Has anyone out there successfully deployed multiple 896HD Firewire under Windows XP SP2?
If so I would love to know how................Thanks!
WANTED: Successful SP2 multiple 896HD Firewire story.....
No luck with that setup...Sp1 only with dual 896hd, the firewire speed is the issue with sp2, motu manual says 4 at a time, it is not true, i still got some dropouts even with sp1 dual setup. I gave up on it sadly, if you want stability in a daw front end then you should maybe purchase an RME rig, they work and stay in sync with one another. Motu is good as a stand alone unit but no good for sync...In my opinion...
Asus PC-DL Deluxe Server Motherboard
Dual Intel Xeon 3.2 Ghz 2Mb L3 Cache 533 Fsb
Intel 875 Chipset, 4 Gb Ram, 256 Mb Agp 8X Video
Belkin Firewire Pci
Maxtor Sata 7200 rpm 16 Mb Cache 250 Gb X 3
Dual Motu 896HD Firewire Interface
Presonus Digimax LT Pre-Amp
Windows Xp Pro Sp1, Sonar 6 Producer
Native Instruments Komplete 3
Belkin Firewire Pci
Works fine for me
Hi there,
I have 2 896HDs and a Traveler. I use them all together regularly on SP2. didn't even know this was (suposed to be) a problem.
I have 2 dells and a homebrew quad core. All work. Some have keyspan firewire cards, some use firewire on mb.
record church services each week without dropouts (1.5 hours+ continious)
firewire cable between 896HDs is 6" long if that helps.
I am reading more about the problems peeps are having with multiple MOTU devices and SP2
hmmm.... that's not really a success "story" since I have never had a problem.
It may matter that I have all of the optional ins and outs turned off (opticals and such).
firewire cards
While I haven't had this problem, I am using all the same FW cards. They are made by Keyspan. Don't know the model, but they have 3 external and 1 internal FW port and NO USB.
Hope that helps.
Hope that helps.
Recording Engineer, Musician and Worship Leader
Hardware:
MOTU Traveler and 2x 896HD
Homebrew computer specially for Audio/Video
MSI Platinum P35
Intel Core 2 Quad (stock: 2.4gHz or OC: 3gHz)
4 Gigs RAM, RAID 5 Media HDs
Zalman Reserator 1 plus silent water cooling rig
Acurus A150 amp to B&W Nautilus 805 monitors with Genelec sub.
Lots of different software on WinXP MCE (SP2)
Yes, I treated my rooms... lol
Hardware:
MSI Platinum P35
My setup
Hey Guys,
I have 3 MOTU 896HD's and one Ultralight and they work well together. So I can lay down 26 mics and 6 line inputs. The external hard drive is first in the FW chain, then the 3 896HD's. The CPU useage rate is low and hard drive useage is tolerable using SONAR 6 Producer.
I consistently record 22 to 24 tracks every Sunday especially with our Praise Band/Singers. On occasion I have recorded musical special services with great success. I connect through the Mackie 8-bus recording mix board (send outs) and multi-track the band/singers that way. It's pretty good.
I have 3 cabinets to "hand truck" in to a remote location and even my own table to put my stuff on! I even use a laptop to process the audio recordings! I prefer external FW hard drives for speed and handling of audio. I also have an APC 650 UPS that I carry with me just in case the power fluctuates or gets unplugged!!javascript:emoticon(':)')
Smile
I rolled back to SP-1 for a while, but found a "work around" for it. It essentially rolls back the 1394 driver from SP-1.
hp laptop ZD7000 2.8 Gb 1 Gb RAM
Win XPPro SP-2
Cakewalk SONAR 6.0 Producer
3 MOTU 896HD
1 MOTU Ultralite
External 7200 rpm hard drives
Several studio microphones
Smile
Win XPPro SP-2
3 MOTU 896HD
1 MOTU Ultralite
