any ideas on this mess.....
Mon Mar 3 16:24:31 2008
panic(cpu 2 caller 0x0019D334): "simple lock deadlock detection: lock=0x5cbd0b0, cpu=2, owning thread=0x9e01000"@/SourceCache/xnu/xnu-1228.3.13/osfmk/i386/locks_i386.c:317
Backtrace, Format - Frame : Return Address (4 potential args on stack)
0x424e3e88 : 0x12b0e1 (0x457024 0x424e3ebc 0x13321a 0x0)
0x424e3ed8 : 0x19d334 (0x45eaa8 0x5cbd0b0 0x2 0x9e01000)
0x424e3ef8 : 0xe74bfb (0x5cbd0b0 0x424420a4 0xa9dc736d 0x94f7)
0x424e3f68 : 0x1aa3b7 (0x1 0x424e3ff0 0x424e3f98 0x1af5e8)
0x424e3f78 : 0x1af5e8 (0x4252f550 0x42452000 0x424e3fa8 0x6)
0x424e3f98 : 0x445d61 (0x42 0x4252f5b0 0x72f3048 0x1)
0x424e3fd8 : 0x19ed2e (0x4252f5b0 0x0 0x13194f 0x42452000)
0x4252f668 : 0x984964 (0x6b08004 0xf 0x0 0x0)
0x4252f6a8 : 0x984a8b (0x6b08004 0x6b17404 0x209c8 0x2b9b0)
0x4252f728 : 0x9855c6 (0x6b08004 0xf 0x0 0x0)
0x4252f768 : 0x99bd01 (0x6b08004 0x6b17404 0x9e93c0 0x13)
0x4252f7a8 : 0x984411 (0x6b08004 0x6b17404 0x1111111 0x35b190a4)
0x4252f7c8 : 0x91fcbc (0x6b08004 0x6b17404 0x0 0x0)
0x4252f858 : 0x929dcd (0x6b08004 0x1 0x0 0x3)
0x4252f918 : 0x6bf0e6 (0x6b08004 0x3c 0x0 0x0)
0x4252f9a8 : 0x6ad08d (0xc1d00021 0x8000000 0x41 0x2)
Backtrace continues...
Kernel loadable modules in backtrace (with dependencies):
com.apple.nvidia.nv40hal(5.2.4)@0x8d9000->0xa9bfff
dependency: com.apple.NVDAResman(5.2.4)@0x699000
dependency: com.apple.iokit.IOPCIFamily(2.4.1)@0x65f000
com.apple.NVDAResman(5.2.4)@0x699000->0x8d8fff
dependency: com.apple.iokit.IONDRVSupport(1.5)@0x68b000
dependency: com.apple.iokit.IOGraphicsFamily(1.5.1)@0x66f000
com.apple.driver.AppleIntelCPUPowerManagement(9.33.0)@0xe73000->0xe8bfff
BSD process name corresponding to current thread: kernel_task
Mac OS version:
9C31
Kernel version:
Darwin Kernel Version 9.2.0: Tue Feb 5 16:13:22 PST 2008; root:xnu-1228.3.13~1/RELEASE_I386
System model name: MacPro1,1 (Mac-F4208DC8)
config...
Model: MacPro1,1, BootROM MP11.005C.B08, 4 processors, Dual-Core Intel Xeon, 2.66 GHz, 3 GB
Graphics: kHW_NVidiaGeForce7300GTItem, NVIDIA GeForce 7300 GT, spdisplays_pcie_device, 256 MB
Memory Module: DIMM Riser A/DIMM 1, 512 MB, DDR2 FB-DIMM, 667 MHz
Memory Module: DIMM Riser A/DIMM 2, 512 MB, DDR2 FB-DIMM, 667 MHz
Memory Module: DIMM Riser A/DIMM 3, 1 GB, DDR2 FB-DIMM, 667 MHz
Memory Module: DIMM Riser A/DIMM 4, 1 GB, DDR2 FB-DIMM, 667 MHz
Bluetooth: Version 2.1.0f14, 2 service, 1 devices, 1 incoming serial ports
Network Service: Ethernet 1, Ethernet, en0
PCI Card: NVIDIA GeForce 7300 GT, display, Slot-1
PCI Card: pci-bridge, sppci_pci2pcibridge, Slot-2
PCI Card: pci137a,5, sppci_audio, Slot-2@15,0,0
Serial ATA Device: ST3250824AS P, 232.89 GB
Serial ATA Device: WDC WD5000AAKS-00TMA0, 465.76 GB
Parallel ATA Device: OPTIARC DVD RW AD-7170A
USB Device: hub_device, high_speed, 500 mA
USB Device: AlphaTrack, Frontier, full_speed, 500 mA
USB Device: Samsung ML-2510 Series, Samsung, full_speed, 500 mA
USB Device: micro lite, Mark of the Unicorn, full_speed, 500 mA
USB Device: Jog and Shuttle, Contour Design, low_speed, 500 mA
USB Device: Bluetooth USB Host Controller, Apple, Inc., full_speed, 500 mA
USB Device: Generic USB Hub, ALCOR, full_speed, 500 mA
USB Device: SP02-A1, No brand, low_speed, 500 mA
USB Device: USB-PS/2 Optical Mouse, Logitech, low_speed, 500 mA
USB Device: Generic USB K/B Hub, full_speed, 500 mA
FireWire Device: built-in_hub, unknown_value, unknown_speed
No issue previous to 10.5.2 - similar crashes on ppc laptop, with nothing plugged into it.
So 10.5.2 doesn't work for me... here is my quandry ... I'd like to stay as current as possible with my os, in anticipation of DP6 as well... I know it's impossible to answer what will work best with dp6, but where do you guys plan on starting from??? 10.4.11 (or earlier??) 10.5.1 ? or whatever the 'newest' is... at the end of q1
Regards, Rob
