All I want to know is if anyone is using giga file on Machfive I said It is not possible.
Anyone having luck playing Giga files On a Mac Pro using Machfive 2.01. Other file plays OK but Giga file malkes a high picht noise. Anyone usingGiga file?
Your answer will be greatly appreciated. I send a note to MOTU but no answer from them...I am on my own
I have attempted to re-instal Machfive 2 the downloaded v 2.01 and change the destination Hard disk (To make sure it was not the disk) But I have the same results. I have andI rarely ask question.
I did everything the manual said about loading preset from the browser etc...
EricD
Anyone using giga files on Machfive?????
Using DP5.12 as a front end for PTHD3
I have seen in the manual that MAchfive2 is compatible with Giga files. I dont nderstand why it is not working. My problem is that I need thoses Giga files to work. Maybe Motu is not aware that such a problem exist, I have written to them but I did not get an answer,When and If I do I will post the knowledge here so that you too will be able to use Giga format withMachfive2.
Eric D
Eric D
