UAD with G5 AMD-8131 chipset...
DJeff
Post by DJeff »
Hi,
I'm thinking of getting an UAD card, but after doing some research it seems that the G5 with the AMD-8131 chipset might have some bug with the UAD PCI x card... My G5 dbl 2.5 (part number: M9457LL/A) is using that AMD-8131 chipset...
Does anybody have an opinion or experience with that?.. Should I get the card anyway?... Are the performances still good with G5 using AMD-8131 chipset?... Would I be better off getting a Focusrite Liquid Mix?...
thanx all
builder
Post by builder »
I have a G5 with the same chipset. You don't get as many instances as a pc or other mac may, but I still think its worth it. I have two.
Music - http://www.missingpalmerwest.com/Missin ... songs.html
Dual 2.0 G5 (Rev. A), 4.5 GB Ram, Powerbook 1.5 GHZ 1.5 GB Ram, (BLA) 828mkII, UAD-1 X2 , 10.4.8, DP 5.13, Sebatron VMP2000e, Sytek MPA, Many Mics
OldTimey
Post by OldTimey »
if the UAD-1 plugs intrigue you, go for it. i deal with the same problems, but don't normally run into the 8131 wall. @ 88.2khz, it does become noticeable when you try and use a lot of instances. extra cards only help so much. there's never enough dsp to go around when using uad plugs...freeze and move on i guess.
DJeff
Post by DJeff »
Thanx a lot guys...
I'll probably go for UAD... I'll keep you posted
Mac Book Pro 2.2 i7, 10.6.8, 8 gig ram, DP 7.24, Ableton 8.2.8, Reason 6.0.2, Recycle 2.1.2, UAD-1, Arturia Prophet, Arturia Moog Modular, NI Spektral Delay 1.5.7, Miroslav Philarmonik, NI Komplete 8, Traktor-Pro 2.1.2, Fender Jazz Bass, Adams P11, Yamaha NS 10m, Mackie Big Knob, UltraLite mk3, M-Audio 410, Novation Nocturn, Korg PadKontrol, Korg Nano Kontrol, X-Session, X-Session Pro, Novation Launchpad, Automap Pro, Mixed In Key 5, etc...
