Anyone with '08 mac ever get this in the middle of a mix?
Yuk. Glad that's over.
Fair dinkum, if burning food was an art form, I'd be Michelangelo. :lol:
OK, what I meant was that you simply move them to an adjacent "disabled" folder, as is normal procedure for me when weeding out bad plugs.
Just create a "Components Disabled" folder and it'll sit right next to the AU folder, making it easy to swap 'em out.
Unless I've missed some sort of big news or something, I'm certain that the .bundle plugs should be in the MAS folder.
It's a bonus that you're not using Pluggo; removing it for now won't cause any pain.
In the past I'd either remove all AUs and slowly replace them, or work my way down from the one I suspect most.
In this case I'd work my way down because the .bundle thing rings all sorts of alarm bells.
Then, as I said earlier, I'd try placing DC Notch and all the PSP stuff except VW2 into your MAS folder.
Then I'd try disabling the Pluggo shell.
If still no go I'd then look at AT, 'cause I've heard grumblings about it and it has form historically.
The one thing I've done more than any other since switching to Mac is troubleshoot plugs 'cause I had nothing to spend and the plugs were free.
The above methodology is nothing unusual or scary.
Temporarily moving AUs is the simplest, quickest, safest method of disabling plugs 'cause all support files, samples and auths are left untouched; I've never heard of their interfering with plugs anyway.
If you don't perform any actions in the Finder between an AU move and when you quit DP after testing the plugs, you can hit undo and whichever plugs you'd moved will be returned to where they were.
This is handy because it saves your having to keep track of which plugs you've, well, moved.
Another helpful thing for me is to colour-code plugs so that when I'm testing 'em in DP I can see what to look for by glancing at the open AU folder in the Finder.
As I just mentioned in passing, you must quit DP between moves.
Sorry if that's obvious, Gary. :oops:
Go on Gary, give it a go.
It's free and you've nothing to lose.
Good luck, man.
Timeline
Post by Timeline »
While you were out enjoying your grommet meal I did just that my friend. :lol:
The bundles were defiantly wrong. I opened up the same tune and found still overloads of my UAD1e card and it was running around 95%. Anyway I dumped a few plugs and replaced with MAS AU's and reduced the loads. Better for sure. I took out PSP bundles and put them in the disabled folder as you recommend. Sad, I just bought the new warmer. Anyway, so far so good. Could be thought that the UAD1 card was duping me.
Still in discover mode so I'll let you know. Thanks a million for the brain rattling which I dearly needed mm.
cbergm7210
Post by cbergm7210 »
This also happens to me at least once a week. I can almost always blame my Liquid Mix plug for it.
LM is not making me very happy so far. Very unstable and I have to restart DP / Mac often while using it. I am hoping DP 6 will magically make this work better, but we'll see. Some days I see red all day.
Running a dual quad core with 8Gigs of RAM.
Chris
Dave Bourke
Post by Dave Bourke »
Nicky is right (as usual). Anything with a ".bundle" extension should be in your MAS folder. Only plug-ins with the ".component" extension belong in the Components folder.
Also, if you have duplicate versions of plug-ins installed ••“ for instance, PSP VintageWarmer.component in your Components folder and PSP VintageWarmer.bundle in your MAS folder ••“ DP may well freak out even though in theory it's supposed to only load the MAS version.
FishFillets.component is just wasting disk space since it's PPC only and will not work on an Intel machine. In fact, what you should do is bring up a file inspector in Finder (Option-Command-I) and select each of your plug-ins in turn. If any are described as "PPC" under "Kind," you can trash them since they won't work on your Mac ••“ only "Universal" is viable.
If you put executables in a folder where the system is not expecting to find them, you can expect problems. Unix is, after all, based entirely on file and folder paths, and, consequently, so is Mac OS X.
Dave Bourke
– ideation –
Mac Pro Quad Xeon 2.66 GHz, 5 Gb, OS X 10.5.8, iMac 24" 2.4 GHz Intel Core Duo, OS X 10.6.2, Mac G4 dual 800 MHz Quicksilver, DP 7.11, PCIe-424/24i, UAD-2 Quad/UAD-1e, PowerCore Firewire.
Timeline
Post by Timeline »
Thanks david. That fish found its way upstream when I migrated from my G5.
Cheers
Timeline
Post by Timeline »
After removing these and correcting the bundles here is my latest crash:
Process: Digital Performer [338]
Path: /MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/Digital Performer
Identifier: com.motu.DigitalPerformer
Version: 5.13 (5.13)
Code Type: X86 (Native)
Parent Process: launchd [90]
Date/Time: 2008-03-25 15:29:15.946 -0700
OS Version: Mac OS X 10.5.2 (9C7010)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000002ee83000
Crashed Thread: 11
Thread 0:
0 com.apple.CoreGraphics 0x9035ae35 CGAccessSessionGetChunks + 294
1 com.apple.CoreGraphics 0x9035b187 partial_get_bytes + 382
2 com.apple.CoreGraphics 0x9035af8f CGAccessSessionGetChunks + 640
3 com.apple.CoreGraphics 0x902bade5 img_decode_read + 425
4 com.apple.CoreGraphics 0x902bab53 img_colormatch_read + 380
5 com.apple.CoreGraphics 0x902ba978 img_alphamerge_read + 421
6 com.apple.CoreGraphics 0x902b8481 img_data_lock + 5496
7 com.apple.CoreGraphics 0x902b6529 CGSImageDataLock + 168
8 libRIP.A.dylib 0x90ae85ef ripc_AcquireImage + 3116
9 libRIP.A.dylib 0x90ad6d4f ripc_DrawImage + 3656
10 com.apple.CoreGraphics 0x902b62fd CGContextDrawImage + 397
11 com.apple.HIToolbox 0x92d08e98 HIViewDrawCGImage + 192
12 ...pspaudioware.plugins.pspvw2 0x417bb6b8 CBitmap::drawAlphaBlend(CDrawContext*, CRect&, CPoint const&, unsigned char) + 952
13 ...pspaudioware.plugins.pspvw2 0x417b780e CBitmap::draw(CDrawContext*, CRect&, CPoint const&) + 46
14 ...pspaudioware.plugins.pspvw2 0x417be9ed CViewContainer::draw(CDrawContext*) + 461
15 ...pspaudioware.plugins.pspvw2 0x417baf4f CViewContainer::update(CDrawContext*) + 271
16 ...pspaudioware.plugins.pspvw2 0x417b6461 CFrame::update(CDrawContext*) + 97
17 ...pspaudioware.plugins.pspvw2 0x417c2b3f CFrame::idle() + 143
18 ...pspaudioware.plugins.pspvw2 0x417e070d VintageWarmerEditor::idle() + 61
19 ...pspaudioware.plugins.pspvw2 0x417a4993 AudioEffect::dispatcher(int, int, int, void*, float) + 899
20 ...pspaudioware.plugins.pspvw2 0x417a69bc AudioEffectX::dispatcher(int, int, int, void*, float) + 316
21 com.pspaudioware.effects.vw2 0x201f5949 VST2AU::Dispatcher(int, int, int, void*, float) + 161
