Loading M5 1.2.2 in ProTools Crashes Session - Anyone Else?
lbueno
Post by lbueno »
This was always pretty unstable with ProTools 7.0 but I could work around it. Now with PT 7.4 it's much worse. I tried the ProTools Tech Support Utility, and the CS2 download, but neither worked. Is anyone else having this problem? Has anyone else solved the problem? I feel so very all alone! :cry:
firminsimplo
Post by firminsimplo »
Hello,
I have the similar Problem with the Mach five V1.1 it does not work with Digital Performer 5.1, Live 6, MelodyeStudio 3 on my Powermac G5 2X2Ghz and also on my Powerbook G4 1,67Ghz. When i try to open Mach five in a Session, the Host Program crashes. i desinstalled it many time but nothing better. If somebody can help...
Sorry for my English.
Firminsimplo.
1,67Ghz Powerbook g4 RAM 2GB
2X2Ghz Dualcore Powermac G5(6,5 Gb)
2x2 Ghz Dualcore Powermac G5( 4,5 Gb)
DP5.11 Ableton 6, Melodyne 3, MetasynthPro 4, BFD1.5 , Guru, Mach Five, Motu SI...
bjornln
Post by bjornln »
firminsimplo wrote:Hello,
Firminsimplo.
Check for updates for Mach 5, I believe there's a good start..... :-)
(at the same time, there's a 5.13 version out for DP...)
/B
