DP vs Nuendo
kwiz
Re: DP vs Nuendo
Post by kwiz »
Originally posted by qo:
Originally posted by kwiz:
I've done sessions out of there using his HD system with DP as the front end. I noticed the difference when he was tracking/mixing a session using Nuendo. The improvement in sound wasn't mind blowing but it was noticable. Again, I guess there is something to be said about having better algorithms in the audio engine.
DP for me is still number one. My Rosetta 800, Big Ben, DAC-1 and the newly added 2bus LT has my friend wishing he never bought PT HD in the first place. He wants to try out Nuendo on my system to see if the "sound" of Nuendo can be improved further.
Cool. I'd be really interested in hearing how it goes if he does bring Nuendo over to your place kwiz. If we can say with some assurance that there really is a difference in sound quality between these DAWs, then we can start banging on MOTU for something better :D
Qo,
I'll let you know for sure.
We might hook up sometime next week.
I'm gonna try to convince him to bring his ADAM's S3A's as well.
Those things sound crazy!!!
Great family and friends!
F. Douglas
Timeline
Re: DP vs Nuendo
Post by Timeline »
You might hold off on this until version 3.1 comes out. It's due within the month.
Timeline
Re: DP vs Nuendo
Post by Timeline »
I have done a record test with a Tele 251 mic/Telefunken preamp/direct into HD192 to DP 4.51 and then Nuendo 3.02 with the exact setup. The clock is UA 2192.
I did elevate the cuemix console input to about 9:00 to match Nuendos normal levels which appear slightly hotter.
It appears that cue mix does not function in Nuendo using PCI 424 card and HD192.
The files are the original ones from each application.
The AIF is Nuendo and they are both 88.2khz-24bit:
www.eirec.com/Audio.aif
www.eirec.com/AudioDP.aif
This one will work I hope
You tell me WHY they sound different because I'm stumped.
<small>[ August 20, 2005, 11:56 AM: Message edited by: Timeline ]</small>
sdfalk
Re: DP vs Nuendo
Post by sdfalk »
Well the .aif file opens fine.
I get error messages when trying to open your SD2 file in any app.
(This file does not parse correctly is one example)
Dp doesn't even "see" the SD2 file.
A Metric Halo ULN8-3D…mmmmmmm
Timeline
Re: DP vs Nuendo
Post by Timeline »
Take off the sd2 and see what happens
I put it up again...
<small>[ August 19, 2005, 11:15 PM: Message edited by: Timeline ]</small>
sdfalk
Re: DP vs Nuendo
Post by sdfalk »
Hmmm
Quicktimes message is:
an unknown error occured -192
Amadeus doesn't "think" it's an SD2 file
I took the sd2 extension off and it wont open
sdfalk
Re: DP vs Nuendo
Post by sdfalk »
I should mention the .aif file opens fine.
Timeline
Re: DP vs Nuendo
Post by Timeline »
OK try this one:
Weird.
<small>[ August 20, 2005, 11:55 AM: Message edited by: Timeline ]</small>
sdfalk
Re: DP vs Nuendo
Post by sdfalk »
Well I give for now..
Need some sleep methinks.
So the .aif file opens fine in any app I use.
I tried this new file in everything from AudioFinder
to DP to Logic express..nothing
The error message in Amadeus is
"this file does not contain an audio track."
This is pretty weird.
sdfalk
Re: DP vs Nuendo
Post by sdfalk »
So in case you're curious..(or not :D )
I tried each sd2 file in various ways in various pieces
of software.
I even tried it on my old G4/400.
Not once did it work.
I'd certainly like to trrack down the reason why as
obviously it worked for you (otherwise you wouldn't
have posted it.)
Timeline
Re: DP vs Nuendo
Post by Timeline »
I think you correctly pointed out the problem SD.
Something happened to the DP file in the transfer to my site. I use fetch and automatic.
The only way I could get it to work as you pointed out, is to do it hqx.
Try that as a last attempt and see whet happens.
This works for me now and thanx.
<small>[ August 20, 2005, 11:32 AM: Message edited by: Timeline ]</small>
sdfalk
Re: DP vs Nuendo
Post by sdfalk »
I actually downloaded the hqx file and had to add the extension
'hqx" as it wasn't there originally.
I decompressed it and..it became a generic exec file.
Don't know what to to tell you.
I'm obviously VERY curious to hear the 2 files side by side.
I can tell you that. :D
<small>[ August 20, 2005, 11:47 AM: Message edited by: sdfalk ]</small>
Timeline
Re: DP vs Nuendo
Post by Timeline »
THIS IS NOW A QUEST!
If this doesnt work, F it.
sdfalk
Re: DP vs Nuendo
Post by sdfalk »
hahahahahah...
It worked.
thanks man.
blue
Re: DP vs Nuendo
Post by blue »
In my experience, most internet servers won't preserve the header on an sd2 file, even with an extension. i would zip the file first (right click file and select "archive" on osx machines), making sure you retain the file extension before uploading it.
MP 2.93 GHz Quad :: 16 GB RAM :: OS 10.6.2 :: DP 7.11
