Audio Unit playback glitch at soundbite start DP 5.01
Hi folks,
Has anyone run into this and found a solution? I've got DP 5.01 running on 10.3.9. I don't know if this has always happened or if I just started noticing it with any AU FX plugs:
On a track with an AU fx inserted, when the play cursor reaches the soundbite (this works better when there's a short bit of quiet at the top of the soundbite) I'll get an audio glitch. Like a little playback buffer dump before the soundbites waveform kicks in.
Example: If the AU is a compressor it'll just pop at soundbite start. If it's a reverb or delay unit, it's like the last few audio buffers play back as soon as the play cursor hits the soundbite edge, so I'll hear a little delay of whatever was playing when I last stopped the transport.
Has anyone else run into this on this version? If so is it fixed with an update or is there a solution?
I've trashed preferences and monkeyed with buffer and configure studio settings with no success.
This is on a G5 2.0 PPC running 10.3.9 and 4 gigs of RAM. I'm using an 828 MKII and MTP-AV USB. The plug ins I"ve noticed this on are Nomad Factory and Apple AU plugins.
Thanks for your help.
- Mr_Clifford
I'm heading down that update road, i've got 10.4 ready to install. I've been in the middle of some projects and didn't want to do the update until they're complete. Plus, I did an earlier update from 10.3 to 10.4 and took quite a performance hit. I'm going to try a fresh install of 10.4 to see if that's better.
At least no one's experiencing this in 5.11 or higher as far as I can tell (no responses anyway). So this will just force me to quit stalling and do the updates. Procrastinators, the leaders of tomorrow...
Thanks for your help!
daniel
daniel
I've noticed it in 5.11. It's driving me nuts. The only solution I've found so far is to play silent portions of soundbites before bouncing (or real-time mixing) or before any critical listening at the beginning of tracks. See this thread:
http://www.unicornation.com/phpBB2/view ... hp?t=24521
Hmm. That's discouraging. I've noticed it only recently and I would think a lot of users are running into this, but apparently not, so I wonder if it's a setting or if it only occurs with certain AUs.
Turning on/off pre-rendering does not seem available to the AU plug-ins I'm using (Nomad Factor, the option is grayed out in mini menu).
i've had it happening in 5.12 and 10.4 when i have automation bypass/unbypass a plugin. sooo, it's a problem i'd say. it creates a popping sound.
MOTU 2408MK3 (PCI-424) / MOTU 1296 / BLACKLION MICRO CLOCK / PRESONUS M80 / FOCUSRITE OCTOPRE / FOCUSRITE VOICEMASTER PRO/ PRESONUS CENTRAL STATION / UAD-1 (2)/ WAVES Platinum / PSP All PLUGS / IK Multimedia (All of them)/ DIGITAL PERFORMER 7.22 / PEAK Pro 6 / MACHFIVE 1.2.3 / DUAL G5 2.0 w/ 5 gigs Ram - OS 10.5.8 / RODE NT1 / RODE NTK / SHURE 57'S / SHURE 58'S / AKG C1000'S / SENNHEISER 421'S / SEINNHEISER E602 / BLUE BLUEBIRD/ BLUE SNOWBALL / AUDIX D2 (2) / EVENT TR8'S / WHARFDALE DIAMOND 6'S
I think I've only noticed it on Reverb AUs--Blueverb, CSR and Breverb. I'm not at the studio right now, but I believe Pre Rendering or Run In Real Time is available on each of them. But it didn't make any differernce whichever I chose.dcate1971 wrote:Hmm. That's discouraging. I've noticed it only recently and I would think a lot of users are running into this, but apparently not, so I wonder if it's a setting or if it only occurs with certain AUs.
i just updated to 10.4.11 and the problem left (for that song). who knows?
- Shooshie
I get this all the time. I got it in 5.11, and I get it in 5.12. I get it in Mach Five2 even worse than anywhere else. It happens at the beginning of every note in MachFive2.
In DP, all kinds of things happen. Muted tracks kick in, and even phantom sounds will play, which I suspect are coming from other chunks in the same file. They're quick, and over with in an instant. But it's too much to overlook. Further, MOTU has known about this for years, and they haven't done anything about it yet. That's got me worried.
In MachFive2 and other VI's I add a tiny delay to the notes. About 10 to 15 milliseconds. That seems to kill most of it. But when it happens in DP, it's different. It's like a track-related thing, and there is no stopping it.
well, i had it happen constantly for the past 3 days on one track. if i used the automation to turn on a bypass for a waves flanger it would create a click at the bypass point of automation.
just today i updated to 10.4.11 and now it is gone??? what does that mean? maybe it was just my computer get bogged down and the new update "FRESHENED" something up?
point being. it's gone. so..it's just trial and error.
- Shooshie
Well, I'm about to install 10.4.11, and I'm going to cross my fingers and hope for the best. I know it won't help the VI thing. Those pops at the beginning of samples are just poorly programmed sampler/player algorithms. But the other things... one can hope.
