Mackie Control Universal Pro not seen by DP 5.12
dansanman
Post by dansanman »
I have just hooked up my new MCU Pro but DP 5.12 on my MacBook Pro won't read it? I have tried everything in both the Mackie and Motu manuals, has any one else had this problem?
jgs252
Post by jgs252 »
I have a CME VX8 that runs as a Mackie Control Surface. I was having problems getting DP to recognize the USB bus in Control Surface Setup. Finally I added a new device onto the MIDI ports on the VX8 in Audio MIDI setup, by simply creating a new device and attaching it to the MIDI I/O on port 2. Now when I launch DP, it sees the device I created over port 1-2 and it sends MIDI control data back and forth on the USB bus.
This might be a CME specific issue for me, but perhaps it helps. Good Luck!
Dwetmaster
Post by Dwetmaster »
DP sees whatever is in Audio/MIDI setup, you need to set it up there and DP will see it.
rknaub
Post by rknaub »
What is said here is the same with the Mackie and they left that out of the manual. Create a device for the Mackie and hook the MIDI virtual cables to the Mackie core MIDI driver. It will work after that.
i had to do that to mine
HTH
Randy Knaub
Randy Knaub
Jireh Productions
San Jose, CA
www.musicforthemasses.com
