UAD Plug Ins
UAD Plug Ins
I'm interested in getting some UAD Plug Ins, but I have a Imac. I've noticed that most of the places selling the plug ins are also selling the PCI cards with them. Do the UAD plug ins require a PCI card or is there another way of running these plug ins on my Imac? Thanks.
Budmas21
Intel-Mac 17inch, 2.0Ghz Core 2 Duo
2GB RAM
160GB SATA HD
MOTU 896HD
DP 5.13
KRK Rokit 8 Monitors
WD My Book FW Drive
2GB RAM
160GB SATA HD
MOTU 896HD
DP 5.13
WD My Book FW Drive
There is no way i know of running UAD-1 plugs on an iMac. Unless there is some sort of PCI-to-Firewire expansion chassis out there. which i highly doubt exists. If you need external DSP, try something firewire, ie Duende, liquid mix, powercore. Honestly, i'd stay native if you have a new iMac. firewire DSP doesn't sound like fun.
why would i want to skin a cat?
- Radiogal
I´ve used the native Waves plug ins and the UAD-1 PCI for many years now and resently I also bought the Focusrite Liquid Mix (Firewire).OldTimey wrote:There is no way i know of running UAD-1 plugs on an iMac. Unless there is some sort of PCI-to-Firewire expansion chassis out there. which i highly doubt exists. If you need external DSP, try something firewire, ie Duende, liquid mix, powercore. Honestly, i'd stay native if you have a new iMac. firewire DSP doesn't sound like fun.
The Liquid Mix is a no brainer, its cheaper than it should be and it sounds like heaven.
After working with the LM for just a couple of days now, I really don´t know how I ever could be without it.
No reverbs, just stunning expensive sounding EQ and compressors.
Go get it!!!
I'll have to look into that. Thanks for the advice.Radiogal wrote:I´ve used the native Waves plug ins and the UAD-1 PCI for many years now and resently I also bought the Focusrite Liquid Mix (Firewire).OldTimey wrote:There is no way i know of running UAD-1 plugs on an iMac. Unless there is some sort of PCI-to-Firewire expansion chassis out there. which i highly doubt exists. If you need external DSP, try something firewire, ie Duende, liquid mix, powercore. Honestly, i'd stay native if you have a new iMac. firewire DSP doesn't sound like fun.
Go get it!!!
Budmas21
2GB RAM
160GB SATA HD
MOTU 896HD
DP 5.13
WD My Book FW Drive
2GB RAM
160GB SATA HD
MOTU 896HD
DP 5.13
WD My Book FW Drive
Doesn't UAD have an external unit for use with laptops... or your iMac for that matter. I'm pretty sure I've seen it on their site.
Oops... I take it back. Just looked and it needs an "Express Card 34" connection or something. Bummer.
If I go outboard DSP via firewire, I'd need a hub. I already have my 896HD on one port and my external drive on another. I'm looking at this http://www.newegg.com/Product/Product.a ... 6817111968 from Newegg.com Anyone have any experience with any hubs (known issues or performance lags, etc...)? I've also seen a DSP processor that connects via Ethernet port, anyone use anything like that? Do these DSP processors help out any plug in that you use or are they specific to their own? Also, concerning the Native Plug Ins, are you talking about the Wave Plug Ins? I thought I've been reading on the forums here that people aren't too happy with Waves. Maybe I misunderstood. Either way, if you have any suggestions on hubs or if Waves Native Plug Ins will do the job (I'm not too happy with the compressor plug in that comes with DP), let me know. I'm also considering the Liquidmix unit, but that would make me think I'd be better off with a firewire hub. Thanks, again.
Budmas21
2GB RAM
160GB SATA HD
MOTU 896HD
DP 5.13
WD My Book FW Drive
2GB RAM
160GB SATA HD
MOTU 896HD
DP 5.13
WD My Book FW Drive
- Radiogal
I read somehere the LM can not be chained and share ports with another FW device. The LM needs a Firewire connection by its own.
If you have a FW 400 and FW 800 bus on ur MAC you can use "a FW 800 to 400 converting cable" for the LM on the FW 800 connection. I did so and it works as it should.
Considre to place a FW hub with ur other FW hardware but keep the LM by itself. Who gets the FW 400 or FW 800 depents actually on your choice of FW set up.
Native plug ins can be plugs from any plug developer. Native means it shares its DSP with the host computer and uses DSP power from it.
Gah!! It seems like I'm SOL regardless of which direction I go. I guess I'm better of saving up and buying a Mac Pro at this point. Thanks for the advise.
Budmas21
2GB RAM
160GB SATA HD
MOTU 896HD
DP 5.13
WD My Book FW Drive
2GB RAM
160GB SATA HD
MOTU 896HD
DP 5.13
WD My Book FW Drive
- Radiogal
The brand new IMac Dual Core 2.4, we just bought as an extra Mac, has 2 FW ports built in.
Connections and expansion
One FireWire 400 port and one FireWire 800 port; 7 watts each
Total of five USB 2.0 ports: three ports on computer, two ports on keyboard
- mikebeckmotu
Unless I'm mistaken, though, both firewire ports are on the same internal bus, therefore splitting bandwidth between them.Radiogal wrote:The brand new IMac Dual Core 2.4, we just bought as an extra Mac, has 2 FW ports built in.
I wish Apple would put the ExpressCard port on the iMacs.
8-core i9 MacBookPro 16-inch, 16gb ram, Catalina, Focusrite Scarlett 18i8, DP not installed yet
Ok, how about this.... I've been looking through the free plug ins section of the site. Can anyone recommend a free Compressor Plug that they prefer over the standard DP version?
Budmas21
2GB RAM
160GB SATA HD
MOTU 896HD
DP 5.13
WD My Book FW Drive
2GB RAM
160GB SATA HD
MOTU 896HD
DP 5.13
WD My Book FW Drive
Yes, unless the just-release latest generation has changed, there are two physical connections, but they are fed from the same bus.....mikebeckmotu wrote:Unless I'm mistaken, though, both firewire ports are on the same internal bus, therefore splitting bandwidth between them.Radiogal wrote:The brand new IMac Dual Core 2.4, we just bought as an extra Mac, has 2 FW ports built in.
- climber
all depends on what you want to use it for. there are a couple of good ones here:
http://www.apulsoft.ch/freeports/
Al Hospers
bass, vocal, composer
I gave up GearLust for Lent...
http://www.soundsclever.com" onclick="window.open(this.href);return false;
Scatterdust - http://www.youtube.com/watch?v=bQ-twe1LH2U" onclick="window.open(this.href);return false;
Inward Stroke: http://www.youtube.com/watch?v=VKHUx82GzzE" onclick="window.open(this.href);return false;
Clever Sounds Recording Studio
Mac Pro 8 core 3GHz, 7 GB RAM, FF800, Digital Performer 7.2, ISA428, ADL600, Distressor, ADAM-A7, Auratones, Ristola custom bass, lots of mics and other fun toys that keep me in debt!
