NI Syphonic Orchestra
- Dubstylie514
Ok it says In order to use it in my Intel Mac I need Kontakt 2.2..... what is kontact 2.2? is it another program?
Intel Imac, DP 7.22, Motu 828 Firewire, Aphex 230, MIDI Express XT, Rode NT2-A Mic, Proteus PK-6 Keyboard, KRK Rokit 8's
Re: NI Syphonic Orchestra
Kontakt is a virtual, universal sampler and sample player. It is one of many such VIs released by NI. Another is called Kompakt, which was originally adopted (and is included) in the EW Orchestra collections and is just a sample player (not a fully featured sampler like Kontakt)Dubstylie514 wrote:Ok it says In order to use it in my Intel Mac I need Kontakt 2.2..... what is kontact 2.2? is it another program?
Note: KoMPakt and KoNTakt are two different instruments.
NI decided not to update the Kompakt player that shipped with EWQLSO for Intel use, so the only way to use EW's samples on the Mac-Intel is to load them into the full version of Kontakt-- and the version you want to start with is version 2.2. In fact, you probably want 2.2.3 or 2.2.4, to be more precise. Those are the Intel compatible versions.
Now: should you choose to go this route, feel free to drop back by because installation and authorization can be a bear!! Some of the instructions for getting this up and running are a little cryptic in places, and I've found EW of late coming across as being a little tired of explaining it clearly.
EW requires an authorization for the sample collection and NI requires a separate authorization for Kontakt. For some it works like a charm, but I'd guess that half of the users encounter some odd hurdles with NI's registration tool.
Once you get the both installed and authorized, there's one additional step that seems a little convoluted. It requires that you start the KomPakt Player that comes with the sample collection even though it won't actually work on the Intel. Starting it and quitting it just once is supposed to finalize the authorization for you.
Finally, if you are using Leopard, I believe that you MUST use Kontakt v. 2.2.4 and not 2.2.0 thru 2.2.3, inclusive.
I hope this hasn't been discouraging to you at all because once you get through the initial reg/auth phase it's really a very nice orchestra library.
Just so that everything is clear, NI itself supports lots of different orchestra libraries. NI only makes the player, but many third-party companies make orchestra libraries that can be or must be run through NI's playback engine.
The title of your thread says NI Symphonic Orchestra-- but I'm assuming you mean East West Quantum Leap Symphonic Orchestra being used in NI's Kontakt sampler. I hope I haven't misunderstood.
- Shooshie
Actually, the title of the thread is NI Syphonic Orchestra. I'm just hoping it's not contagious. I'm already saying "Ni! Ni! Ni!" Are there knights in the house?
(sorry... obscure references for the few)
As for the Kontakt part, is there not an installer for that somewhere in your disks? I just got the new Garritan Personal Orchestra which uses the same player (Kontakt2) and it came with a working installer which even linked to an updater and retrieved the latest version of Kontakt 2. (version 2.2.4)
There may be further info on their website:
http://www.native-instruments.com:80/in ... ecbeb6681e
Unfortunately, I have seen no change on their website, even though I'm actually USING the correct version of Kontakt 2 on my Intel Mac in Leopard. The Garritan disks just came with the right installers. This should be addressed somewhere in the East-West manual, or Read me, or installer... something, somewhere.
The good news is that the correct version is available and working. The bad news is that I have no idea how to acquire it if it's not on the disks provided by whoever made your VI.
- emulatorloo
Just to clarify -- here is how I understand it. Some of this is speculation on my part. But I think this situation is EASTWEST's fault, not Native Instruments.Frodo wrote: NI decided not to update the Kompakt player that shipped with EWQLSO for Intel use, so the only way to use EW's samples on the Mac-Intel is to load them into the full version of Kontakt
EASTWEST decided to no longer use NI's player and decided to develop their own.
So now EASTWEST has a player for intel called "PLAY". They are shipping their newer libraries with the PLAY engine, and promise to update the older ones like EWQL Symphony Orchestra "any day now."
So the OP could wait for the PLAY update rather than getting the full Kontakt.
I think this was based on a CHOICE by EAST WEST. The reason I think this is:
1. Native Intruments Kontakt 2 Player works on intel and powers several libraries like VirSyn and the Garritan Products.
2. Furthermore KOMPAKT libraries are compatible with Kontakt 2.2
3. Hence KOMPAKT based libraries like EWQLSO could probably easily work with Kontakt 2 Player intel.
If EastWest wanted it to . . .
So in my estimation, for whatever reason, EASTWEST decided not to use NI anymore and build their own engine.
It is similar to what Spectrasonics has done with Atmosphere and the UVI engine.
In both cases the companies seem to have left a technology that works in favor of a technology that so far seems a little iffy>
Dubstylie, if you decide to purchase KONTAKT and you have EAST WEST ORCHESTRA already, you are eligible for a crossgrade
Kontakt is an excellent soft sampler, very powerful and it ships with its own 32 gig library. So it is not money wasted if you go that route. Here is a link to the crossgrade at a vendor:
http://www.audiomidi.com/Kontakt-3-Cros ... P9951.aspx
Or you could just wait for EAST WEST to release their PLAY upgrade:
http://support.soundsonline.com/play
- richardein
There are some issues with EWQLSO upgrade. At present, you get two installs per library, via challenge/response.
When Play is released you will get one dongle for the first library you buy. You will need to buy additional dongles for additional libraries. Thus if you buy the entire ewqlso package, you will get one dongle free and you can load all four licenses on to that if you run it on one machine. (Good luck with that.)
You will need to buy 3 more dongles if you wish to spread the library over four machines. However, if you want to spread any library over more machines than that, you will need to buy that library again.
