4 Amp Heads, One Speaker Cab - I Need a "Head Switcher&
I have a bunch of great tube amps. When I record them, I run them through a Palmer PDI-03 Speaker simulator instead of a real speaker cabinet because I can't crank my amps in my apartment. They are just way too loud.
The Palmer accepts speaker cable from just one amp at a time. So if I want to go from one amp to another, I need to unplug and replug. It's a little bit of a hassle.
I'm wondering if there's a rackmountable "Amp Head Switcher" that I can run between my amp heads and the Palmer so I don't have to plug things in and out when I switch from amp to amp. The only product I know of is by Radial Engineering, it's called the Headbone. But that only allows for switching between 2 amp heads. Ideally, I'd like to be able to switch between 4 heads (or more).
If anyone knows of such a product, I'd greatly appreciate some info. Thanks!
24" iMac, 10.4.1?, DP 5.13, Traveler
- timriley
An exact answer to your question is NO! I cannot find a 4 way version of what you are looking....
I did find something called the Toadworks Roundabout (again only two channels im afraid) which does a very similar thing to the Tonebone but at half the price...
Im not sure it's exactly what you're looking for either but here is the link anyway!
http://www.pedalgeek.com/cgi-bin/new_sh ... link--twrb
Mac Pro Quad XEON/2.8Ghz/12GB RAM
Macbook Pro Core Duo/2.16Ghz/2GB RAM
OSX 10.6.8/DP7.22
OSX 10.6.8/DP7.22
- timriley
Also have you looked at 'voodoo labs' pedals?
http://www.voodoolab.com/products.htm
Their GCX audio switcher and amp selector might be of use.... Hope this helps!
OSX 10.6.8/DP7.22
OSX 10.6.8/DP7.22
3GHz 8 core, 6GB ram, DP 5.13, OSX.4.11, PTLE 7.4.2, Rosetta 200 digi003, waves platinum, mach five, distressors, ADL 1000, API, Calrec, UA mic pres, neumann, AT, shure, Sennheiser and rode mics...old guitars and drums...nord rack 2, s90, micro korg...yaddda yadda.
http://myspace.com/monkeydenrecording
- Pappy725
Ditto on the Radial stuff. Just got my Bassbone, can't wait to check it out this evening after work.
Stephen
Stephen
MacBook Pro (Retina, 15-inch, Early 2013)
2.4 GHz Intel Core i7, 8GB RAM, OS High Sierra 10.13.2, DP8.07, 256GB SSD
828mkII, 8Pre, Alesis M1 Active Mk2, Ext. FW drives, Yamaha fretless bass, Kay upright bass, Wechter acoustic/electric, trombone, baritone and a proclivity for polka music. (With sufficient quantities of beer) and I play country music.
Thanks for the tips!
I'm looking for an alternative to the Radial headbone because I would ideally be able to switch more than 2 heads. Apparently custom audio electronics (Bradshaw) makes an amp switcher that allows you to switch 4 heads. But it's about $1500 new...kind of expensive. But it does provide a dummy load and enables you to keep all heads on at the same time for fast A/B tone comparisons. Seems like more of a live tool than what I need. I don't need a load box necessarily. I could deal with only having the amp on that I intend to record. I would just need to be sure that I turned off any amps without a load attached. I can deal with that.
Anyway, unless there's something affordable out there (under $500), I think I'll just reach behind my amps and switch the speaker cable manually for the time being.
Hey Itemma, how does the dummy load thing work? I was going to ask how you're not going into a cab and also not burning up your amp. And if you had a switcher, how would you not need a dummy load? I'm uneducated, sorry.
...real bits of panther, so you know it's good...
Macbook Pro 2.3Ghz
2Gb Ram
MOTU Ultralite
DP5.13
Macbook Pro 2.3Ghz
2Gb Ram
MOTU Ultralite
DP5.13
A dummy load simulates the load of a speaker and prevents your amp's output transformer (or whatever the thing is called) from frying. The Palmer is both a load box and a filter (EQ, basically). The filter section of the Palmer simulates the frequency response and other artifacts of a traditional guitar cabinet speaker. So, with the Palmer you end up getting something that sounds very much like your amp through a speaker cab instead of that fizzy and unpleasant direct recording sound that we've all heard before.
I'm trying to find a way to switch between 4 amps, all using the same Palmer load box/filter. I am tired of manually plugging and unplugging each amp to Palmer whenever I want a different amp because I need to move the amp from the wall, unplug, move another amp from the wall, plug. It gets old really quickly, believe me! So I wanted a switcher so everything can stay plugged in and ready to go. I have two options: I can get a 'Head Switcher' or a 'regular' switcher. With a head switcher, any amp that's on but not connected to the Palmer will be safe because the head switcher itself also has a built-in load for the inactive head. Check out the Radial Headbone product for more information on that. If I get an ordinary switcher without a load built-in, then I can leave everything plugged in but I shouldn't turn both heads on because the one that isn't routed to the Palmer won't have a load attached. Does that make sense?
