Share your favorite DP tip!
chrispick
Re: Share your favorite DP tip!
Post by chrispick »
Not to be a pill, but I imagine most of these keyboard shortcuts would be less a revelation if DP had right-mouse-click menu capabilities -- like every other app on the planet .
Anyhoo...
My trick isn't DP-specific, but works great with DP since DP allows for flexible aux bussing...
Two mono auxes in place of stereo auxes. For example, instead of plugging in a single, stereo eVerb in an aux buss, try using two mono auxes, panned hard left and right, with the same eVerb, but adjusted slightly differently. It can make for a more "spacious" sounding verb rather than a solid wash.
To add, try using subtle EQs and echoes with mono verb busses. Or stacking different verbs in an aux bus.
<small>[ July 03, 2005, 06:54 PM: Message edited by: heavypick ]</small>
aaronlyon
Post by aaronlyon »
Originally posted by Panopticon:
Control-click +mouse up/down in the time ruler for really fast and efficient zooming in and out.
Please to eshplain. I can't repeat.
DP7*, Mac Pro Quad 2.66GHz, 12GB RAM, MOTU 828mk3, Mac OS 10.6*
* Bleeding edge updater--if it's released, I've updated, and bled.
aaronlyon
Post by aaronlyon »
I just discovered a great one! I have a scroll-wheel mouse. If I hold Shift and roll the wheel in Sequence view, it scrolls right and left. Yea!
Tim
Post by Tim »
Originally posted by 666:
Select any tracks you want (Shift-Click). Hold down the letter "t" while picking a color. All of the tracks you selected will change to that color.
Holding "T", or hitting it twice makes a temporary group of the selected tracks (not just for colors, but mix/edit too). Hit T once to cancel the temp group.
Tim
Post by Tim »
Originally posted by Timeline:
Turn off the automation pref under the setup window called 'effects parameter' before every mix.
I often remember that after recording a global pass and then seeing all those lines in the tracks (undo, edit automation setup, redo automation pass).
<small>[ July 04, 2005, 03:37 AM: Message edited by: Tim ]</small>
Tritonemusic
Post by Tritonemusic »
Schweats
Post by Schweats »
Many Many thanks ••¦ these tips/short cuts are simply wonderful
folks. Please keep 'em coming !!! Schweats
Sorry , I don't have anything to add at the moment
Schweats
MacPro 2.8/OS 10.10.1/6g ram/Powerbook G4/1g ram/10.4.11/828 mk3 hybrid/MTP AV usb/DP 7.23/Stylus RMX/Omnisphere/Trilian/Mach Five v2/RealGuitar/Korg Oasys/UAD2-Quad card & various plugs/Novation Zero SL mk2 controller/Akai MPK61
Panopticon
Post by Panopticon »
Um, do it right at the top of the time ruler border where you click to place the playback wiper. This is in the sequence editor window...
Billy
suckstar.com
aaronlyon
Post by aaronlyon »
Got it. TOP of the time ruler. Excellent!
Sylver
Post by Sylver »
Originally posted by Tim:
[qb]
The Commands window is very useful but for some reason, I don't think many people ever even look at it.
That's it's name!! I have been trying so hard to find this reference again. I remembered reading about the feature, then forgot what it was called!
Sylver
Post by Sylver »
Hey, I got one! Clicking on a marker's name selects everything up to the next marker.
That is going to be so handy.
I LOVE this program! :D
blue
Post by blue »
My most useful DP tip••¦Command-S to save.
MP 2.93 GHz Quad :: 16 GB RAM :: OS 10.6.2 :: DP 7.11
Schweats
Post by Schweats »
I was wondering if there is a way to create and save a separate
mixer window for say drums only or strings only and to be able to toggle to it with a single key instead of having to pull down
from the mix board window's mini menu and selecting alternate board layout ? Any ideas ? Many TIA ••¦Schweats
Schweats
jfmguitarist
Post by jfmguitarist »
does anyone else hate the consolidated window? my tip: turn that annoyance off in Prefs.
toodamnhip
Post by toodamnhip »
Wow...
Thank you every one...Love it!
This post could go on and on...keep it coming!
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
