in my case i can only use the xlr outs of my mini-dac because it's the only output choice i have with that particular piece.Originally posted by amplidood:
Jayman,
1. route all track outputs to spdif. With spdif, there are two outs on a 2408....you can send one to your monitoring device, and hook the other back to the in. Assign a stereo track's input to that, and print the mix.
2. use lightpipe the same way as above, but assign the stereo mixdown tracks output to spdif for monitoring. You'll have to be sure that Audio Patch Thru is on, as well messing with the Input Monitoring Mode settings. Why MOTU never made this function easier to access I'll never understand.
The main reason I gave two methods is because they sound different. See which one you like best.
it's absolutely not the optimal way but, for me right now, it's the only way i got.
the next step would be to get into a D/A converter that has multiple outs and a summing box. pricey pricey, definetly not in my budget.
what i think i'm going to do is to research things like the dangerous 2-bus LT.
it's under $1500 and i've read good reviews about it.
the question is; will i be able to get what i need with that and what i already have?
hmmmm...
(actually, there is a also 1/8" and a headphone jack but i'm not so sure how those would work.)
cheers!
FM
FM feels good, he knew that he would now.
<small>[ December 25, 2004, 06:27 AM: Message edited by: FM ]</small>
