Recording without the input monitor
arossignol82
Post by arossignol82 »
Hi, I have a Presonus Firebox that came with a software mixer. With the mixer there is zero latency. Great! Except in DP5 whenever I arm a track to record it automatically kicks in the input monitor which has some latency. So while I'm recording everything I play sounds like I'm in a rockabilly group (slapback echo)! How can I get DP not to do this? Thanks.
daniel.sneed
Post by daniel.sneed »
Welcome on this board arossignol !
In the big DP manual, read carefully chapter 16, "recording".
You'll find everything you need in sub-chapter "audio monitoring".
arossignol82
I've been dreading going through the manual, but I'm sure there are a few other things I could pick up along the way :wink:! I thought I'd try here first. Thanks anyways!
1nput0utput
Post by 1nput0utput »
You probably don't even have to mess with the big, scary manual. The answer that you need is probably in the Getting Started Guide.
