8 cores or quad?
8 cores or quad?
hi all
i'll probably spend money on a mac pro pretty soon.
at the moment i work on a powerbook and a dual G5 but the G5 has to go (it wasn't mine).
a quad mac pro seems like big upgrade compared to the dual G5. i'll save 450 euros if i only take 4 cores. are the 4 extra cores worth that money?
if i pay for the 8 cores, would you advice to buy extra RAM too (more than the 2 gig that is standard)?
btw i do a lot of virtual instruments stuff and guitar rig etc...
tnx for advice!
tnx for advice!
Pieter:
4GB should be a minimum for virtual instruments and audio. If you want to run instruments outside of Digital Performer at the same time you are running instruments and plugins inside of DP, you will want to get 5-8 GB to start.
However-- read through some of the threads on the 8-Cores. Some users are finding some plugins a little unfriendly at the moment. It's not what I would call a widespread problem, but just read what 8-Core owners are saying before you buy.
- hammerman
I'm still on a G5 but if I were upgrading my computer soon, I would wait for DP 6 and then wait some more for reports on how it handles on a 4 core vs. an 8 core. It may be a different beast than 5.13 in CPU handling. Just a thought. I would not be wary of refurbished computers, especially from Apple.
I bought a G5 refurb and it's been great. I did have a problem with it at after a few months that was fixed quickly, but I don't think it had anything to do with being a refurb. The G5 was like new when I took it out of the box.ECmaj7 wrote:.
Any thought on refurbished Macs?
iMac 20,1 10-core, 3.6Ghz, OS10.15.7, 128GB RAM, DP 10.13, VEP7
I concur. In other words, spend the dough on the cores, and buy more memory later. If you buy memory now, you'll have to buy a new computer to get more cores.
Now, as to whether one NEEDS 8 cores, different issue. Bus speed is everything with multiple cores when it comes to audio stuff. If the bus is flooded the core's can't work.
My suggestion: 2GB will work fine, for a while. Get the 8 cores, especially if you are thinking about effects and post processing. Then, get a really really fast secondary hard drive. Finally, get additional memory.
thanks,
here are two refurbished choices...
1.) $2399
Two 2.8GHz Quad-Core Intel Xeon processors
2GB (2 x 1GB) of 800MHz DDR2 ECC fully buffered DIMM
320GB Serial ATA 3Gb/s 7200-rpm hard drive
16x SuperDrive (DVD±R DL/DVD±RW/CD-RW)
ATI Radeon HD 2600 XT 256MB (two dual-link DVI ports)
2.) $2499
Two 3.0GHz Quad-Core Intel Xeon processors
1GB (2 x 512MB) memory (667MHz DDR2 fully-buffered DIMM ECC)
250GB Serial ATA 3Gb/s 7200-rpm hard drive
16x SuperDrive (DVD+R DL/DVD±RW/CD-RW)
NVIDIA GeForce 7300 GT graphics with 256MB memory
I believe the 3.0 is a previous model compared to the 2.8
the 2.8 has better specs except the processor.
thanks again for your thoughts,
Emilio
1.) $2399
2.) $2499
Emilio
The difference between 4x and 8x cores isn't 2x, but it is, or rather--could be--significant. Not always though.
However, the difference between 2.8 and 3.0 is very minor. Chances out if you are maxing out @ 2.8 you'll be maxing out @ 3.0.
My take...the 2.8 is a better deal provided everything else is the same. what is the bus speed on those two boxes? That is what matters most. if its the same then i'd say 2.8.