22 com.pspaudioware.effects.vw2 0x201f5d08 timerCallback(__CFRunLoopTimer*, void*) + 186
23 com.apple.CoreFoundation 0x925eeb5e CFRunLoopRunSpecific + 4494
24 com.apple.CoreFoundation 0x925eed18 CFRunLoopRunInMode + 88
25 com.apple.HIToolbox 0x92c776a0 RunCurrentEventLoopInMode + 283
26 com.apple.HIToolbox 0x92d2b28f GetNextEventMatchingMask + 447
27 com.apple.HIToolbox 0x92d2af96 WNEInternal + 151
28 com.apple.HIToolbox 0x92d2aef5 WaitNextEvent + 54
29 PerfFoundation.dylib 0x01f83cbc SafeWaitNextEvent(unsigned short, EventRecordAdapter*, unsigned long, OpaqueRgnHandle*) + 52
30 com.motu.DigitalPerformer 0x005c3c71 0x1000 + 6040689
31 com.motu.DigitalPerformer 0x005c3efd 0x1000 + 6041341
32 com.motu.DigitalPerformer 0x005c3fbc 0x1000 + 6041532
33 com.motu.DigitalPerformer 0x005c48f9 0x1000 + 6043897
34 com.motu.DigitalPerformer 0x00003466 0x1000 + 9318
35 com.motu.DigitalPerformer 0x0000338d 0x1000 + 9101
Thread 1:
0 libSystem.B.dylib 0x9468fb06 mach_wait_until + 10
1 libSystem.B.dylib 0x9470772f nanosleep + 314
2 libSystem.B.dylib 0x947075ef usleep + 61
3 PerfMSL.dylib 0x02103ea6 PerfAssert::SetEnableDebugMsgs(bool) + 4746
4 PerfMSL.dylib 0x02103bcf PerfAssert::SetEnableDebugMsgs(bool) + 4019
5 libSystem.B.dylib 0x946c0c55 _pthread_start + 321
6 libSystem.B.dylib 0x946c0b12 thread_start + 34
Thread 2:
0 libSystem.B.dylib 0x9468f9e6 mach_msg_trap + 10
1 libSystem.B.dylib 0x946971dc mach_msg + 72
2 libSystem.B.dylib 0x9470556b mach_msg_server + 675
3 PerfMSL.dylib 0x02101e43 catch_exception_raise_state + 527
4 libSystem.B.dylib 0x946c0c55 _pthread_start + 321
5 libSystem.B.dylib 0x946c0b12 thread_start + 34
Thread 3:
2 PerfFoundation.dylib 0x01fc645f PerfWorkerThread::GetThread() + 831
3 PerfFoundation.dylib 0x01fc655d PerfWorkerThread::GetThread() + 1085
Thread 4:
0 libSystem.B.dylib 0x9468fa3a semaphore_timedwait_trap + 10
1 AllUtilities.dylib 0x00e643bd PerfSemaphore::timed_wait(long) + 115
2 PerfEngine.dylib 0x01af232a PerfAudioCache::RunJobs(std::vector<workq_ele_t*, std::allocator<workq_ele_t*> >&) + 662
3 PerfEngine.dylib 0x01af2355 PerfAudioCache::RunJobs(std::vector<workq_ele_t*, std::allocator<workq_ele_t*> >&) + 705
Thread 5:
2 com.apple.audio.MIDI.CoreMIDI 0x00e37f0f XServerMachPort::ReceiveMessage(int&, void*, int&) + 101
3 com.apple.audio.MIDI.CoreMIDI 0x00e2a477 MIDIInPortThread::Run() + 111
4 com.apple.audio.MIDI.CoreMIDI 0x00e2e07d XThread::RunHelper(void*) + 17
5 com.apple.audio.MIDI.CoreMIDI 0x00e389ee CAPThread::Entry(CAPThread*) + 96
6 libSystem.B.dylib 0x946c0c55 _pthread_start + 321
7 libSystem.B.dylib 0x946c0b12 thread_start + 34
Thread 6:
2 com.apple.CoreFoundation 0x925ee0de CFRunLoopRunSpecific + 1806
3 com.apple.CoreFoundation 0x925eed18 CFRunLoopRunInMode + 88
4 com.apple.audio.CoreAudio 0x9546f464 HALRunLoop::OwnThread(void*) + 160
5 com.apple.audio.CoreAudio 0x9546f300 CAPThread::Entry(CAPThread*) + 96
Thread 7:
2 com.motu.MAS.framework 0x01647717 0x15ff000 + 296727
3 com.motu.MAS.framework 0x01647848 0x15ff000 + 297032
Thread 8:
0 libSystem.B.dylib 0x9468fa22 semaphore_wait_trap + 10
1 com.motu.MAS.framework 0x016466eb 0x15ff000 + 292587
2 com.motu.MAS.framework 0x01602ae7 0x15ff000 + 15079
3 com.motu.MAS.framework 0x01602e5f 0x15ff000 + 15967
4 com.motu.MAS.framework 0x0160a0b9 0x15ff000 + 45241
5 com.motu.MAS.framework 0x01646fa5 0x15ff000 + 294821
Thread 9:
1 ...ple.CoreServices.CarbonCore 0x9562a3eb MPDelayUntil + 39
2 ...ple.CoreServices.CarbonCore 0x9562a27f Delay + 104
3 ...opellerheads.rewire.library 0x1e99b7e8 RWPUnregisterDeviceImp + 21574
4 ...opellerheads.rewire.library 0x1e9b6a5c RWPUnregisterDeviceImp + 132794
Thread 10:
2 com.motu.MAS.framework 0x016657f4 0x15ff000 + 419828
3 com.motu.MAS.framework 0x01665875 0x15ff000 + 419957
Thread 11 Crashed:
0 ...pspaudioware.plugins.pspvw2 0x417dab40 VintageWarmer::processReplacing(float**, float**, int) + 1216
1 com.pspaudioware.effects.vw2 0x201f8121 VST2AU::Render(unsigned long&, AudioTimeStamp const&, unsigned long) + 1165
2 com.pspaudioware.effects.vw2 0x2021370e AUBase::DoRender(unsigned long&, AudioTimeStamp const&, unsigned long, unsigned long, AudioBufferList&) + 730
3 com.pspaudioware.effects.vw2 0x20212504 AUBase::ComponentEntryDispatch(ComponentParameters*, AUBase*) + 410
4 com.pspaudioware.effects.vw2 0x201f6fd7 VST2AUEntry + 33
5 ...ple.CoreServices.CarbonCore 0x955fb5cd CallComponentDispatch + 29
6 ...apple.audio.units.AudioUnit 0x93293af3 AudioUnitRender + 67
7 com.MOTU.MAS.AudioUnitSupport 0x1a1962f0 AudioUnits::Base::render(unsigned long&, AudioTimeStamp const&, unsigned long, unsigned long, AudioBufferList*) + 66
8 com.MOTU.MAS.AudioUnitSupport 0x1a1a9793 MasAUSupportProc::Process(MotuException*, float**, MasBufferInfo*, IMasEffectContext*) + 2549
9 com.motu.MAS.framework 0x016364fd 0x15ff000 + 226557
10 com.motu.MAS.framework 0x01664056 0x15ff000 + 413782
11 com.motu.MAS.framework 0x016657bd 0x15ff000 + 419773
12 com.motu.MAS.framework 0x01665875 0x15ff000 + 419957
13 libSystem.B.dylib 0x946c0c55 _pthread_start + 321
14 libSystem.B.dylib 0x946c0b12 thread_start + 34
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
0 libSystem.B.dylib 0x9468fa46 semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x946c1daf _pthread_cond_wait + 1244
2 libSystem.B.dylib 0x946c3633 pthread_cond_timedwait_relative_np + 47
3 com.apple.audio.CoreAudio 0x9547ea47 CAGuard::WaitFor(unsigned long long) + 213
4 com.apple.audio.CoreAudio 0x95480602 CAGuard::WaitUntil(unsigned long long) + 70
5 com.apple.audio.CoreAudio 0x9547eda7 HP_IOThread::WorkLoop() + 759
6 com.apple.audio.CoreAudio 0x9547eaab HP_IOThread::ThreadEntry(HP_IOThread*) + 17
7 com.apple.audio.CoreAudio 0x9546f300 CAPThread::Entry(CAPThread*) + 96
8 libSystem.B.dylib 0x946c0c55 _pthread_start + 321
9 libSystem.B.dylib 0x946c0b12 thread_start + 34
Thread 19:
1 PerfEngine.dylib 0x018efea3 InsideAnInterrupt() + 1401
2 libSystem.B.dylib 0x946c0c55 _pthread_start + 321
3 libSystem.B.dylib 0x946c0b12 thread_start + 34
Thread 20:
1 Kontakt2.MusicDevice.component 0x25627393 NI::GP::HEvent::wait() + 19
2 Kontakt2.MusicDevice.component 0x255e98b5 BAsyncReadWorker::ReadWorkerThreadProc() + 37
3 Kontakt2.MusicDevice.component 0x25626ed7 NI::GP::Thread::execute(void*) + 71
Thread 21:
2 Kontakt2.MusicDevice.component 0x255a51ef BEngine::ScriptSetEngineParThreadProc() + 31
Thread 22:
2 Kontakt2.MusicDevice.component 0x25590928 BEngine::AuxProcessThreadProc() + 72
Thread 23:
Thread 24:
3 PerfFoundation.dylib 0x01fc830c GetUnitTestRandomLong() + 106
Thread 25:
Thread 26:
Thread 27:
Thread 28:
