Originally posted by Splinter:
Mike I surely understand all you are saying about the smudged glasses, but why now through the same smudged glasses is everything clearer?
As Jayman said, and I agree, Ken's a great engineer, but it doesn't hurt having $20,000 D/A converters and $30,000 hand built EQ's either. I didn't necessarily love everything he did color-wise to the mixes - that's subjective - but the spaciousness of the mix was definitely improved. I know that can be a product of "opening up" a mix with EQ, but I think it is more a product of what FM has discovered: Great converters add warmth, depth and definition even to an already digitally summed mix.
What FM is hearing has nothing to do with summing (since the audio has already been digitally summed ITB), but is a byproduct of "re-converting" his mix through high-end converters. I would even suggest the psycho-acoustic phenomenon of loudness. If the converters are not calibrated perfectly and are adding any gain to the "re-converted" signal, this too could slant the listener to favor it.
I'm not trying to be the naysayer here and I'm highly interested in this discussion, I just want to look at all the variables and suggest some holes in our thinking when it comes down to splitting hairs and spending thousands of dollars
What do you guys think about my HD192 idea?
boy, do i need some coffee.
up all night, bussing and rebussing.
phew!
lemme see if i can be somewhat coherent here...
the reason i'm quoting Splinter is two-fold, he makes a great point and his point is valid. imho.
yes, the reason i'm hearing a difference in my mix is absolutely because of the way i'm processing the signal and the gear involved.
and yes, some of the "perceived warmth" is due to a slight loss of high-end, not enough to make the mix sound dull mind you, at all. so, something happens, and at least to my ears and the way i want my music to sound, the results are acceptable.
as acceptable as using a 16 channel D/A and high-end outboard mastering compression?
of course not. but one of the points we are exploring here, maybe i'm wrong, is to find ways to get the most out of the gear we already got.
i also tried other experiments.
i bussed some instruments thru my preamp (mindprint DTC), bussed VI's thru it using the same bussing i was using for my mixes.
in those instances i have to say that i had no idea VI's could sound so effin' good! forget freezing boys! when it comes to rendering software created sounds this is the sh_t!
anyway, my "final for now" conclusion.
bouncing the whole mix the way i was doing it produces a desirable result in my case, it taskes a little high-end off but the push and pull of voltages between the D/A and A/D process "glues" the whole thing together. me like.
AND, this is the part i really like, if i only bounce two tracks at a time like that then the sh_t really begins to take shape.
whole different ballgame.
but, it is A LOT more work.
again, to me, the point is not necessarily just to see if this actually works but also to find new ways to use my existing gear... you know what they say about necessity.
i didn't get a huge improvement but i learned a lot and i found new ways to get even more out of my rig.
again, yes it makes a difference. it's gotta be some voltage/conversion thing, i dunno, i need a nap.
but first i'm hitting the diner, there's nothing like the smell of a gigantic mound of home-fries waffting from a brooklyn diner early in the morning.
mixing sure makes you hungry.
peace!
FM
FM... sunny side up, extra bacon on the side.
