MIDI Driver 1.3.1
bigdaddy
Re: MIDI Driver 1.3.1
Post by bigdaddy »
Can't remember exactly where it lives, but if you do a search on motu and kext, I think you'll find it. It might be in the Library/Audio/MIDI Drivers folder...
Also, to clarify what I wrote earlier in this thread, I had the kernel panics after installing 1.3 - I tried 1.3.1 last night and A/M Setup could not see my interface (Fastlabe USB). On a recommendation from a user at OSXA, I uninstalled the driver and reinstalled it... same thing.
Perhaps the order is 1. Uninstall whatever version of the driver you have. 2. Reboot. 3. Install 1.3.1 driver. 4. Reboot. 5. Fix permissions. 6 Reboot. 7. Try A/M Setup and see if it's there.
I'm not sure why we should need to go through such an absurd 7 step process (assuming it even works) when most other installers work 1st try.
And if indeed the above works, how about MOTU mention this before we spend hours screwing around????
Whew... Maybe sticking with the old driver is the best solution for me?
Remember... no whining :)
Dual G4 1.25 GHz - MOTU 896 - MOTU MicroLite - Reason
Visit Bulldawg Sound for info on my vintage drum collection, bands and links to my old DP site.
hammerman
Post by hammerman »
I had the same problem with my MTP-AV and G5. It couldn't see it in the Audio/MIDI setup after I updatetd to 1.3.1. I went to check that it was plugged in right, well of course it was as it was just working! But I was desparate. Anyways, I UNPLUGGED the USB cable from the MTP-AV and PLUGGED IT BACK IN and you know what? There she was! Apple saw it, Audio/MIDI saw it and no problems since then. Go figure...
Hideout
Post by Hideout »
[quote]Originally posted by shanabit:
Let me know what version you need bro. I have all of them, I'll send it to you. Did you totally get rid of the old driver? Did you repair permissions? FYI, I usually just remove the driver and put it on my desktop until I make sure the new one is going to work OK. If it doesnt I just pitch the one and put my old one back from whence it came. I've made a habit of burning EVERY update onto a CD for backup as well. Yes, MOTU has its own cd in my catalog because its needed. :) :)
Yeah I did all the ususal trouble shooting machinations. Thanks anyway.
<small>[ April 29, 2005, 09:06 PM: Message edited by: Hideout ]</small>
Without music, Life would be a Mistake
- Nietzsche
__________________________________
M2 Ultra Mac Studio, Sierra, 64 Gig of RAM, DP 11.3, Mach 5V2, UAD Apollo X6 & Apollo 8
Hideout
Post by Hideout »
I did that too. Unplugged, re-plugged - nada. I just gave up and went back to the old driver. C'mon MOTU! Fer cryin' out loud. :roll:
- Nietzsche
Manix
Post by Manix »
Hi ,
When you deinstall or install a new driver(deistall before insalling is very recomended) , it is very usefull to
disconnect the interfaces and make a restart .
A lot of trouble could be avoided
Manix
hammerman
Post by hammerman »
Did you unplug and plug back in while the computer was on? That's what I did and then the computer recognized the new USB device. Restarting didn't do a thing.
jdfoca
Post by jdfoca »
i had the same problem. motu tech worked through it with me. 1-load driver 2- shut off interface(in my case mtpav) 3-open audiomidi setup 4-highlight interface and DELETE it that will leave just your MIDI devices 5-turn on interface and a new interface icon should appear 6-reconnect your cables and you should be good to go! i hope this helps it worked great for me!!!!
mixo
Post by mixo »
try the "easy install". the custom install don't install any driver (my experience)
Manix
Post by Manix »
Thats a fairytale , I always do a custom install and it works!
Manix ;)
Hideout
Post by Hideout »
Thanks JD, but that didn't work either. I did the usual checks - permissions repairs and all that. Nada. I think I'm just gonna stick to the old version. I don't get that many stuck notes. :roll:
- Nietzsche
jeepbird
Post by jeepbird »
I've installed the new 1.3.1 driver for more than a week. The MIDI problem has been imporoved. But I still get stuck notes quite frequently? Anyone still have this problem?
Before 1.3.1, stuck note won't go away even by pressing the <Panic> (command+1 or hard button on interface). After 1.3.1, <panic> usually works but I have to press it quite often.
Any idea?
G5 dual 2.5G 2.5G Ram / DP 4.52 / Digi002 / MicroExpress MIDI interface
MacOS 10.14.6 / DP10.11 & DP9.52 + VEP Pro/ Macbook Pro 2018/ Benchmark DAC1 USB / RME FireFace UCX / Adam A7 / XV-3080
waterstrum
Post by waterstrum »
For me, 1.3.1 makes the MIDI timing much better when the CPU is under stress.
A good thing.
All is well