3 ...ple.CoreServices.CarbonCore 0x955f292a TSWaitOnConditionTimedRelative + 246
4 ...ple.CoreServices.CarbonCore 0x955f270a TSWaitOnSemaphoreCommon + 422
5 ...ple.CoreServices.CarbonCore 0x955f240b AsyncFileThread(void*) + 73
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
0 libSystem.B.dylib 0x94696bce __semwait_signal + 10
1 libSystem.B.dylib 0x946c18cd pthread_cond_wait$UNIX2003 + 73
2 com.apple.ColorSync 0x9628b460 pthreadSemaphoreWait(t_pthreadSemaphore*) + 42
3 com.apple.ColorSync 0x9629dd92 CMMConvTask(void*) + 54
Thread 34:
Thread 35:
Thread 36:
Thread 37:
Thread 38:
Thread 39:
Thread 40:
5 ...ickTimeComponents.component 0x90bd580a ReadSchedulerThreadEntryPoint + 4724
Thread 11 crashed with X86 Thread State (32-bit):
eax: 0x4199e010 ebx: 0x417da68e ecx: 0x2ee83000 edx: 0x00000000
edi: 0x4199e010 esi: 0x4199e010 ebp: 0xb059c5b8 esp: 0xb059c530
ss: 0x0000001f efl: 0x00010216 eip: 0x417dab40 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037
cr2: 0x2ee83000
Binary Images:
0x1000 - 0xa3eff7 +com.motu.DigitalPerformer 5.13 (5.13) <7771f5be77884003a32006073a78edd4> /MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/Digital Performer
0xe26000 - 0xe43ff7 com.apple.audio.MIDI.CoreMIDI 1.6 (42) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0xe5b000 - 0xe72fd4 +AllUtilities.dylib ??? (???) <fb4c3a6fd17a4ea0b1b921fb45b5f986> /MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/AllUtilities.dylib
0xe85000 - 0xec6fe3 +DPBasicUI.dylib ??? (???) <aca805617fdc412fb0c75ea9d0126ccf> /MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/DPBasicUI.dylib
0xef4000 - 0x1144feb +DPPart2.dylib ??? (???) <d682f75506694e0c9f1bcfaddb2cd084> /MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/DPPart2.dylib
0x1332000 - 0x133bfff +FileSystem.dylib ??? (???) <46da88de11544f75982482d9af88308a> /MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/FileSystem.dylib
0x1348000 - 0x1380ffb +GenericPanes.dylib ??? (???) <a95909762db044508b44fdfd0bd852a2> /MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/GenericPanes.dylib
0x13ca000 - 0x1474fe3 +HiLevelWrappers.dylib ??? (???) <7bc7b8389b27476c9b18cc33f0204ed2> /MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/HiLevelWrappers.dylib
0x14d9000 - 0x15bafe3 +com.motu.MidiSystem MidiSystem version 1.0 (1.0) <9b30ac432e0f44b19403b11809fa93d0> /MOTU DP5 Folder/Digital Performer 5.13.app/Contents/Frameworks/MidiSystem.framework/Versions/A/MidiSystem
0x15fa000 - 0x15fbfe3 +com.motu.MPO.framework MotuPublicObjects 3.1 (3.1) <92c3eca447ee4ce5b8f0c7f5867ee320> /MOTU DP5 Folder/Digital Performer 5.13.app/Contents/Frameworks/MotuPublicObjects.framework/Versions/A/MotuPublicObjects
0x15ff000 - 0x16a5ff3 +com.motu.MAS.framework 4.0.0 (4.0.0) <d19b3e45538c477ead407e103bebfe11> /MOTU DP5 Folder/Digital Performer 5.13.app/Contents/Frameworks/MotuAudioSystem.framework/Versions/A/MotuAudioSystem
0x16c7000 - 0x17a2ff7 +com.motu.DAE MotuDAE•„• 1.0 (1.0) <14030bce66d641adb3954b923cf28537> /MOTU DP5 Folder/Digital Performer 5.13.app/Contents/Frameworks/MotuDAE.framework/Versions/A/MotuDAE
0x17f2000 - 0x18aafc7 +OMF_AAF.dylib ??? (???) <884f6731dcbd497ba62644cf6b626eb1> /MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/OMF_AAF.dylib
0x18c6000 - 0x1d4afd3 +PerfEngine.dylib ??? (???) <b9e0dad0b31143fdb78c21f1981ce6ab> /MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/PerfEngine.dylib
0x1f6f000 - 0x1f73fff +PerfError.dylib ??? (???) <a20756beff954aec9eb3745fb2b5f9a1> /MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/PerfError.dylib
0x1f7a000 - 0x206dfe3 +PerfFoundation.dylib ??? (???) <082d5d942ff44a7ca14ae515ddf104c0> /MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/PerfFoundation.dylib
0x20ff000 - 0x2107ffe +PerfMSL.dylib ??? (???) <91b5b579f06840cda62307076d9d2420> /MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/PerfMSL.dylib
0x210e000 - 0x21ccfde +PureDSP.dylib ??? (???) <50b2224e053d4b5dbe1c8e426df9a3b1> /MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/PureDSP.dylib
0x2211000 - 0x2213fff +ResourceAccess.dylib ??? (???) <32c19923217241aea6cac0c0dfd5f8a6> /MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/ResourceAccess.dylib
0x2219000 - 0x222afff +XML.dylib ??? (???) <a951d1812a8d416881de01a0eddf91c4> /MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/XML.dylib
0x2238000 - 0x2256fe3 libexpat.1.dylib ??? (???) <eff8a63a23a7d07af62b36fdb329e393> /usr/lib/libexpat.1.dylib
0x27f7000 - 0x27f8fe1 com.apple.textencoding.unicode 2.2 (2.2) <542f2b8930d6bdf16c318ffea541acab> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x17767000 - 0x1777bfc7 +com.MOTU.plugin.AudioExport.CoreAudio 1.5.1 (1.0) <fcc623ab10a94dce94b09120fc6e4042> /Library/Audio/Plug-Ins/MOTU Audio Export/Core Audio Export.bundle/Contents/MacOS/Core Audio Export
0x17790000 - 0x1779bff9 +com.MOTU.plugin.AudioExport.LAME 1.2.1 (1.0) <2ef4a51363eb421b9eb8109f4630d7dc> /Library/Audio/Plug-Ins/MOTU Audio Export/LAME Audio Export.bundle/Contents/MacOS/LAME Audio Export
0x177a5000 - 0x177befcf +com.MOTU.plugin.AudioExport.QT 2.51 (1.0) <dbd2ad12dd684b95a76419de03a891a8> /Library/Audio/Plug-Ins/MOTU Audio Export/QuickTime Export.bundle/Contents/MacOS/QuickTime Export
0x1783e000 - 0x179ccfe7 com.apple.audio.codecs.Components 1.6.1 (1.6.1) /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
0x1846f000 - 0x18472fff com.apple.audio.AudioIPCPlugIn 1.0.4 (1.0.4) <8ab1f4e9dff77d4f66843719e9ff2928> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x18478000 - 0x1847dfff com.apple.audio.AppleHDAHALPlugIn 1.5.6 (1.5.6a19) /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x184af000 - 0x184d9fff com.apple.audio.SoundManager.Components 3.9.3 (3.9.3) /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
0x184df000 - 0x1851afff com.apple.QuickTimeFireWireDV.component 7.4.1 (14) /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x187d3000 - 0x18976fea +com.MOTU.MAS.plugin.ArcPan 2.4 (2.4) <5089eb9bb9444bec97974dcb177c64a0> /Library/Audio/Plug-Ins/MAS/Arc Panner.bundle/Contents/MacOS/Arc Panner
0x189fd000 - 0x18bd8fe2 +com.MOTU.MAS.plugin.Auralizer 2.4 (2.4) <891acd02fa4d4897932d3af0670be98f> /Library/Audio/Plug-Ins/MAS/Auralizer.bundle/Contents/MacOS/Auralizer
0x18cd1000 - 0x18e04fca +com.MOTU.MAS.plugin.AutoPan 4.3 (4.3) <726989ffa1574641a9c18bcb1513b8e6> /Library/Audio/Plug-Ins/MAS/AutoPan.bundle/Contents/MacOS/AutoPan
0x18e64000 - 0x18f70fea +com.MOTU.MAS.plugin.BassManager 2.3 (2.3) <acf5a4393f2c4569a60bd426deff3c7b> /Library/Audio/Plug-Ins/MAS/Bass Manager.bundle/Contents/MacOS/Bass Manager
0x18fd8000 - 0x19253fff +com.motu.mas.plugin.BassLine 1.1.1 (1.1.1) <9ff7432ec5dd48d1bcfdec2921e2f97c> /Library/Audio/Plug-Ins/MAS/BassLine.bundle/Contents/MacOS/BassLine
