Does original 828 have inserts?
johnedwardlow
Post by johnedwardlow »
I just bought a new compressor and want to be able to add it as an insert on my mixes.
I'm assuming two things:
1. This will enable me to not only put compression on live instruments but also on soft synth instruments as well.
2. When making a final mixdown I will be able to add stereo compression to the entire mix and print a version of my mix to "tape."
Is there a way to to do this using the original 828? If not, how would you go about accomplishing 1 and 2?
