Ultimate Sound Bank X-treme fx With DP 5 Crashes
Blacklisted
Post by Blacklisted »
Hi DP users.
Is there anybody using X-treme FX with Digital Performer 5? I just purchased this plugin and installed it. Every time I go to assign it to audio, DP crashes. Is there anyone experiencing this issue and or could anybody give me any advice as to what to do? I downloaded and installed the update for X-treme fx but it still didn't work.
G5 Quad 2.5 PPC, 6 gb ram DP 5.11, Logic Studio 8, MachV 1.2.3, NI Battery 1, 2 & 3, Plug Sound Pro, Sampletank XL, Motu MX4, Reason 4.0, Waves Gold, NI FM8, Korg Legacy Digital collection, Stylus RMX 1.5, Korg Triton Classic, 2 Roland 1080's, Planet Phat, Mo Phat, Akai MPC 2000 XL, Motu 24 I/O, Motu AV 8x8, Xtreme FX, G4 10.3.9, 2 gigs RAM, Too many plugins, Pro Tools MBox 2
Aramis
Re: Ultimate Sound Bank X-treme fx With DP 5 Crashes
Post by Aramis »
What version of PlugSound pro do you have ?
Have you tried it in LOGIC 8 ?
Aramis
Blacklisted wrote:Hi DP users.
iMac 2012 27 ' 3.2 ghz 32 gigs ram OSX 10.9.4 DigitalPerformer 8.7 , MOTU Track 16, MOTU MachFive3.2, Ethno and BPM , Komplete 9, OmniSphere , Trilian and Stylus RMX , Axon mkII and Godin LG .
chrispick
Post by chrispick »
I'm using it as a module within Plugsound Pro. No problems.
You are using this UVI soundcard, correct?
http://www.ultimatesoundbank.com/uvisc3.html
Blacklisted
I am using the first version (not the UVI version) 1.2. I finally got it working. When I loaded the sounds onto an external hard drive, then loaded the application as stated in the instructions, the application created alias for the AU version and the MAS version. When I assign an Audio Track to X-treme fx, it would crash. So I played around with the alias folders by first removing them them out of the AU components folder, that didn't work so I put them back, then moved them out of the MAS folder. What I then noticed is that it didn't crash when I did that, but it didn't display any sound. So I removed the whole MAS plugin and everything worked without a problem. I am going to assume that there was some confusion with the program as to what folder to acess the information from and as a result, sent DP to crashville.
Aramis, I did try it in Logic 8 before I figured out the situation and it worked just fine.
Blacklisted
Chrispick,
how does the whole UVI thing work? I am a bit confused. I do have Plug Sound Pro's UVI Plugin with the sound pack that came with it. But is there a way to use the X-treme fx sounds in my UVI plugin? I don't mean to sound like a dumb ass but how does that work?
The player needs to be current, but I was getting the same thing. It ends up that I needed to have both the X-TremeFX.ufs and the X-TremeFX.ufs1 both installed on my HD. I confirmed this with the vendor. I didn't think that I needed both and don't recall deleting one or the other, but that was the fix for me. Again, as mentioned by others as well, be sure the player is current.
Blacklisted
Thanks MIDI Life Crisis and everyone else as well. I appreciate your responses.
hellcat
Post by hellcat »
I use it, and don't have a problem at all.
HOWEVER, after upgrading to Leopard, I have been experiencing crashes in DP generally..... maybe Leopard has something to do with it?
hellcat wrote:I use it, and don't have a problem at all.
Can you tell us about your setup? PPC? Intel? RAM? TIA.
Blacklisted
I have a PPC 2.5 Duel core G5, 6 gigs of RAM, 10.4.9 operating system using DP 5.12.
