Issue Syncing Hardware To Ultralite
michael louis
Post by michael louis »
I am running Leopard on a MacBook, with the latest firmware/drivers installed on my Ultralite. I have a couple of drum machines/synths (Korg Electribes, Monomachine) chained to sync from the Ultralite's MIDI clock via Ableton Live. For some reason, the gear will randomly jump out of sync, and no matter what adjustments I make, which temporarily brings all the gear back into sync, the gear will suddenly and dramatically jump off sync. Has anyone else experienced this issue, or does anyone know what I can do to fix this :?: :!: :?: :!:
michael louis
anyone?
bueller?
1nput0utput
Post by 1nput0utput »
Are you sure that the UltraLite is the cause of the problem? Have you tried using a different MIDI interface?
michael louis
yes, i also have an m-audio firewire 18/14, and when used in the motu's place has no issues. once the proper MIDI delay on live is set, the machines will still in sync.