0x192d3000 - 0x193a0fe7 +com.MOTU.MAS.plugin.Buffy 2.4 (2.4) <dc7efed4857e4414b1fc2dee9a5b277b> /Library/Audio/Plug-Ins/MAS/Buffy.bundle/Contents/MacOS/Buffy
0x193dd000 - 0x1951bfea +com.MOTU.MAS.plugin.Calibration 2.3 (2.3) <bfecf7ce3d61421fbf68bb44d87e3309> /Library/Audio/Plug-Ins/MAS/Calibration.bundle/Contents/MacOS/Calibration
0x19578000 - 0x19688fea +com.MOTU.MAS.plugin.Chorus 3.3 (3.3) <bb6ce1d6b8ab4ae6ab22415d6f129cca> /Library/Audio/Plug-Ins/MAS/Chorus.bundle/Contents/MacOS/Chorus
0x196e4000 - 0x1979ffdb +com.MOTU.MAS.plugin.DCNotch 4.3 (4.3) <0d3fa52c3e57448d987f58d45a1f7ac2> /Library/Audio/Plug-Ins/MAS/DCNotch.bundle/Contents/MacOS/DCNotch
0x197d3000 - 0x199a5fea +com.MOTU.MAS.plugin.Delay 3.3.1 (3.3.1) <d51097abda194e0c9c178eb61a06f078> /Library/Audio/Plug-Ins/MAS/Delay.bundle/Contents/MacOS/Delay
0x19aac000 - 0x19bc1fca +com.MOTU.MAS.plugin.Dynamics 3.3 (3.3) <d11ff747976e4939bb6dba1eac4f749f> /Library/Audio/Plug-Ins/MAS/Dynamics.bundle/Contents/MacOS/Dynamics
0x19c10000 - 0x19d24fca +com.MOTU.MAS.plugin.Echo 3.3 (3.3) <09d3d1e90c73422995458cdfc8a93247> /Library/Audio/Plug-Ins/MAS/Echo.bundle/Contents/MacOS/Echo
0x19d79000 - 0x19f4bfea +com.MOTU.MAS.plugin.eVerb 4.4 (4.4) <9a1c653bfd74450f9661e454c52a67ef> /Library/Audio/Plug-Ins/MAS/eVerb.bundle/Contents/MacOS/eVerb
0x19fbf000 - 0x1a0e3fea +com.MOTU.MAS.plugin.Flanger 4.3 (4.3) <7be663d06b5844aab316febf6f18fd7e> /Library/Audio/Plug-Ins/MAS/Flanger.bundle/Contents/MacOS/Flanger
0x1a153000 - 0x1a167fff +com.MOTU.MAS.plugin.InvertPhase 1.1.1 (1.0) <fe10cb13f3db41a285814d4fd82d0899> /Library/Audio/Plug-Ins/MAS/InvertPhase.bundle/Contents/MacOS/InvertPhase
0x1a17f000 - 0x1a1dbfff +com.MOTU.MAS.AudioUnitSupport 1.6.1 (1.0) <88f3bce603fc4a9c91ca3457b422f4b5> /Library/Audio/Plug-Ins/MAS/MAS AudioUnit Support.bundle/Contents/MacOS/MAS AudioUnit Support
0x1a5c0000 - 0x1a6cafef com.apple.RawCamera.bundle 2.0.4 (2.0.4) /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x1ad02000 - 0x1ad31ff6 +com.pspaudioware.effects.vintagewarmer ??? (2.1.4) /Library/Audio/Plug-Ins/Components/PSP VintageWarmer.component/Contents/MacOS/PSP VintageWarmer
0x1ad51000 - 0x1ae84fca +com.MOTU.MAS.plugin.MWCompressor 3.4 (3.4) <69b37458d2f046b2b2ccd1193f597ebd> /Library/Audio/Plug-Ins/MAS/MasterWorks Compressor.bundle/Contents/MacOS/MasterWorks Compressor
0x1aedd000 - 0x1b08ffca +com.MOTU.MAS.plugin.MWEQ 1.3 (1.3) <290dabe83a3a4ebc93840e7e59ef6b1d> /Library/Audio/Plug-Ins/MAS/MasterWorks EQ.bundle/Contents/MacOS/MasterWorks EQ
0x1b27d000 - 0x1b3bbff2 +com.MOTU.MAS.plugin.MWGate 2.3 (2.3) <eb2f4cb7b46641f99aa3ecffafa1364c> /Library/Audio/Plug-Ins/MAS/MasterWorks Gate.bundle/Contents/MacOS/MasterWorks Gate
0x1b412000 - 0x1b5acfd4 +com.MOTU.MAS.plugin.MWLimiter 4.3 (4.3) <1547046e0bc246e7b0aaaf62e898e837> /Library/Audio/Plug-Ins/MAS/MasterWorks Limiter.bundle/Contents/MacOS/MasterWorks Limiter
0x1b626000 - 0x1badefff +com.MOTU.MAS.plugin.Model12 1.1.1 (1.1.1) <bf0e11f9840d408f9487985560e3c736> /Library/Audio/Plug-Ins/MAS/Model12.bundle/Contents/MacOS/Model12
0x1bbb2000 - 0x1c066fff +com.motu.mas.plugin.modulo 1.1.2 (1.1.2) <c0324196bfde4b66bd477b9e1b14a0eb> /Library/Audio/Plug-Ins/MAS/Modulo.bundle/Contents/MacOS/Modulo
0x1c166000 - 0x1c237fea +com.MOTU.MAS.plugin.MSDecoder 2.3 (2.3) <bb0fac780e534c9faece8b7f379c0d44> /Library/Audio/Plug-Ins/MAS/MS Decoder.bundle/Contents/MacOS/MS Decoder
0x1c274000 - 0x1c3cdfca +com.MOTU.MAS.plugin.MultiModeFilter 2.3 (2.3) <d965ae34a2344ac99895959d606565c0> /Library/Audio/Plug-Ins/MAS/Multimode Filter.bundle/Contents/MacOS/Multimode Filter
0x1c433000 - 0x1c5c4fea +com.MOTU.MAS.plugin.MultiPan 2.4 (2.4) <c42112f94b334a37907ffca8175e88a5> /Library/Audio/Plug-Ins/MAS/n-Panner.bundle/Contents/MacOS/n-Panner
0x1c64b000 - 0x1cac4fdf +com.motu.mas.plugin.nanosampler 1.1.2 (1.1.2) <e6d85159035b4ba888f9857c96a9f251> /Library/Audio/Plug-Ins/MAS/nanosampler.bundle/Contents/MacOS/nanosampler
0x1cbca000 - 0x1cd8bfea +com.MOTU.MAS.plugin.ParaEQ 4.3.1 (4.3.1) <806c66a5fb4a4de0bd7797a5715ea122> /Library/Audio/Plug-Ins/MAS/ParaEQ.bundle/Contents/MacOS/ParaEQ
0x1cdfe000 - 0x1cf30fef +com.MOTU.MAS.plugin.PatternGate 1.2.1 (1.2.1) <9eddbe106cbb484ebccbd41c7818eab8> /Library/Audio/Plug-Ins/MAS/PatternGate.bundle/Contents/MacOS/PatternGate
0x1d004000 - 0x1d121fea +com.MOTU.MAS.plugin.Phaser 4.3 (4.3) <7fc5520eb6f0490bb378239934811f07> /Library/Audio/Plug-Ins/MAS/Phaser.bundle/Contents/MacOS/Phaser
0x1d179000 - 0x1d2b8fea +com.MOTU.MAS.plugin.Plate 2.3 (2.3) <76f19d33f45f4c05968179924b1460db> /Library/Audio/Plug-Ins/MAS/Plate.bundle/Contents/MacOS/Plate
0x1d332000 - 0x1d5d2fff +com.motu.mas.plugin.PolySynth 1.1.1 (1.1.1) <7d66f8e42c024c7793ac926350f2cacd> /Library/Audio/Plug-Ins/MAS/PolySynth.bundle/Contents/MacOS/PolySynth
0x1d67d000 - 0x1d67eff3 ATSHI.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0x1d686000 - 0x1d7bfffc +com.MOTU.MAS.plugin.Preamp 3.3 (3.3) <ea95fdc5294f4df7b8c1584549e487e5> /Library/Audio/Plug-Ins/MAS/Preamp-1.bundle/Contents/MacOS/Preamp-1
0x1d81c000 - 0x1dbc8fff +com.motu.mas.plugin.proton 1.1.2 (1.1.2) <84d248b9dc444deda6826ae145683f69> /Library/Audio/Plug-Ins/MAS/Proton.bundle/Contents/MacOS/Proton
0x1dc70000 - 0x1dd4dfd6 +com.MOTU.MAS.plugin.QuanJr 2.3 (2.3) <d84caf97bde84cd3982ffd61845d3deb> /Library/Audio/Plug-Ins/MAS/Quan Jr.bundle/Contents/MacOS/Quan Jr
0x1dd8d000 - 0x1de61fea +com.MOTU.MAS.plugin.Reverb 3.3 (3.3) <fa135c3c775c4271843ea870e774779f> /Library/Audio/Plug-Ins/MAS/Reverb.bundle/Contents/MacOS/Reverb
0x1de9d000 - 0x1deafff6 +com.MOTU.MAS.plugin.Reverse 1.1.1 (1.0) <22effc4798c9410190527ea6a09a3a85> /Library/Audio/Plug-Ins/MAS/Reverse.bundle/Contents/MacOS/Reverse
0x1debb000 - 0x1dfcdfdb +com.MOTU.MAS.plugin.RingMod 2.3 (2.3) <b1f493ecbae946f29fdfa548d18890b6> /Library/Audio/Plug-Ins/MAS/RingMod.bundle/Contents/MacOS/RingMod
0x1e01e000 - 0x1e19efda +com.MOTU.MAS.plugin.SonicModulator 3.3 (3.3) <aa2234884b834cb3a9583a7bf660fc69> /Library/Audio/Plug-Ins/MAS/Sonic Modulator.bundle/Contents/MacOS/Sonic Modulator
0x1e214000 - 0x1e328fea +com.MOTU.MAS.plugin.Tremolo 4.3 (4.3) <e60197503909433b873977f2a0ebb9c3> /Library/Audio/Plug-Ins/MAS/Tremolo.bundle/Contents/MacOS/Tremolo
0x1e388000 - 0x1e4adff7 +com.MOTU.MAS.plugin.Trigger 2.3.1 (2.3.1) <d6311f09080542969e8e366e5db49b2e> /Library/Audio/Plug-Ins/MAS/Trigger.bundle/Contents/MacOS/Trigger
0x1e503000 - 0x1e628ff3 +com.MOTU.MAS.plugin.Trim 4.3 (4.3) <ca3386f319764e048c922ec9c9bbacf6> /Library/Audio/Plug-Ins/MAS/Trim.bundle/Contents/MacOS/Trim
