apple reverb in MV2
homebilly
apple reverb in MV2
Post by homebilly »
is there a trick to get the apple reverb inside of MV2? i'd like to use the Matrix verb on select sounds but it doesn't seem possible.
any ideas?
el Ocho 2.8 running DP6 & RMX with M5II - 828mkII / el Quatro 2.66 running Vienna VI & Vienna Ensemble, RAX 2, M5II & L8 for VSL - 2408mkII / steiner MIDI EVI, Oberheim Xpander, M5II reading UVI .dats, Radium 61 controller
http://www.ronmeza.com
Paris mini studio : iMac 20" intel 2.66 core duo (spring 2009) DP 6.02 - Firebox running M5II & Independence Pro 2.1 connected to Mac Mini (spring 2009) - Firebox running L8, RAX 2, Independence 2.1, M M5II
Keystation 49e controller
carrythebanner
Post by carrythebanner »
MachFive 2 doesn't host AUs. There are lots of options to route parts or individual samples to auxilliary outputs, though, so if you're runnng MachFive in a DAW you can just run the extra outputs through an aux track with the desired plug-ins on the aux.
homebilly
Post by homebilly »
thanks
that is what i thought. :-(