In short, you get half the installs you had before when you upgrade. An interesting business plan.
Richard Einhorn
MacBook Pro 2019, Motu M4, EWQLSO Play Platinum Plus, Ivory, Kontakt 5, Izotope Ozone, Izotope RX, Omnisphere other plug-ins, instruments, etc. that are used less often. StudioLogic SL88 Grand
This is true, however if the public release of 64-bit PLAY works as well (or better) than the public BETA of the 64-bit engine, the reduced numbers of installs may be a moot point because it won't require as many computers to load up the entire EWQLSO, for example. The other side of this issue is simple portability where, say, one laptop and one desktop can be authorized for libraries that only need one computer to run effectively. That indeed makes some of this very awkward for many people.richardein wrote: In short, you get half the installs you had before when you upgrade. An interesting business plan.
And herein rest the problems: when "the decision" was made to not continue Konpakt Player support for EW on Intel, there was no PLAY engine update for older EW libraries. The Mac-Intel is now into its third year, and as of today there is no public release of PLAY versions for libraries formerly powered by NI players.e-loo wrote:Just to clarify -- here is how I understand it. Some of this is speculation on my part. But I think this situation is EASTWEST's fault, not Native Instruments.
I understand that it takes time for these things to mature to the point of usability, and I'm increasingly empathetic to the difficulties involved-- but the gap is horrid for users! Some of EW's PLAY versions have been imminent for a fairly uncomfortable period of time.
Just to further support and clarify, the NI Players created to run various third-party libraries were unique to each library. This is quite different from using Kontakt 2 which is the same bit of software for any compatible library. Therefore, for each third-party library one had to have a different NI Player installed, registered, and authorized.. one per library. There was an inherent awkwardness with this.
So where the NI/GPO alliance (re: players) continued, the NI/EW alliance ceased except where having to buy Kontakt 2 was part of the price the end user was expected to pay to continue using the EW libraries on the Intel at all. For a lot of people, the full version of Kontakt was really more than they actually needed as they paid for additional features they'd wouldn't use.
Personally, I think EW should extend the free update to the PLAY version to all registered users who had no choice but to shell out cash for Kontakt 2 or for those who were forced to continue using their PPCs against their needs and wills until ALL of the PLAY versions have been released. The problem with this is that it's unlikely that EW would extend their offer any further to more legit users by giving away PLAY for free while NI benefits from sales of K2/K3 because of EW's release delays.
Getting Kontakt 2 as a universal sampler for its own purposes is one thing. It is a good bit of software. However, for those using EW and who perhaps had little use for K2's bundled samples, the need to use things like SC and SO far outweigh the perceived convenience of using different (if arguably inferior) collections to the same effect.
For those Kontakt users who have no interest in EW, however, Kontakt2 becomes a whole different animal.
To boot, it appears that some of the defenses I've read (elsewhere) in support of what's going on seem to ignore the fact that the library is no good without the playback medium and the other way around. You spend thousands on a library and can't use it without spending hundreds more.
EW libraries aren't cheap, and when the choice is to either set them aside to wait 2+ years for the PLAY version or to pay for K2/K3 it creates a two-fold situation of awkwardness:
1. Those who paid for K2/K3 must also make a decision as to whether or not they'll pay for a PLAY update if, for some reason, they missed one of EW's upgrade offers. In the interim, NI makes money on K2/K3 on one stop-gap while EW's own stop-gap hangs in the balance.
2. For those who bought the EW libraries prior to (or after) the sales and free PLAY offers, the options are even slimmer. It has been "reasoned" that these people either just missed the boat or have likely "made good" on using the software over a period of time, but for those who paid $3500 for EWQLSO Plat it feels messy when other come-latelies paid less than $1k for the same library and are getting the PLAY upgrade for free.
I was among the come-latelies, fortunately, but I'd feel the same way had I paid the higher price and gotten less.
Regardless of where the blame rests for this, it's a wide range of users who pay for it in time or money, not only for a format change but for the yawning gap where old promises have yet to be kept.
But, it's awkward and not impossible where a few hundred bucks are involved. I'm still pondering how fair it might be, though. For many, buying an EW library has meant also spending $150-300 (or more) on Kontakt 2 to only later find that if the PLAY update is not free for them (pending date of purchase) and that there is an additional $49 to switch to PLAY and a $99 fee to be able to retain Kontakt and PLAY compatibility concurrently. That the PLAY versions for said libraries remains in its "imminent vaporware" phase of development doesn't help, either.
Wait for PLAY or pay to PLAY. Hmm.
- emulatorloo
I KNOW! and that really gets my goat.Frodo wrote: To boot, it appears that some of the defenses I've read (elsewhere) in support of what's going on seem to ignore the fact that the library is no good without the playback medium and the other way around. You spend thousands on a library and can't use it without spending hundreds more.
My understanding is that EASTWEST originally went with Kompakt player so that the could encrypt their libraries as protection against piracy.
Good for them, they deserve to have their hard work protected.
But there is a big potential for screwing over the users.
With a Roland or E-mu or Giga version of their libraries, the user can still use them even if EASTWEST fell off the earth. There are multiple softsamplers that can read those formats. I expect there are softsamplers that will read those formats in the future.
But these encrypted libraries, that is another kettle of fish. Given the WORST possible scenario, we would need to stockpile G4 machines to use as EASTWEST hosts.
For as painful as that sounds, it just might be the most affordably doable option of all.emulatorloo wrote: But these encrypted libraries, that is another kettle of fish. Given the WORST possible scenario, we would need to stockpile G4 machines to use as EASTWEST hosts.
Strange, ain't it?