0x1e694000 - 0x1e83cfd6 +com.MOTU.MAS.plugin.TriPan 2.4 (2.4) <87cd700738cc4d74883d42209955d946> /Library/Audio/Plug-Ins/MAS/TriPan.bundle/Contents/MacOS/TriPan
0x1e990000 - 0x1e9effe1 +se.propellerheads.rewire.library 1.7 (1.7) /Library/Application Support/Propellerhead Software/ReWire/ReWire.bundle/Contents/MacOS/ReWire
0x1ea0e000 - 0x1ea2cfe7 com.apple.OpenTransport 3.0 (3.0) /System/Library/PrivateFrameworks/OpenTransport.framework/OpenTransport
0x1ed28000 - 0x1ed3afff libTraditionalChineseConverter.dylib ??? (???) <c9672ad2aba7312af00ec6a4690bb89d> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x1ed3e000 - 0x1ed4cfeb libSimplifiedChineseConverter.dylib ??? (???) <1c60d5ddc447ced14b48d883ecfd2f81> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x1f19c000 - 0x1f1ceff3 +com.MOTU.plugin.ControlSurface.MackieControl 1.2.2 (1.0) <397f91af4bbb4d4e9cbae5ff237c9838> /Library/Audio/Plug-Ins/MOTU Control Surface/MackieControl.bundle/Contents/MacOS/MackieControl
0x1f1f2000 - 0x1f22cff3 +com.MOTU.plugin.ControlSurface.SAC_2_2 3.2.1 (1.0) <d93c04e17f2a4b38a2baff85eb6cd14f> /Library/Audio/Plug-Ins/MOTU Control Surface/SAC DP Driver.bundle/Contents/MacOS/SAC DP Driver
0x1ffb7000 - 0x1ffdafc7 +com.uaudio.effects.UAD Precision Limiter 4.9.0 (4.9.0) <5b4d4a08800c4987a8b95d934f1d8bf3> /Library/Audio/Plug-Ins/Components/UAD Precision Limiter.component/Contents/MacOS/UAD Precision Limiter
0x1ffe2000 - 0x20005fe7 +com.uaudio.effects.UAD SPL Transient Designer 4.9.0 (4.9.0) <d2c11f1b0a7a49d8b9df7033e2d61f45> /Library/Audio/Plug-Ins/Components/UAD SPL Transient Designer.component/Contents/MacOS/UAD SPL Transient Designer
0x2000d000 - 0x20030fe7 +com.uaudio.effects.UAD 1176LN 4.9.0 (4.9.0) <6757a86a39c243a48f81a9dfede0abaa> /Library/Audio/Plug-Ins/Components/UAD 1176LN.component/Contents/MacOS/UAD 1176LN
0x20038000 - 0x2005bfe7 +com.uaudio.effects.UAD Pultec 4.9.0 (4.9.0) <c8064b5ee3c947dc9b4724c7af0f0718> /Library/Audio/Plug-Ins/Components/UAD Pultec.component/Contents/MacOS/UAD Pultec
0x20063000 - 0x20086fe7 +com.uaudio.effects.UAD 1176SE 4.9.0 (4.9.0) <cc1f9811a8934b99b65c1e2f43170ff2> /Library/Audio/Plug-Ins/Components/UAD 1176SE.component/Contents/MacOS/UAD 1176SE
0x2008e000 - 0x200b1fe7 +com.uaudio.effects.UAD LA2A 4.9.0 (4.9.0) <b22c77cf5bf549e6b2c9fe77e31d1506> /Library/Audio/Plug-Ins/Components/UAD LA2A.component/Contents/MacOS/UAD LA2A
0x200b9000 - 0x200dcfc7 +com.uaudio.effects.UAD Precision Equalizer 4.9.0 (4.9.0) <977bbe7efe254e4da749931e615b2881> /Library/Audio/Plug-Ins/Components/UAD Precision Equalizer.component/Contents/MacOS/UAD Precision Equalizer
0x200e4000 - 0x20107fc7 +com.uaudio.effects.UAD Precision Maximizer 4.9.0 (4.9.0) <4d1330cb84eb4d5cae6ecdba18429fe3> /Library/Audio/Plug-Ins/Components/UAD Precision Maximizer.component/Contents/MacOS/UAD Precision Maximizer
0x2010f000 - 0x20132fc7 +com.uaudio.effects.UAD Pultec-Pro 4.9.0 (4.9.0) <3c77b39878d34a0b8ebff6244babe95f> /Library/Audio/Plug-Ins/Components/UAD Pultec-Pro.component/Contents/MacOS/UAD Pultec-Pro
0x2013a000 - 0x2015dfc7 +com.uaudio.effects.UAD Precision Multiband 4.9.0 (4.9.0) <45f08238fd0444b59b4db829982aac09> /Library/Audio/Plug-Ins/Components/UAD Precision Multiband.component/Contents/MacOS/UAD Precision Multiband
0x20165000 - 0x20188fc7 +com.uaudio.effects.UAD Precision De-Esser 4.9.0 (4.9.0) <f4ab101fcbe64cd3bf1123dfe041ce77> /Library/Audio/Plug-Ins/Components/UAD Precision De-Esser.component/Contents/MacOS/UAD Precision De-Esser
0x20190000 - 0x201b3fe7 +com.uaudio.effects.UAD Precision Buss Compressor 4.9.0 (4.9.0) <328d30e0048148ffbf6dcd2c2d71bd04> /Library/Audio/Plug-Ins/Components/UAD Precision Buss Compressor.component/Contents/MacOS/UAD Precision Buss Compressor
0x201d8000 - 0x201ebff4 +com.smartelectronix.magnus.Ambience 1.0.6 (1.0.6) /Library/Audio/Plug-Ins/Components/Ambience.component/Contents/MacOS/Ambience
0x201f4000 - 0x20223fd6 +com.pspaudioware.effects.vw2 ??? (2.1.4) /Library/Audio/Plug-Ins/Components/PSP VintageWarmer2.component/Contents/MacOS/PSP VintageWarmer2
0x20243000 - 0x202b8fff +com.Syncrosoft.Synsoacc ??? (1.8.2.9) /Library/Application Support/Syncrosoft/pos/Synsoacc.bundle/Contents/MacOS/Synsoacc
0x2037d000 - 0x20386ff7 com.apple.iokit.IOUSBLib 3.0.0 (3.0.0) <3dc62c82eabba24f96af44fad0b3aa83> /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0x2039e000 - 0x203c8fd3 +com.Antares.musiceffects.AutoTuneAU_SS.component 5.1.0 (5.1.0) /Library/Audio/Plug-Ins/Components/AutoTuneAU_SS.component/Contents/MacOS/AutoTuneAU_SS
0x2041f000 - 0x20442fed com.apple.audio.OpenAL 1.2 (1.2) <d2b9567e2f3e44ef025556bffbb1aeb9> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
0x204d8000 - 0x2053dfcf +[Unknown Bundle] ??? (???) <4f004619d2ff477aa5b42cf994fbff1f> [Unknown Bundle]
0x205b6000 - 0x205c1adf +com.WavesAudio.RVox.5.9.7 5.9.7 (5.9.7) /Applications/Waves/Waves Plug-Ins/RVox.bundle/Contents/MacOS/RVox
0x2061a000 - 0x2084bfe4 +com.steinberg.Virtual Guitarist 2 FX.AU 2.0.0.425 (???) /Library/Audio/Plug-Ins/Components/Virtual Guitarist 2 FX.component/Contents/MacOS/Virtual Guitarist 2 FX
0x20946000 - 0x20953fc3 +com.WavesAudio.RDeEsser.5.9.7 5.9.7 (5.9.7) /Applications/Waves/Waves Plug-Ins/RDeEsser.bundle/Contents/MacOS/RDeEsser
0x209b6000 - 0x209c3adf +com.WavesAudio.RenAx.5.9.7 5.9.7 (5.9.7) /Applications/Waves/Waves Plug-Ins/RenAxx.bundle/Contents/MacOS/RenAx
0x20a52000 - 0x20a5e8ff +com.WavesAudio.RBass.5.9.7 5.9.7 (5.9.7) /Applications/Waves/Waves Plug-Ins/RBass.bundle/Contents/MacOS/RBass
0x20b48000 - 0x20cc58bf +com.WavesAudio.WaveShell-AU.5.9.7b1 5.9.7b1 (5.9.7) /Library/Audio/Plug-Ins/Components/WaveShell-AU 5.9.7.component/Contents/MacOS/WaveShell-AU
0x20fbe000 - 0x21023fcf +[Unknown Bundle] ??? (???) <be0d111586df47a5b01375c0f19c9c0b> [Unknown Bundle]
0x21a6a000 - 0x21c8ffeb +com.WavesAudio.WavesLib 5.9.7.framework 5.9.7 (5.9.7) /Applications/Waves/Waves Plug-Ins/WavesLib 5.9.7.framework/Versions/A/WavesLib
0x2208b000 - 0x220b5fd3 +com.Antares.musiceffects.AutoTuneAU_MM.component 5.1.0 (5.1.0) /Library/Audio/Plug-Ins/Components/AutoTuneAU_MM.component/Contents/MacOS/AutoTuneAU_MM
0x2212d000 - 0x22168fc4 +com.Antares.plugins.AutoTuneAU_MM 5.1.0 (5.1.0) <ffa8c2ead8934c7989f3e18461ac41ef> /Library/Audio/Plug-Ins/Components/AutoTuneAU_MM.component/Contents/Resources/AutoTuneAU_MM.bundle/Contents/MacOS/AutoTuneAU_MM
0x22430000 - 0x22495fcf +[Unknown Bundle] ??? (???) <4f004619d2ff477aa5b42cf994fbff1f> [Unknown Bundle]
0x22502000 - 0x22505fff +1000 ??? (???) /Users/garybrandt/Library/Caches/Waves/Applications/Waves/Waves Plug-Ins/RDeEsser.bundle/Contents/Resources/RDeEsser.rsrc/asIL/1000
0x22660000 - 0x22660ffd libmx.A.dylib ??? (???) /usr/lib/libmx.A.dylib
