hi,
yesterday i recorded a live session for 90 min in Logic, 48kHz, 24Bit.
Today when listining through, i recognised the beginning sounds good.
after some time on most tracks there is a slow fade in of some very disturbing noise, but its not really noise, it sounds more like digital failures... This noise stays for quiet a time and then fades away again...
hmmmmmmm.....
any idea???
i used one 828mkII USB2.0 and one 8pre FW (=16tracks)
to use both i had to set uop an aggregate driver. i think i remeber reading a similar failure when someone used his aggregate driver...
Do you think this is the problem??
i will change the 828 to a second 8pre anyway, cause i need a quick access to gain of the signal, so in the future i will not use this aggregate driver..
BUT: I am interested if this was the problem or something else???
On the meters the signal was not distorted... and it doesnt sound distorted but (digitally) destroyed...
Thanks for any help..
digital distorted noise while using aggregate driver??
