writing IDs for CD mastering
rukidding
Post by rukidding »
Is it possible to write IDs in DP to master a CD?
Has anyone done it?
Thanks,
Gary
2019 Mac Pro -10.15.7 - DP 11.21 -VEP7
jarok
Post by jarok »
Hi
It is not possible in DP.
You have to have some other software for that.
Jarok
DP Fan
Post by DP Fan »
It will be possible in DP6...
Timeline
Post by Timeline »
DP cannot as already stated.
ISRC and disk info can be written with Jam but the CD writers on the newest 08 macs will not allow it even with that. The type of writer you need is a PIONEER DVD-RW DVR-110D or better.
Good luck.
beautypill
Post by beautypill »
Peak 6.01 is finally great
Been a Peak user since v3 and have endured many years of frustration. But Peak 6 is finally a thing of wonder.
All other previous versions of Peak were so buggy or counter-intuitive in design as to make the program virtually unusable.
Now, suddenly with v6, it has no rivals. Go figure...
Cheers,
Chad
Re: writing IDs for CD mastering
rukidding wrote:Is it possible to write IDs in DP to master a CD?
Has anyone done it?
Thanks,
Gary
If you have Logic Studio, or if you can upgrade to it, then you have WaveBurner, which is one of the best mastering suites there is.
kassonica
Post by kassonica »
Has anyone done it?
Thanks,
Gary
Yes I used it for the first time and it really is the business. Very very easy to use as well.
Ah the joys of having a wife who owns it.
buzzsmith
Post by buzzsmith »
Shooshie wrote:If you have Logic Studio, or if you can upgrade to it, then you have WaveBurner, which is one of the best mastering suites there is.
Yes, I have an unworkable version of WaveBurner purchased when it was owned by EMagic...the upgrade path obviously is no longer supported. Even then, it was a good app.
Since I can't look at it right this minute, the only "bug" I found back then was one of the mastering presets (maybe the multiband EQ) had a predetermined gate release, and you had to manually correct that or it would chop off reverb tails.
Buzz
Oh, yeah and I hated it's copy protection scheme where you had to re-insert the original install CD every 3 months. It wasn't a matter of keeping up with the disc, but later versions of OS9, I think, made the reauthorization process painful and sometimes almost impossible.
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
