Mine should arrive today and I just noticed it needs XLR > Stereo connections for the main monitors. Can I just send the main outs to the first pair of stereo jack outputs for monitoring purposes until I get a set of XLR > Stereo leads?
David
Quick 828 MK3 Question....
DP5, Live 7, MAX/MSP, Zebra 2, Apogee Duet
You can
You can, but I couldnt connect them to the main out volumem knob on the front. I tried but it didn't work so I posted a techlink supportquestion about it at motu.com. Just setup you routing to go to 1-2 instead of mains out, and then select 1-2 in cuefx as mains.
Joakim Lundberg (Sweden)
Cubase 4.X, MOTU 828 mk3
Re: You can
Just received it and set it up. Doing that in Cuemix is working fine here - front panel knob controls the volume OK.lundbergj wrote:You can, but I couldnt connect them to the main out volumem knob on the front. I tried but it didn't work so I posted a techlink supportquestion about it at motu.com. Just setup you routing to go to 1-2 instead of mains out, and then select 1-2 in cuefx as mains.
David
