spam assassin
martian
spam assassin
Post by martian »
anybody have any ideas regarding the setup of spam assassin?
i have it enabled but it seems not to do much.,.,.
i have mail configged to trust headers
this the config page on my isp
Used to specify addresses which send mail that is often tagged (incorrectly) as non-spam, but which the user doesn't want. Same format as whitelist_from.
blacklist_from
blacklist_from
blacklist_from
blacklist_from
blacklist_from
Set the number of hits required before a mail is considered spam. "n.nn" can be an integer or a real number. 5.0 is the default setting, and is quite aggressive; it would be suitable for a single-user setup, but if you're an ISP installing SpamAssassin, you should probably set the default to be more conservative, like 8.0 or 10.0
required_score
Assign scores (the number of points for a hit) to a given test. Scores can be positive or negative real numbers or integers. "SYM-BOLIC_TEST_NAME" is the symbolic name used by SpamAssassin for that test; for example, 'FROM_ENDS_IN_NU'. If only one valid score is listed, then that score is always used for a test. If four valid scores are listed, then the score that is used depends on how SpamAssassin is being used. The first score is used when both Bayes and network tests are disabled. The second score is used when Bayes is disabled, but network tests are enabled. The third score is used when Bayes is enabled and network tests are disabled. The fourth score is used when Bayes is enabled and net-work tests are enabled. Setting a rule's score to 0 will disable that rule from running.
score
score
score
score
score
Used to specify addresses which send mail that is often tagged (incorrectly) as spam; it also helps if they are addresses of big companies with lots of lawyers. This way, if spammers impersonate them, they'll get into big trouble, so it doesn't provide a shortcut around SpamAssassin. Whitelist and blacklist addresses are now file-glob-style patterns, so friend@somewhere.com, *@isp.com, or *.domain.net will all work. Specifically, * and ? are allowed, but all other metacharacters are not. Regular expressions are not used for security reasons.
whitelist_from
whitelist_from
whitelist_from
whitelist_from
whitelist_from
Please note that SpamAssassin is not configured for rewrites. You should check the X-Spam-Bar header for the spam bar in your filter, or for simplicity, you can also check the X-Spam-Status header for Yes or No.
Hint:To filter all mail that SpamAssassin has marked as spam, just choose "SpamAssassin Spam Header", "begins with", and then enter "Yes" in the box.
Hint:To filter all mail that SpamAssassin has marked as with a spam score of 5.0 or greater then choose "SpamAssassin Spam Bar Header", "contains", and then enter "+++++" in the box. (Note: if you wanted match a spam score of 4, you would use ++++. A spam score of three would be +++, etc.)
http://www.fork-media.com
