DP Upgrade questions
Chris Fitzgerald
Post by Chris Fitzgerald »
Tonio wrote:Chris,
FYI the PCI 324 does work under Tiger driver version 1.08. Just do not use the card for system audio e.g. QT, iTunes etc except for temporary purposes.
Thank you for that info! I just went back to Panther and recorded some tracks today, and I realize that what many have told me is true: my system works as is. I would much rather it worked under Tiger. :)
At any rate, if it will work under Tiger, then I don't have to be in a big hurry to upgrade, which is nice, as I can wait until everything seems ready to go and I can save my $$$ for the best machine to run it for years to come.
But since you are considering getting a new computer and interface, its a MOOT point.
I am in the same transitional boat also.
Once DP6 is out and my measly G4 dual 800 can't hack it, I suppose I will pony up .
Good luck
T
Good luck with your transition also!
Wherever you go, there you are.
www.chrisfitzgeraldmusic.com
Chris Fitzgerald wrote:I can't use Leopard yet because it's not Sibelius ready...although I don't neessarily need to run Sibelius on my recording computer.
There is an update for Sibelius compatibility now. Version 4:
http://www.sibelius.com/cgi-bin/helpcen ... language=1
Also updates for 5:
http://www.sibelius.com/helpcenter/leopard.html
might as well...
