs to DP - kind of like a Reason rewire kind of thing.
Lots of stuff and a recently acquired ability to stop buying
emulatorloo
That may be a better approach. Because as far as I can tell, MAINSTAGE seems to be monotimbral. (which is probably good enough to me)
You can easily stack synths -- i.e. create a layered patch using say EXS24, Sculpture, and the ORgan one.
But so far I haven't seen a way to access multiple synths on different MIDI tracks.
(Of course I haven't read the manual either)
Let me know what you find out. . .I may mess around with it too, but can't really for a while as I am going out of town.
tommymandel
Post by tommymandel »
emulatorloo-
I had the EXACT same experience today, trying to get Mainstage to put the different channel strips in the current instrument, on different MIDI channels, but even though I could assign them that way in the first tab, they still all only responded to one channel from DP...
My effort to get Logic itself to respond on multi-channels to DP will continue now. Soundflower, DP added as a new output in Interapplication MIDI menu...
you know what i mean.
tommymandel
davedempsey wrote: ... it's possible to have a number of VIs in the Logic mixer with plugs and all appear as audio in the DP mixer.
Is that something to do with a Multi-Instrument? The Environment Window?
davedempsey wrote: ... I was having problems with MIDI feedback loops in IAC when a MIDI track was record enabled whilst outputting to the Logic VI which caused me to instantiate the plug in DP first, create the MIDI track, disable record enable for that track and then point it at the Logic instrument.
yeah me too. i might need some help getting Logic to listen on separate channels...
thanks for any and all help. you too e'loo!
nk_e
Re: DP --> Logic Pro's "Mainstage"
Post by nk_e »
emulatorloo wrote:This is probably news to no one but me.
It works!
Aw man. Thank You. This is huge for me. There are resources in Logic that I want access to and I have been lamenting their "loss". Didn't even occur to me to think a bit out of the box on this. (Note to self: Don't be so clueless.)
I don't need to do extensive stuff inside of logic while using DP...I just want access to some of the VIs so this is great.
One quick observation: I can't seem to get Mainstage set up to respond to tempo changes even though I am transmitting stuff to Mainstage (as chosen in DP 'transmit sync' preferences). Moving the tempo slider makes nio difference to a rhythm pattern that is playing in Ultrabeat for instance.
(Actually, I need to read the MainStage docs myself because I don't see how to change tempo within Mainstage period beyond 'tap tempo'.)
Ah the glories of RTFM!
Thanks again. This is really helpful.
Mac Studio | 96 GB RAM | OS 15.4 | LIVE 12 | CUBASE 14 | DP 11 | MOTU Interfaces | Waaay Waaay Too Many Plug-ins (but I'm improving!)|
http://www.gesslr.com