0x23097000 - 0x230d2fc4 +com.Antares.plugins.AutoTuneAU_SS 5.1.0 (5.1.0) <e6f931e23c934c1bbeae7f26ac430c18> /Library/Audio/Plug-Ins/Components/AutoTuneAU_SS.component/Contents/Resources/AutoTuneAU_SS.bundle/Contents/MacOS/AutoTuneAU_SS
0x2330c000 - 0x23371fcf +[Unknown Bundle] ??? (???) <4f004619d2ff477aa5b42cf994fbff1f> [Unknown Bundle]
0x2484e000 - 0x2486b04f +com.uaudio.UAD Precision De-Esser 4.9.0 (4.9.0) <ac30222d701a4c7ea06795b6eb6e0556> /Library/Audio/Plug-Ins/Components/UAD Precision De-Esser.component/Contents/Resources/UAD Precision De-Esser.vst/Contents/MacOS/UAD Precision De-Esser
0x24880000 - 0x248d1feb +com.uaudio.UAD_GUI_Library 4.9.0 (4.9.0) <0e72d8d4b4f74b2c9c5b5ded724e4980> /Library/Frameworks/UAD GUI Library.framework/Versions/A/UAD GUI Library
0x24a22000 - 0x24a4cff1 +com.uaudio.UAD Precision Equalizer 4.9.0 (4.9.0) <c8d363182fbc4de08f59239a010caaba> /Library/Audio/Plug-Ins/Components/UAD Precision Equalizer.component/Contents/Resources/UAD Precision Equalizer.vst/Contents/MacOS/UAD Precision Equalizer
0x24c79000 - 0x24c97fd9 +com.uaudio.UAD Precision Limiter 4.9.0 (4.9.0) <d91a7ee4570d4888b238c96cc115af2d> /Library/Audio/Plug-Ins/Components/UAD Precision Limiter.component/Contents/Resources/UAD Precision Limiter.vst/Contents/MacOS/UAD Precision Limiter
0x25469000 - 0x25e6805e +Kontakt2.MusicDevice.component 2.2.4.001 (2.2.4, Copyright © 2007 Native Instruments) /Library/Audio/Plug-Ins/Components/Kontakt2.component/Contents/MacOS/Kontakt2
0x2677f000 - 0x267b1fe6 +se.propellerheads.rex.library 1.6 (1.6) /Library/Application Support/Native Instruments/REX Shared Library.bundle/Contents/MacOS/REX Shared Library
0x27d1a000 - 0x27d1bfff +de.native-instruments.ni_dfd.macho.bundle 1.5.0.0 (NI_DFD_1_5 version 1.5.0.0) /Library/Application Support/Native Instruments/NI_DFD_1_5.bundle/Contents/MacOS/NI_DFD_1_5
0x27d1f000 - 0x27d48fef +de.native-instruments.ni_irc.macho.bundle 1.2.0.0 (NI_IRC_1_2 version 1.2.0.0) /Library/Application Support/Native Instruments/NI_IRC_1_2.bundle/Contents/MacOS/NI_IRC_1_2
0x27d52000 - 0x27f5efef +de.native-instruments.kconvert.macho.bundle 1.1.0.032 (1.1.0.032) /Library/Application Support/Native Instruments/kconvert.bundle/Contents/MacOS/kconvert
0x2e1c6000 - 0x2e72503f +com.steinberg.Hypersonic.AU 2.0.0.605 (2.0.0.605) /Library/Audio/Plug-Ins/Components/Hypersonic.component/Contents/MacOS/Hypersonic
0x31488000 - 0x3148dffb com.apple.AppleMPEG2Codec 1.0 (211) /Library/QuickTime/AppleMPEG2Codec.component/Contents/MacOS/AppleMPEG2Codec
0x3f4fb000 - 0x3f515fc3 com.apple.AppleIntermediateCodec 1.2 (145) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0x4179e000 - 0x417fc002 +com.pspaudioware.plugins.pspvw2 2.1.4 (2.1.4) /Library/Audio/Plug-Ins/Components/PSP VintageWarmer2.component/Contents/Resources/PSP VintageWarmer2.vst/Contents/MacOS/PSP VintageWarmer2
0x41aab000 - 0x41cebfd2 +net.telestream.wmv.import 2.2.0.49 (2.2.0.49) /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
0x41d23000 - 0x41ee5fea +net.telestream.wmv.advanced 2.2.0.49 (2.2.0.49) /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
0x41f29000 - 0x41f65fe3 com.apple.AppleVAFramework 4.0.16 (4.0.16) /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x41f6c000 - 0x41f86fe3 com.apple.applepixletvideo 1.2.10 (1.2d10) <fdac8dfc20ba5d49672d57e04d5c09a2> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0x70000000 - 0x700e3ff2 com.apple.audio.units.Components 1.5.1 (1.5.1) /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8fe00000 - 0x8fe2da53 dyld 96.2 (???) <7af47d3b00b2268947563c7fa8c59a07> /usr/lib/dyld
0x90006000 - 0x90035fe3 com.apple.AE 402.2 (402.2) <e01596187e91af5d48653920017b8c8e> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x90036000 - 0x90073fff com.apple.CoreMediaIOServicesPrivate 1.4 (1.4) /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
0x90074000 - 0x90084fff com.apple.speech.synthesis.framework 3.6.59 (3.6.59) <4ffef145fad3d4d787e0c33eab26b336> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x90085000 - 0x90085ffe com.apple.quartzframework 1.5 (1.5) <4b8f505e32e4f2d67967a276401f9aaf> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x90086000 - 0x90165fff libobjc.A.dylib ??? (???) <a53206274b6c2d42691f677863f379ae> /usr/lib/libobjc.A.dylib
0x90166000 - 0x901f1fff com.apple.framework.IOKit 1.5.1 (???) <a17f9f5ea7e8016a467e67349f4d3d03> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x9022c000 - 0x90237ff9 com.apple.helpdata 1.0 (14) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x90289000 - 0x9028effb com.apple.DisplayServicesFW 2.0 (2.0) <216d67a55304c851e9888616d9a32126> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x9028f000 - 0x90928fff com.apple.CoreGraphics 1.351.21 (???) <6c93fd21149f389129fe47fa6ef71880> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x90929000 - 0x909d9fff edu.mit.Kerberos 6.0.12 (6.0.12) <3dd13466876a8fe4549cfc1354233ec3> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x909e7000 - 0x90a66ff5 com.apple.SearchKit 1.2.0 (1.2.0) <277b460da86bc222785159fe77e2e2ed> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x90a67000 - 0x90a67ff8 com.apple.ApplicationServices 34 (34) <8f910fa65f01d401ad8d04cc933cf887> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x90aa6000 - 0x90ab5ffe com.apple.DSObjCWrappers.Framework 1.2.1 (1.2.1) <eac1c7b7c07ed3148c85934b6f656308> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
0x90ab6000 - 0x90ac1fe7 libCSync.A.dylib ??? (???) <482d16ba55f91a5dc05f78cc9db707a7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x90ac2000 - 0x90b03fe7 libRIP.A.dylib ??? (???) <9d42e83d860433f9126c4871d1fe0ce8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x90b04000 - 0x90bbefe3 com.apple.CoreServices.OSServices 224.4 (224.4) <ff5007ab220908ac54b6c661e447d593> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90bbf000 - 0x91b46fea com.apple.QuickTimeComponents.component 7.4.1 (14) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x91b47000 - 0x91b5ffff com.apple.openscripting 1.2.6 (???) <b8e553df643f2aec68fa968b3b459b2b> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x91b60000 - 0x91ca5ff7 com.apple.ImageIO.framework 2.0.1 (2.0.1) <68ba11e689a9ca30f8310935cd1e02d6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91cd9000 - 0x91d28fff com.apple.QuickLookUIFramework 1.1 (170.2) /System/Library/PrivateFrameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x9237a000 - 0x92401ff7 libsqlite3.0.dylib ??? (???) <6978bbcca4277d6ae9f042beff643f7d> /usr/lib/libsqlite3.0.dylib
