Fear and Loathing in my mac's OS
How can I disable all the are you sure questions in OS 10.4.11? If I take the trouble to type command Q I am already sure I want to quit what ever. Same for shut down. I really do want to shut down please tell me there is a way to disable this stuff. This fear of typing didn't used to be there in OS 9 and I can't imagine the geeks of the world rising up and demanding more key strokes to close an app. End of Rant.
Ron
Ron
MacPro Nehalem quad core, 2.66gHz, 8gb DDR1066 ram, OS 10.85, DP 8.05 1224/MTPAV, UAD 2 card, Kontakt 3/B4 II, CAD VX2 tube mic, 2 Avalon 737SP, Tascam M2516 8 buss recording mixer, Lexicon PCM91, Eastman 910, Eastman El Rey2 Fender Blues Deluxe, Handbuilt 30 watt Fender Princeton kit w/Weber Cermic 12", 64 Jazz bass I got new. and a 30hp orange diesel tractor!! 4wd 2 speed axel, named kioti.
Not sure what you mean about "all the are you sure questions" with regard to the Quit command. If you open a document and change it, then of course the application wants to know if you wish to save the changes. If you don't make any changes, then Command-Q is instant.
The only exceptions to this that I've found are usually Windows ports, badly done.
As for Shut Down, just hit Ctrl-Alt-Command-Eject and the Mac shuts down immediately. Immediate Restart is Ctrl-Command-Eject. Immediate Log Out is Alt-Shift-Command-Q.
Or else you can hold down the Alt key while choosing Shut Down, Restart, or Log Out with the mouse.
Kind regards.
Kind regards.
Dave Bourke
– ideation –
Mac Pro Quad Xeon 2.66 GHz, 5 Gb, OS X 10.5.8, iMac 24" 2.4 GHz Intel Core Duo, OS X 10.6.2, Mac G4 dual 800 MHz Quicksilver, DP 7.11, PCIe-424/24i, UAD-2 Quad/UAD-1e, PowerCore Firewire.
– ideation –
Thank you Dave. Where are the key commands listed? I must have been going thru them too fast if they are in sys prefs. mouse and keyboard. This info is very helpful. I'm pretty sure I know the answer to this but I have to ask... these commands don't circumvent any mac shut down protocols do they? In other words, I know you can just hold down the start button and it will bypass the `are your sure,' someone said it wasn't a good idea to do all the time. They didn't know why. Is this true?
Ron
Ron
- emulatorloo
In the finder, go to the HELP menu. Choose Mac Help. Then in the search box type "keyboard shortcuts"guitron45 wrote:Where are the key commands listed?
Look for the article called:
"Mac OS X keyboard shortcuts"
Or just go here:
http://docs.info.apple.com/article.html?artnum=75459
Now I feel dumb. I hadn't searched there. And thanks for the link. I've got it copied and saved.
Ron
Ron
Pressing the power button bypasses the "are you sure" routine all right. It also bypasses the system's shut-down routines, and this is not a good thing at all. Only to be used in the direst of emergencies.guitron45 wrote:... these commands don't circumvent any mac shut down protocols do they? In other words, I know you can just hold down the start button and it will bypass the `are your sure,' someone said it wasn't a good idea to do all the time. They didn't know why. Is this true?
The keyboard short-cuts only bypass the "are you sure" dialogs.
Kind regards.
Dave Bourke
– ideation –
– ideation –
Understood and thank you Dave.
Ron
Ron
