PCIe424 - Can't choose output source
bredo
Post by bredo »
I upgraded my old PCI324 to a PCIe424 for my two 2408 mkII + one 308 interface.
After troubling a bit with the driver-installation, I now can't choose output source as I used to.
I can only select "enable routing" and just check/uncheck the output boxes, and not select inputs to route to outputs.
Any thoughts ?
ASUS PK5C + Core 2 Quad is what it should run on.
P.S. I've used the PCI324 on 4 different machines with 3 different software without trouble of any kind D.S
billruys
Post by billruys »
You enable routing in the PCI control panel. But you actually route inputs to outputs in CueMix. In CueMix you need to select the output pair from the drop-down on the right and then use the faders to mix whatever inputs you want to the currently selected output pair.
I've never owned a 324, only the 424. Perhaps the user interface has changed?
kmccrindle
ME TOO BUT WITH 324
Post by kmccrindle »
Hi Bredo. Just so you know, I am having the same trouble but with a *used*& 324 card. I am running 10.411 using 1.08 driver. Since 324 doesn't support cuemix in OSX, this may be why I'm having MY problem but doesn't explain yours...What driver are you using (eg. the 1.1?)
Cheers,
Kate