0x92402000 - 0x9240afff com.apple.DiskArbitration 2.2.1 (2.2.1) <75b0c8d8940a8a27816961dddcac8e0f> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x9240b000 - 0x92438feb libvDSP.dylib ??? (???) <b232c018ddd040ec4e2c2af632dd497f> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x92439000 - 0x92463fff com.apple.CoreMediaPrivate 1.4 (1.4) <59630ee9096ecf2ca1e518da2f46c68d> /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate
0x92464000 - 0x924bdff7 libGLU.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x924be000 - 0x9251aff7 com.apple.htmlrendering 68 (1.1.3) <fe87a9dede38db00e6c8949942c6bd4f> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x9251b000 - 0x92522fe9 libgcc_s.1.dylib ??? (???) <a9ab135a5f81f6e345527df87f51bfc9> /usr/lib/libgcc_s.1.dylib
0x92523000 - 0x92568fef com.apple.Metadata 10.5.2 (398.7) <73a6424c06effc474e699cde6883de99> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9257b000 - 0x9257bffd com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x9257c000 - 0x926aefef com.apple.CoreFoundation 6.5.1 (476.10) <d5bed2688a5eea11a6dc3a3c5c17030e> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x926af000 - 0x926b3fff libGIF.dylib ??? (???) <b8f61e346fa243a7138910bed3dcdb6b> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x926b4000 - 0x926c0fe7 com.apple.opengl 1.5.6 (1.5.6) <d599b1bb0f8a8da6fd125e2587b27776> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x9292a000 - 0x92931ffe libbsm.dylib ??? (???) <d25c63378a5029648ffd4b4669be31bf> /usr/lib/libbsm.dylib
0x92932000 - 0x92c46fe2 com.apple.QuickTime 7.4.1 (14) <1a4838d29e0804a2a102f03c053600f0> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x92c47000 - 0x92f4ffff com.apple.HIToolbox 1.5.2 (???) <7449d6f2da33ded6936243a92e307459> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x92f50000 - 0x92f81ffb com.apple.quartzfilters 1.5.0 (1.5.0) <22581f8fe9dd2cb261f97a897407ec3e> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x92f8e000 - 0x92f94fff com.apple.print.framework.Print 218.0.2 (220.1) <8bf7ef71216376d12fcd5ec17e43742c> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x92f95000 - 0x93028ff3 com.apple.ApplicationServices.ATS 3.2 (???) <cdf31bd0ac7de54a35ee2d27cf86b6be> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x93059000 - 0x93120fff com.apple.QuickTimeMPEG4.component 7.4.1 (14) /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
0x93121000 - 0x93158fff com.apple.SystemConfiguration 1.9.1 (1.9.1) <8a76e429301afe4eba1330bfeaabd9f2> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x93159000 - 0x93159ffb com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/InstallServer
0x9315a000 - 0x93292ff7 libicucore.A.dylib ??? (???) <afcea652ff2ec36885b2c81c57d06d4c> /usr/lib/libicucore.A.dylib
0x93293000 - 0x93293ffc com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x93294000 - 0x932a8ff3 com.apple.ImageCapture 4.0 (5.0.0) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x932a9000 - 0x932a9ffe com.apple.MonitorPanelFramework 1.2.0 (1.2.0) <a2b462be6c51187eddf7d097ef0e0a04> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
0x932aa000 - 0x932c9ffa libJPEG.dylib ??? (???) <0dd7e9d7fb22174b78205a944144f9c3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x932ca000 - 0x932f2ff7 com.apple.shortcut 1 (1.0) <057783867138902b52bc0941fedb74d1> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x93452000 - 0x93459ff7 libCGATS.A.dylib ??? (???) <dd3161e6653fa6400b9ef9c144309fa5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x9345a000 - 0x934e3fe3 com.apple.DesktopServices 1.4.5 (1.4.5) <8b264cd6abbbd750928c637e1247269d> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x934e4000 - 0x9387aff7 com.apple.QuartzCore 1.5.1 (1.5.1) <665c80f6e28555b303020c8007c36b8b> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9387b000 - 0x9390efff com.apple.ink.framework 101.3 (86) <bf3fa8927b4b8baae92381a976fd2079> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x9391a000 - 0x9391dfff com.apple.help 1.1 (36) <b507b08e484cb89033e9cf23062d77de> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x9391e000 - 0x9392effc com.apple.LangAnalysis 1.6.4 (1.6.4) <cbeb17ab39f28351fe2ab5b82bf465bc> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x93995000 - 0x93b50ff3 com.apple.QuartzComposer 2.1 (106.3) <ed79ff3644e8883905ba3ba681742476> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x93b51000 - 0x93b51fff com.apple.Carbon 136 (136) <450e7e239de3f8e559c78f6473ec5149> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x93b62000 - 0x93c47ff3 com.apple.CoreData 100.1 (186) <8e28162ef2288692615b52acc01f8b54> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x93c48000 - 0x93c56ffd libz.1.dylib ??? (???) <5ddd8539ae2ebfd8e7cc1c57525385c7> /usr/lib/libz.1.dylib
0x93de5000 - 0x93e5fff8 com.apple.print.framework.PrintCore 5.5.2 (245.1) <3c9de512e95fbd838694ee5008d56a28> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x93ecd000 - 0x93ed4fff com.apple.agl 3.0.9 (AGL-3.0.9) <7dac4a7cb0de2f6d08ae71c1249379e3> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x93ed5000 - 0x93f47fff com.apple.PDFKit 2.1 (2.1) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x93f48000 - 0x93f6cfff libxslt.1.dylib ??? (???) <4933ddc7f6618743197aadc85b33b5ab> /usr/lib/libxslt.1.dylib
0x93f6d000 - 0x93f83fff com.apple.DictionaryServices 1.0.0 (1.0.0) <ad0aa0252e3323d182e17f50defe56fc> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x93f84000 - 0x940a8fe3 com.apple.audio.toolbox.AudioToolbox 1.5.1 (1.5.1) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x940a9000 - 0x940e8fef libTIFF.dylib ??? (???) <76301b3506f310fb454b58897c8d0a9f> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x940e9000 - 0x94187fef com.apple.QuickTimeImporters.component 7.4.1 (14) /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x94188000 - 0x94188ffd com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x94189000 - 0x94200fe3 com.apple.CFNetwork 221.5 (221.5) <5474cdd7d2a8b2e8059de249c702df9e> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x94250000 - 0x9425afeb com.apple.audio.SoundManager 3.9.2 (3.9.2) <0f2ba6e891d3761212cf5a5e6134d683> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x94278000 - 0x9427cfff libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
0x9427d000 - 0x9435eff7 libxml2.2.dylib ??? (???) <3cd4cccd4ca35dffa4688436aa0cd908> /usr/lib/libxml2.2.dylib
0x9435f000 - 0x94411ffb libcrypto.0.9.7.dylib ??? (???) <330b0e48e67faffc8c22dfc069ca7a47> /usr/lib/libcrypto.0.9.7.dylib
0x94412000 - 0x94413ffc libffi.dylib ??? (???) <a3b573eb950ca583290f7b2b4c486d09> /usr/lib/libffi.dylib
