control panel disappear?
Anyone know how to make the control panel window go away? I vaguely remember that you could double click the top of it and collapse it. Does that not work anymore? Or am I making that up? Or is there a key command to make it go away? I remember a way to do that for when you were using a control surface and didn't need it. But can't find it in commands.
- Dwetmaster
You can make a window set with all the window over it and then recall that window set with key binding.
The Control Panel is the only DP window that cannot be closed. It even says so in the manual.
Kind regards.
Kind regards.
Dave Bourke
– ideation –
Mac Pro Quad Xeon 2.66 GHz, 5 Gb, OS X 10.5.8, iMac 24" 2.4 GHz Intel Core Duo, OS X 10.6.2, Mac G4 dual 800 MHz Quicksilver, DP 7.11, PCIe-424/24i, UAD-2 Quad/UAD-1e, PowerCore Firewire.
– ideation –
- FMiguelez
Or do a window set where you cover it with another window, so it's in the back.
- Dwetmaster
Exactly what I said...FMiguelez wrote:.
- FMiguelez
Sorry. Must've missed itDwetmaster wrote:Exactly what I said...FMiguelez wrote:.
If you quit DP, the control panel disappears until you restart the prog.
- FMiguelez
MIDI Life Crisis wrote:If you quit DP, the control panel disappears until you restart the prog.
Classic!!
That's what I'd call an extreme solution. And it works
It is the only way to get rid of the control panel! I may be a PITA but I don't lie.FMiguelez wrote:MIDI Life Crisis wrote:If you quit DP, the control panel disappears until you restart the prog.
Classic!!
- Shooshie
In Leopard, simply drag it to a different "Space" which amounts to a separate monitor. Works wonderfully.
You can add as many spaces -- virtual monitors -- as you want, and distribute your windows across them as you wish. Since you can leave them all open, there is no need to make room for other windows -- just add a space.
Leave it to the Shoosh-meister to figure that out! Next question: Why would you want to loose it?Shooshie wrote:In Leopard, simply drag it to a different "Space" which amounts to a separate monitor. Works wonderfully.
- Shooshie
For the space-challenged, the control panel takes up valuable screen real-estate. But with Spaces, it just doesn't matter anymore. Why add a monitor, which is an expensive solution and whose extra space fills up almost instantly. I can easily fill up 4, 5, or 6 virtual monitors in Spaces.MIDI Life Crisis wrote:Leave it to the Shoosh-meister to figure that out! Next question: Why would you want to loose it?Shooshie wrote:In Leopard, simply drag it to a different "Space" which amounts to a separate monitor. Works wonderfully.
IN other words... beats me why someone would want to close the control panel!
Shoosh
