pitch correction not work under DAE?
pcm
Post by pcm »
Anybody running DP under DAE out there? Are you able to use pitch correction under DAE? I can't, but can under MAS. Can anybody else confirm this?
shansen1
Re: pitch correction not work under DAE?
Post by shansen1 »
No I can't ider. It does not work with DAE.
HanZen
burger
Post by burger »
I'm running D.P. 4.52 under DAE, I haven't gone to 4.6 yet, I want to but I'm in the middle of a few things at the moment and don't want to get hung up.
My guess is simply that D.P.'s new pitch correction will only work with the MAS audio engine option. Since it is a MAS Plug in???
Dual 2.5 gig G5 2.5 gig RAM. DP 4.52
2408 MK3, Digi 96 & 192. Pro Tools Accel HD 2. Various plug ins.
sdfalk
Post by sdfalk »
It's not a plugin (as far as I can tell)
A Metric Halo ULN8-3D…mmmmmmm
pcm
Post by pcm »
Okay, here is what I have observed. Under DAE, you can see the pitch markings, but you cannot move them. Switch to MAS, and then it works. So perhaps it really is a MAS plugin, but embedded in the track itself.
I have just aquired an HD2 system. What else in DP won't work under DAE, aside from MAS plugins in general?
methezer
Post by methezer »
Right. It may not seem like a plugin in the traditional 'track insert' sense, but it is definately a DSP process and therefore I would assume it would be reliant on MAS.
burger
Post by burger »
I've used a similar DAE set up for about 6 months now. Seems everything else is good to go except for the plug ins. Do you find D.P. slow in following DAE commands and in booting up D.P. under DAE?
b.
shansen1
Post by shansen1 »
I just received this message from MOTU
It is correct that pitch correction is not available under DAE at this time.
HanZen