0x94414000 - 0x9468efe7 com.apple.Foundation 6.5.4 (677.15) <6216196287f98a65ddb654d04d773e7b> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x9468f000 - 0x947eeff3 libSystem.B.dylib ??? (???) <4899376234e55593b22fc370935f8cdf> /usr/lib/libSystem.B.dylib
0x949dc000 - 0x94ba7ff7 com.apple.security 5.0.2 (33001) <0788969ffe7961153219be10786da436> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x94ba8000 - 0x94beafef com.apple.NavigationServices 3.5.1 (161) <c07a4b33317f284825cb82929e8c877e> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x94beb000 - 0x94c16fe7 libauto.dylib ??? (???) <42d8422dc23a18071869fdf7b5d8fab5> /usr/lib/libauto.dylib
0x94c17000 - 0x94c17ff8 com.apple.Cocoa 6.5 (???) <e064f94d969ce25cb7de3cfb980c3249> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x94c18000 - 0x94c38ff2 libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x94c39000 - 0x94c3efff com.apple.CommonPanels 1.2.4 (85) <ea0665f57cd267609466ed8b2b20e893> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x94c3f000 - 0x94d76feb com.apple.imageKit 1.0.1 (1.0) <4cb353ae2d3b141afc3d82b557bde878> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x94d77000 - 0x94d77ffd com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x94d78000 - 0x94dc8ff7 com.apple.HIServices 1.7.0 (???) <f7e78891a6d08265c83dca8e378be1ea> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x94dc9000 - 0x94ddffe7 com.apple.CoreVideo 1.5.0 (1.5.0) <7e010557527a0e6d49147c297d16850a> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x94de0000 - 0x94dfeff3 com.apple.DirectoryService.Framework 3.5.1 (3.5.1) <96407dca4d6b1d10ae5ca1881e31b27a> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x94dff000 - 0x94ef3ff4 libiconv.2.dylib ??? (???) <c508c60fafca17824c0017b2e4369802> /usr/lib/libiconv.2.dylib
0x94ef4000 - 0x94f80ff7 com.apple.LaunchServices 286.5 (286.5) <33c3ae54abb276b61a99d4c764d883e2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x94f81000 - 0x94fdeffb libstdc++.6.dylib ??? (???) <04b812dcec670daa8b7d2852ab14be60> /usr/lib/libstdc++.6.dylib
0x94fdf000 - 0x95007fff libcups.2.dylib ??? (???) <2f0a710a9128882efb2ed92ad139b58c> /usr/lib/libcups.2.dylib
0x9501c000 - 0x9542cfef libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x95452000 - 0x954cefeb com.apple.audio.CoreAudio 3.1.0 (3.1) <a8b4350bc44d83c1cc50f2e0ac02f506> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x954cf000 - 0x955a2fef com.apple.QuickTimeH264.component 7.4.1 (14) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x955a3000 - 0x955acfff com.apple.speech.recognition.framework 3.7.24 (3.7.24) <d3180f9edbd9a5e6f283d6156aa3c602> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x955ad000 - 0x955c8ffb libPng.dylib ??? (???) <85ca18172d7a4b5a5be3574e4e879880> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x955c9000 - 0x958a2ff3 com.apple.CoreServices.CarbonCore 785.8 (785.8) <827c228e7d717b397cdb4941eba69553> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x958a3000 - 0x958fdff7 com.apple.CoreText 2.0.1 (???) <07494945ad1e3f5395599f42748457cc> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x9592f000 - 0x959fdff7 com.apple.JavaScriptCore 5525.13 (5525.13) <04772ff1212d98f31c613dde4d123698> /System/L
odarellmc
Post by odarellmc »
are you using fxpansion vst to au wrapper, or any other of the same type?
Macbook Pro 15" SR 2.4ghz 2g ram , FirmTek SeriTek/2SM2-E dual-bay hot swap sata drive enclosure, JBL 4206 & Mackie HR824, MOTU 2408 mkII, Mackie Onyx 400f, Rode NTK, MOTU MTPAV, OS 10.4.10, DP 5.13, Reason 4.0, Rob Papen Predator & Albino 3, Ozone 3,BFD v1.5, Roland xp-80, EMU e6400 ultra, Alesis ControlPad, Akai MPK49
Timeline
Post by Timeline »
Nope
leigh
Post by leigh »
Thread 11 Crashed:
It looks like Thread 11 crashed in Vintage Warmer. Are you using the latest version?
**Leigh
Dave Bourke
What were you doing when it crashed?
If you look at Thread 11, you'll find that it was the crasher. And lines 0-5 (lowest numbered lines are the last ones written) would seem to implicate PSP VintageWarmer 2. It's the first time I've ever seen references to "AUBase," "VST2AUEntry," and "VST2AU."
I wonder if PSP are wrapping VSTs as AUs using their own proprietary wrapper? I know Korg do this with the Legacy Collections, and TC used to do it with their Powercore plug-ins. But PSP? I use VW2 on my Mac Pro and I have no problems so far with it.
Try pulling it out of the Components folder and putting it in a new folder you create named "Components (Disabled)." If your crashes go away, you found the culprit and a reinstall might fix it.
Kind regards.
Dave Bourke
– ideation –
Timeline
Post by Timeline »
Great. Thanks for susing it. I recently downloaded the latest vers. Figure it would be them.
I'll stay away from that one for a bit and see what happens.
waterstrum
Post by waterstrum »
This is very scary to me.
I think I will limp along for a while on 10.4.11 on my old dual G5.
Gary, it sounds like there are still more culprits.
At this point, I'd be tempted to remove all 3rd party plugs (leaving only the MOTU MAS plugs in place), and give that a run, substituting missing plugs with MAS VIs and FX temporarily.
If that runs smoothly and that ridiculous load suddenly lightens, I'd begin adding plugs, starting with 3rd party MAS, then on to the AUs, saving those you suspect the most 'till last.
Easy peasy, man.
It's probably a product of our individual troubleshooting experiences that when things go wrong in DP you tend to look to hardware, whereas I look first to plugs.
Since my early PCI324 and RAM issues were sorted (OS9 days), every single glitch in DP apart from known issues has been attributable to plug-ins, and even then only because I've been a sucker for collecting freebies and many of them are badly written. :oops:
I honestly hope we're getting to the bottom of things here and that our Macs are good to go.
I'll bet we'd both sleep a whole lot better. :D
Oh, just an afterthought but do you really need all that RAM Gary?
Things just may run more smoothly with less heat around, methinks.
Timeline
Post by Timeline »
Thanks MM.
I'm changing my PSP warmer2 plug over to iLok. That may solve that crash issue but we'll see.
FWIW, I've tested freebies in the past that've pegged the CPU meter with only one instantiation.
I'd still do the bare bones thing and build 'em back up (and maybe trash your audio and possibly DP prefs); you may be surprised what unexpected or unforeseen gains are to be had.
After all, you haven't seen this machine perform to its full potential yet, you'd think.
OK, you'd hope. :D
This time I refuse to burn dinner again, so I'm outa here to watch a stove in action.
I'll check back in a while Gary. :D
