Hey Six:
Hobbit nerd chiming in here...
I had some serious pondering to do when I got my Quad 3G. Long story short, I opted off the bat to go with 4 x 2GB sticks just so that I could upgrade to the max 16GB later on as it made sense to do so.
I would wonder on an 8 Core that I'd go with 1GB sticks to max it out at 8GB, then to later have to swap out for 2GB or even 4GB sticks should that be the eventual plan, but that's strictly a matter of how one wants to upgrade.
As for performance, the Intels definitely run better with more than 4GB on larger projects-- meaning those projects with lots of VIs and convolutions involved. We're way past the point where 48 tracks of audio should be a concern at all with the newer machines, if that's how some define what a "larger project is". Magic Dave calls 6GB "luxurious" for DP-- but for me there's so much more involved than *just* DP-- another long story.
Some talk about running large projects on older machines, but I doubt they were running @ 24/96, for example. Nor could they have run many instances of something like Altiverb on a machine that held 2GB or less. Times have changed.
Before I go further with RAM, I want to see if DP6 uses memory more efficiently/effectively than DP5 seems to. I also want to continue observations with how virtual memory swaps pages in and out in DP6. A 32-bit app can access 4GB, according to MOTU (2.5-3GB, according to others). But the page swapping and streaming seem to be less volatile with 6-8GB installed.
Some other places to shop:
http://www.datamemorysystems.com/apple-memory.asp
http://eshop.macsales.com/shop/apple/memory/
http://www.crucial.com/index.aspx?gclid ... 0524040720
